Old 25-04-2007, 09:50 PM   #1
au2sw
Blown 5L coming
au2sw's Avatar
Default XR door cards
just wondering how much i may be looking at for a set of xr door cards including power window switches. only after ball park figures. thinking of fitting them into the wagon. that way it gives me a reason to get power window regulators for the rear and run wiring for the rear switches
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2007, 10:20 PM   #2
HOTC2R
I called FTG auto salvage a while back to get an idea on how much they were. AU black interior door skins - $75 per door skins without switches.
Pity your not in Vic. I know of four black door skins for $220.
HOTC2R is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2007, 10:21 PM   #3
bodes-sh
rear sedan doors are different to wagons, i'm pretty sure the cards are too, but fairlane ones are the same, well the actual door anyway
bodes-sh is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2007, 03:14 AM   #4
Mechan1k
Mechan1k's Avatar
damn ... didn't know the wagons had different doors to the sedan.
I guess it goes to show I really havn't had a look up close at wagon doors then.
Old 26-04-2007, 03:55 AM   #5
FGII-XR6
FGII-XR6's Avatar
yes the wagon is long wheelbase the same as the fairlane so fairlane is the way you need to go
Old 26-04-2007, 12:41 PM   #6
chief
FTF Club Moderator
chief's Avatar
I have fitted Fairmont Ghia door trims to my wagon. The door trims are the same.
Albert Einstein:
Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom.
(It is more difficult to alter a preconception than split an atom)
Falcon Tickford FPV (FTF) Car Club of NSW
Fords in the Park 2010
I use and recommend Stingray Car Security.
http://www.stingraycar.com.au/
chief is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2007, 12:55 PM   #7
LG
LG's Avatar
chief's right... Door trims are the same, right across the range, Falcon -> Fairmont -> Fairlane -> Wagon
AUIII Falcon Forte, with SIX Appeal
LG is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2007, 05:33 PM   #8
Mechan1k
Mechan1k's Avatar
Good to know .... otherwise it would have cost Ford a fortune to make up a completely different shape/size door/trim as well ... that so me sounds about right for a larger car maker ... do it as cheap as possible ... keep everything the same.
Old 26-04-2007, 08:25 PM   #9
au2sw
Blown 5L coming
au2sw's Avatar
excellent, so it is possible then. so if i set aside $300 that should cover it then you think? then all i need is rear window regulators (about $120 a pop i think arent they?) and all will be good
Old 26-04-2007, 08:42 PM   #10
chief
FTF Club Moderator
chief's Avatar
Trust me its a pain to get the wiring to work with the 4 way switch on the drivers door trim. It can be done. Speak to Stav he did my power windows.
Albert Einstein:
Old 26-04-2007, 08:44 PM   #11
au2sw
Blown 5L coming
au2sw's Avatar
thanx chief, will keep that in mind
Old 30-04-2007, 07:18 AM   #12
au2sw
Blown 5L coming
au2sw's Avatar
well, while at the cleveland auto spectacular yesterday, it gave me a chance to take some notice of fairlane door skins and XR door cards. Im pleased to report that in fact, yes, the door cards are the same size through out, the difference between a fairlane/wagon door to a sedan door is the plastic moulding around the window reaches out further to the door card in the rear door. unfortunately i didnt think of taking pics at the time for comparison. perhaps next time i get a chance.... aslo as i said, the fairlane doors and wagon doors are identicle, so now im not limited to hunting for just a wagon door, makes sense really that they would be the same, both being LWB vehicles and all. my only real concern had been that perhaps the slope along the top edge of the frames might have been different, but they're not so yippee!!!! : :
so anyone else out there considering new doors/door cards, all door cards are interchangeable, all front doors are interchangeable, and rear wagon/fairlane doors are interchangeable.
now all i have to do is run the wiring to through the wagon for power windows, get the door cards and new rear left door, and im a happy camper!!!!
one question does remain though, the chrome strip around the windows of the fairlane doors. are they easy to remove? i woul;d assume they are and that removing it would return it to a base door. is the stripping a part of the rubber suround or is it sepperate?
and lastly, does anyone know if there is a wiring diagrame for power windows for an au in here, or should i just ask stav if he could do a quick layout of what he did with chief? im good with electrical wiring, so ill be doing it myself, but help from someone who has done one before is always appreciated
col
Old 30-04-2007, 09:37 PM   #13
AUIII
AUIII's Avatar
Sorry I can’t offer any advice at the moment but I will be watching this thread with interest, I am currently collecting the bits to do this as well.
I have the door cards and all the switches just need the regulators then I will have a crack at it .
If I get there before you I will let you know how I go.
Current Ride 2012 Mitsubishi Triton Dual Cab ute :
AUIII is offline   Reply With Quote Multi-Quote with this Post
Old 30-04-2007, 10:01 PM   #14
blackers10
blackers10's Avatar
you should of asked me and i would have let ya have a good squiz at my cars insides!!
fern tree gully quoted me $750 for a full leather interior in black
not sure if this included dash etc.. but i did stress the ENTIRE part in the question..
Smalls Wrecking at clontarf(around the corner from RDP) specialise in newer models etc and are reasonably priced!!
they also have a website www.smallswrecking.com.au that they DO respond to emails from!!
i have had good dealings with them
On The Street Feature Winner Performance Ford Mag
See my car at:-www.aufalcon.com/blackers10
blackers10 is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2019, 11:15 PM   #15
Bigredbf
Default Re: XR door cards
I seen a trashed ba with xr bits on it and a rear xr door trim. It’s got me thinking weather it has functional windows tho
Bigredbf is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2019, 11:16 PM   #16
Bigredbf
But wagon uses the same floor pan as sedan
Old 23-12-2019, 11:21 PM   #17
Bigredbf
Sorry but Was this au ba? How did the electric windows line up? I have a ba looking to do a xr conversion but I also need to install the electric windows
Old 23-12-2019, 11:24 PM   #18
Bigredbf
I might be a little late on this but I’m not sure about au but ba has a massive wiring loom that I’m looking into installing
Old 24-12-2019, 10:10 AM   #19
Bill M
Bill M's Avatar
You would be better to post in the B series forums as this is the AU only
https://fordforums.com.au/forumdisplay.php?f=175
cheers
Bill.
AUII XR6 VCT ute
20 years and still going strong!
