Old 19-10-2021, 07:59 PM   #1
rodo
Default 2010 Focus 5 speed manual gearbox interchange
Hi All
My grandson has wrecked the syncro's on 1st and 2nd
I'm in Melb and looking at "help yourself wreckers" for a donor gearbox
Not finding much for "LV" 2009-2011
Are there earlier or later year Focus gearboxes I can use ??
I'm aware his Focus uses a 2.0 ltr Mazda engine
So is the Mazda 5 speed an option
Just worried the clutch input (shaft) maybe different between Ford Mazda
Thanks in advance Rodo
rodo is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2021, 08:28 PM   #2
GTLEGEND
Default Re: 2010 Focus 5 speed manual gearbox interchange
The 5 speed manual in LV Focus is a Getrag B5A transmission and unique in the same setup for LV Focus, ie you cannot use another B5A transmission from other makes and even Ford models.
You can get you a brand new one for around $3000. Can help with this if need be.
Old 21-10-2021, 10:41 AM   #3
rodo
I found a B5A Getrag manual trans with this Part # BM5R 7002 LRA
Will it suit Focus LV 2009-2011 with Duratec 2.0 Petrol engine
Thanks rodo
Old 21-10-2021, 12:21 PM   #4
GTLEGEND
Thanks rodo
No that part number is for a 6/2012 to 6/2014 LW/LW2 Focus.
You need 8M5R 7002 KC or 8M5R7002FF pending on your car. A VIN will confirm which one you need. The first part number is the one worth $3K new.
Old 21-10-2021, 01:12 PM   #5
rodo
Hmmmmmm
These are a minefield
LV went from May 2009 - Aug 2011
There's a MKl May 09 - Aug 11
Then MKll Aug 11 - Aug 12
I guess this is the reason for 2 gearbox part #'s you have quoted
Thanks by the way - much appreciated
His Vin is AFAUXXMJDUAJ00331
2010 LV Focus Hatch
Old 21-10-2021, 01:18 PM   #6
GTLEGEND
Hmmmmmm
2010 LV Focus Hatch
5/2010 MY09 LV Focus B5A Manual Trans, correct transmission part number is 8M5R 7002 KC. The other part number is for a 6 speed manual, just looked deeper into it.
Old 21-10-2021, 01:32 PM   #7
Peter B - CV8
Can you just get the synchro's replaced ???
Peter B - CV8 is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2021, 01:46 PM   #8
GTLEGEND
You can buy Synchro rings seperate at around $50 each..
Old 21-10-2021, 07:42 PM   #9
rodo
Yes it may come to that
I'm use to these - used on 3rd 4th 5th
https://www.bearingkits.co.uk/Ford-i...k-ring/871.htm
1st and 2nd are a bit funky and $$$$$
https://www.bearingkits.co.uk/Ford-i...ng-set/868.htm
Old 21-10-2021, 10:21 PM   #10
GTLEGEND
Here is first and second gear parts.
If you let me know what you need, can advise price for genuine Ford parts.
Old 23-10-2021, 10:11 AM   #11
rodo
A week on
He claim's "I've figured it out now - no grinding at all"
Hmm - is he right - I tried double clutching - slow / fast engage
I found slow was best and told him to treat it really really nice
Next - because the oil has
A Probably never been changed (115k on Odo)
B Copped a hiding in the last month from clutch related issues
I'll try an oil change - wish me luck n watch this space lol
Old 01-11-2021, 04:58 PM   #12
rodo
Drained the oil mid week - too much brass / bronze in it for my liking
I found 3 transmissions first one $1100 another $900 another $600
I ended up at Harvey "pick a part" wrecker in Langwarrin South
$180 with 30 day warranty - wacked it in and it's a winner
Thanks all for your help and advise
