30-12-2019, 08:23 PM | #1 | ||
Howdy all, it's my first thread here but I've been lurking in the shadows silently gathering information for a few years. Anyway here is my 2cents to the forum with a few tips on repairing au fairlane woodgrain door spears.
This tip is a variation on the tech resource that uses a similar method but I've found mine is a lot stronger and will have better longevity. The reason these spears fall off is due to broken/snapped stalks on the back where the screws come through the card. With a maccas straw and a product called "Selleys - KneedIT!" We can rebuild these broken screw stalks. Just cut some straw to length, doesn't matter if too long as we can cut and sand this stuff, kneed some of the product with your hands until mixed and soft and stuff the straw you just cut full of it. Then press the filled straw over the broken stalk and hold firm for a few seconds. Wait for approx 60mins for it to fully cure, cut to length so it's just short of poking through the card. Drill a 2mm hole into the kneedit stalks. Press back into door and fasten the new spear stalks with short button head screws. Good luck!, if there is enough interest in these kind of repairs I'm happy to make better, more structured repair guides! Pics for reference: Last edited by CrypticLuxury; 30-12-2019 at 08:36 PM. |
31-12-2019, 09:43 AM | #2 | ||
13-01-2020, 11:22 AM | #3 | ||
Afterburner + skids =
This thread is relvant to my interest - picked up a set of Fairmont door cards over the weekend with all spears in tact - took them off to paint, boom. Broken. Haha oh well.
So I will be giving this a go. Thanks for documenting it all.
19-01-2020, 09:33 PM | #5 | ||
Tried this out today with a decent level of success. I struggled with a few of them, but the end result is all four spears attached to the doors quite securely.
Thanks for the knowledge!
19-01-2020, 11:31 PM | #6 | ||
Did mine slightly differently
LTD spears are super hard to come by. Most plastic prongs on mine were cracked, I used megapoxy to glue m4 studs into the plastic bits and glued the cracks, used a flat washer and nut to retain them to the door trim. Bit of thread sealant on the threads to prevent rattling loose. Did the same thing with the prongs that were completely snapped off; just glued studs on to them; mine have been going good for about 5 years now.
Current Car: 2002 AUII LTD 408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS Daily: 1998 Mitsubishi Super VR-4 Legnum |
20-01-2020, 12:16 PM | #7 | ||
That's also a good way to deal with it!
Curious to know what the difference in LTD spears are - is it the wood grain pattern used?
20-01-2020, 01:58 PM | #8 | ||
Yeah it’s just darker. Similar pattern.
Thread Tools | |
Display Modes | |
