Old 10-10-2006, 02:22 PM   #1
Trevnutz
Default au xr6
Hi
What are the specs of a 1998 au falcon xr6 sedan e.g power? kerb weight? 0 to 100kph? and 400mtre times? I might be buying a really cheap 5 speed manual one but want to know more about the car Thanks
Trevnutz is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2006, 04:02 PM   #2
JeffAU1
JeffAU1's Avatar
Originally Posted by Trevnutz
Hi
You will need to know if it was VCT or not.
Non VCT (164KW): http://www.redbookasiapacific.com/au...p?key=FORD98HP
VCT (172KW): http://www.redbookasiapacific.com/au...p?key=FORD98HX
:eclipsee_ MY CAR :eclipsee_
JeffAU1 is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2006, 04:39 PM   #3
loxxr6
XB in parts...
loxxr6's Avatar
Hi
My 99 AU Manual XR weighed in at 1540kg's (no driver full tank fuel).
Some times I found :
1999 Ford Falcon XR6 5-speed
0-100 : 8.3
Qtr Mile : 15.9
KW(not rwkw) : 164
Has Fez and XB.
loxxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2006, 07:12 PM   #4
stiddy
stiddy's Avatar
They are generally faster than those times, but it really comes down to how much of a good peddeler you are with a manual..
Should be able to get down to about 7.2 sec 0-100(wheelspin, im down to about 6.5now) and around 15.2 sec down the 1/4
Well thats what I got in my bog stock AU 5speed on my first night out at the track.
stiddy is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2006, 01:19 PM   #5
Trevnutz
Was your a vct or non vct
Old 11-10-2006, 01:28 PM   #6
GlennBA
GlennBA's Avatar
0-100 : 8.3
Qtr Mile : 15.9
KW(not rwkw) : 164
15.9 1/4 mile? Mine does 15.6 and its a forte
GlennBA is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2006, 01:28 PM   #7
Trevnutz
The one I might be buying is a intech without the vct :-(
Would it cost much to put the veriable cam timing on my model
Old 11-10-2006, 02:03 PM   #8
JeffAU1
JeffAU1's Avatar
But i guess it all depepnds on the weight of the car (spare wheel, how much fuel is in the tank) and also if the driver can drive a manual and get a good launch.
Old 11-10-2006, 02:41 PM   #9
JC
JC's Avatar
Don't worry too much. The VCT got the extra grunt so the power to weight ratio of the car was similar to the intech veriosn. The VCT got IRS, which adds 70kg odd to the car weight, meaning it had to have more power to match times - in stock form, there's not much in it.
An exhaust upgrade and a flash tune will see the intech nearly up to stock XR8 times (AU1).
Ford Performance Club ACT
Old 11-10-2006, 08:20 PM   #10
TwistedEL
TwistedEL's Avatar
Yeah plus there is way less modding prospects on the VCT, if that's your thing
TwistedEL is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2006, 08:38 PM   #11
stiddy
stiddy's Avatar
There would be 1/10th of stuff all between an AU1 manual XR6 and AU1 manual XR8...
Auto would be in the XR8's favour.. just.
I agree with Twisted EL.. If you want to mod it alot go for the HP.. easier and cheaper and there is alot of aftermarket support.. VCT is starting to look up, but there isnt much available for them yet..
Just ask Casper.. does the word custom mean anything to you? everything needs be built or made to suit the vct theres nothing 'off the shelf' so to speak.
Old 11-10-2006, 10:10 PM   #12
Casper
Contributing Member
Casper's Avatar
Not actually true. Everything is avaliable off the shelf except the head and cams.. and they are avaliable from G&D now.
I went custom because with my original off the shelf exhaust etc I just wasnt happy with the potential of them. Results were good but they were not capable of dealing with future plans I have. So I went custom to ensure "upgradability".
That said though, a cam is the most common and easiest power mod and, apart from the G&D one and a JMM regrind, theres nothing really out there.
Older, wiser, poorer.
Now in Euro-Trash. VW Coupe V6 4motion.
Casper is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2006, 08:11 AM   #13
jonbays
TL40 Wagon?
Here is some test data for you to have a look at. its a bit small i have no space left.
Old 12-10-2006, 10:38 PM   #14
Trevnutz
Cheers for all the info guys. I am only new so Im going to ask a few questions lol. Supercharging will be the next topic I'll post heheHEHEHAHAHAHA
Old 04-11-2021, 10:18 PM   #15
Neato1998
Default Re: au xr6 2000
Hey I have trouble with the diff clunking everytime I take off and slow down
Neato1998 is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2021, 11:59 AM   #16
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Question Re: au xr6 2000
if you look the last post was 2006.
