19-08-2007, 08:11 PM | #1 | ||
Hey mates, I am going for my manuals tommorow, and I need a few pointers to help me remember.
1. when stopped at traffic lights, should I keep the revs up and friction point on before take off? 2. how do you do a reverse park? the reason i am asking is because I want to actually do good in the test, I have aced the clutch and everything, but I need to know the finer points. please send all replys preferably before 8am tommorow. Thanks guys, have a good one. andrew. |
19-08-2007, 08:16 PM | #2 | |||
Regards Alan FG GT in Lightning Strike 5th anniversary edition in manual 1 of 25 And an 2019 MD Mondeo Trend Wagon in Platinum White |
19-08-2007, 08:17 PM | #3 | ||
By your point in no. 1, do you mean riding the clutch? If so, no. It puts un-needed pressure on it and decreases the life of it, it's a bad habit to get into.
When I went for mine the thing was to always do a handbrake start, not sure if they still make you do that. As for reverse parking, if you havent learnt yet best you get the olds to take you out for some practise before tomorrow. You most likely will have to do it, or a parellel park and they can be strict. Always use ALL your mirrors, it'll make life easier for you and everyone else. It's a lot easier to line yourself up using them rather than twisting yourself all over the joint trying to see where you're reversing |
19-08-2007, 09:10 PM | #4 | ||
WP Fiesta LX
1. Since your starting out, you usually bring the revs up first (to 1400-2000rpm depending on car) and then bring the clutch out to friction point. As you get more experience, you'll be able to bring the clutch up to friction point and add revs almost simulatenously, but this comes naturally with time so don't try to do it on the day of your test.
2. Just as you would in an auto. Pull up to the car alongside, put it in reverse and slowly release the clutch to friction point to get you going. Use the gas if the engine needs more revs (i.e. My Fiesta will shudder if I don't add gas, however a Falcon would generally have enough torque so that this doesn't happen). Also push the clutch in all the way if you need to slow down/control acceleration and never fully release the clutch!!! In reverse parking, I only need to use the brakes when I come to a complete stop, otherwise the car will slow itself when you push the clutch in. I'm going to go ahead and assume that you already have your P's and have done the driving test on auto only. Don't forget to think and drive like an L Plater when you go to do the test. Two hands on the wheel, stay under the speed limit, indicate for 5 seconds prior to changing lane or leaving the curb, always check your blindspots, always look out the back window when reversing and don't put your arm around the passenger seat to look out the back. I did my manual driving test a couple months after doing my autos and I passed both first go. Surprisingly, they didn't make me do a hillstart but I had practiced my handbrake starts on the steepest hill of the area prior to the test anyway. Also, if you're quick enough you can learn to move off without using the handbrake and only rolling back 1cm (don't do this in the test though, it's just for convenience! :P). They don't expect you to use the handbrake when moving off from a start on a normal road, unless the road is at a decent incline or you feel comfortable doing it that way. The only thing the testing officer mentioned to me was to engine brake by downshifting to 2nd when slowing down instead of just putting it in Neutral and coasting once the revs dropped below 1000rpm. And I've been doing that ever since. Good Luck
No Show, No Go - Just Woah!
19-08-2007, 09:31 PM | #5 | ||
OH NO not another one being taught to get a license and not how to drive!!!!!
FORD RULES OK The more I know ppl the more I love my DOGS. 2011 SY Territory Limited Edition TS 2000 AUII SE ute IL6 |
19-08-2007, 10:09 PM | #6 | ||
MY21.5 Mustang GT
you're asking how to do a reverse park and you've got your test tomorrow morning?
riiiiiiiiight........
19-08-2007, 11:59 PM | #7 | |||
Can't go around corners
I think he means pointers on reverse parking, not how to reverse park.
Quote from Jeremy Clarkson in the Top Gear Vietnam special: Quote:
20-08-2007, 12:14 AM | #8 | |||
You should have practiced reverse parks before your test.. :
Shouldn't your driving instructor have told you about those points? Mine told me to always hand brake and never ride the clutch and we went through reverse parks/parallel parks from the first lesson. Has your instructor told you you're ready?
20-08-2007, 12:38 AM | #9 | |||
Former BTIKD
#2. At appx 60kmh approach parking space from the wrong way, flick steering wheel whilst at the same time pulling on the handbrake. If all goes well you should do a neat 360 into the space. On a lighter note, your asking 12hrs before a driving test how to do this?... Gimmie a break!
20-08-2007, 05:53 PM | #10 | ||
how did u go ? u pass?
2015 FGX XR8 - 557rwkw on E85 KPM Street Fighter PCMTec Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19 Shockworks Coilovers PITLANE AUTOMOTIVE & PERFORMANCE
