Old 25-12-2018, 11:25 PM   #1
bethauto
Default Laser 08/2009 KN Auto Sedan-1.6 ZM Eng
Engine no start - Checked fuel pump operation & pressure, all good & holds. Tried to retrieve codes from diagnostic connector in engine bay by earthing out & LED test lamp, but none make sense. Further checks found no injector impulse signal & there seems to be no spark also. (Common cause in case is Crank Angle sensor (Was replaced - No Diff). I don't think/believe the vehicle is fitted an engine immobiliser, as there is dash lamp display. Removed instrument cluster & checked if lamp was fitted & no provision for same.
Any Ideas Out There Would Be Appreciated
bethauto is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2018, 04:58 AM   #2
happy1
Default Re: Laser 08/2009 KN Auto Sedan-1.6 ZM Eng
Ford Laser = prior to 1994.
What do you mean by 2009 ?
Obviously unless you can do the diagnose yourself, it will cost more to fix than the car is worth.
If you have a repair manual and a basic multimeter you need to check every signal / wire loop all the way back to the ECU.
By law in some states, there should have been an immobilizer.
Cheers,
happy1 is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2018, 12:24 PM   #3
GTLEGEND
Last Laser was the KQ and finished in 2002. So the vehicle cranks but no start? Have you checked power to the coil pack?
Old 26-12-2018, 02:09 PM   #4
Itsme
Experienced Member
Itsme's Avatar
All KN & KQ laser models were equipped with immobilisers.
Itsme is online now   Reply With Quote Multi-Quote with this Post
Old 26-12-2018, 02:53 PM   #5
Itsme
Experienced Member
Itsme's Avatar
Check IAC valve, ignition coils, ignition timing, spark plugs, high tension leads, crank shaft sensor or pulley damaged also improper gap setting. EGR system malfunction.
You will need to use a jumper wire in conjunction with multitester or test light, you will also need the diagnostic chart to read the pulse signals.
You will find the repair manual if you google for it.
Old 26-12-2018, 04:38 PM   #6
No spark, no injectors. Sounds like a classic case of immobilisaton.
A normal key won't start it, and if memory is correct, you will be locked out of system even with the correct key. (I think that system is a 3 strikes and you're out).
Easiest way is to ring around locksmiths who know of this system and go from there.
