Old 20-07-2020, 03:32 PM   #1
Snupple
Default Wiring Driving Lights Up
Due to the not-so-good high beam on my Ambiente MD I am going to get some seperate driving lights.
How easy are they to wire up? I have done it on my previous cars with a realy etc, but not on something as complicated as these recent cars!
Snupple is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2020, 08:56 AM   #2
thebigd
Default Re: Wiring Driving Lights Up
Not sure about the wiring side of things, but where and how are you going to mount them ?
thebigd is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2020, 11:09 AM   #3
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
Providing the high beam positive wire is normally off (not sure in this case)
To keep it all legal (can only activate driving light's when high beam's are on)
Just tap into the original high beam power wire at the back of the headlight as the trigger wire for the relay.
Run a wire from the relay's earth terminal back inside the cabin (use an existing firewall grommet) to an on/off switch, then the other side of the switch goes to an earth point, this way you wont have a positive wire running through the firewall
You can also connect a Driving Light on indicator light by running a wire from a positive behind the dash to the light and the earth side connect's where the earth wire from the relay connect's to your switch
30 - Power, Battery Positive via a 30A fuse
86 - Relay trigger, High beam wire at back of headlight
85 - Relay Switched Negative, Driving light main switch on dash, other side of switch to an earth point on the body
87 - Positive power wire to Driving light's
Negative wire from Driving light's to earth
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2020, 12:10 PM   #4
Snupple
Using one of those license plate bracket mounts
Old 21-07-2020, 12:12 PM   #5
Snupple
Thanks!
Old 21-07-2020, 07:34 PM   #6
bundybear75
bundybear75's Avatar
Pretty sure the headlights are negatively switched ie positive is always live (on the MC at least)
I got around this by tapping off both the positive and negative high beam wires, ran one through the driving light switch, and the connected them to the pins 85 and 86.
Biggest problem I had was finding somewhere to run the switch wire through the firewall, so I temporarily mounted the switch near the under bonnet fuse box (4 years ago.....)
2012 MC Mondeo LX TDCi Wagon - Highway Hack 392K km and counting - Now gone 😢
2008 Peugeot 308 HDi - Highway Hack II
2008 Citroen C4 HDi - Highway Hack III
2010 Peugeot 308 HDi SW - Shaggin Wagon II
2016 VDJ200R Landcruiser GX Wagon - TTD V8 Power !
2017 Toyota RAV4 GX Wagon - Shopping trolley - Gone
2022 Volvo XC40 T4 Inscription - Shopping trolley II
2002 BMW R1150GS
bundybear75 is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2020, 07:37 PM   #7
bundybear75
Just check that the bumper is strong enough to support the bracket - on the MC, the number plate is only attached to a thin section of plastic grill - I ended up making support brackets from the lights to the radiator support panel to avoid the lights bouncing around when driving
2002 BMW R1150GS
Old 21-07-2020, 07:40 PM   #8
Snupple
Thanks, will keep an eye out for that
Old 21-07-2020, 08:00 PM   #9
thebigd
Agree bundy. The MD is the same. I also considered the front number plate bracket for an LED bar, as I do a bit of night driving (through the winter months). I believe it will need support if you don't want it bouncing around.
Old 21-07-2020, 08:32 PM   #10
bundybear75
lights by bundybear75, on Flickr
2002 BMW R1150GS
Old 22-07-2020, 10:12 AM   #11
If you are not sure on the wiring, just buy a kit from Korr or someone else.
Old 22-07-2020, 01:55 PM   #12
Snupple
With the bracket, there are a few options:
https://www.stedi.com.au/number-plat...g-bracket.html
https://www.ebay.com.au/itm/NUMBER-P...R/324181425358
https://www.supercheapauto.com.au/p/...040204#start=7
Next is to work out which lights to use!
Old 23-07-2020, 02:35 AM   #13
bundybear75
I started with a 120W light bar, but I upgraded to the above 7 inch LED driving lights. Much better reach and spread. I do around 1500km per week, at least half of that in the dark, so good lights are essential.
These are the Kings from 4wdsupacenter - you can get them for around $100 delivered. They work great, but I have found that the lens is starting to yellow a little after 3 years of being parked outside all the time.
You can see the braces I made to take the vibration and rattle out of the bracket
lightbar by bundybear75, on Flickr
2002 BMW R1150GS
Old 23-07-2020, 01:45 PM   #14
Snupple
Where did ther brackets come from, can you get a closer photo at all?
Old 24-07-2020, 12:46 AM   #15
bundybear75
Braces are made from some 12mm x 3mm (?) aluminium strap from bunnings, bent and twisted to go from the side of the lights through the grill, back to the radiator support panel. Covered with a quick coat of matt black rattle can
2002 BMW R1150GS
