Old 18-07-2020, 04:38 PM   #1
3SpeedScottie
Default AU S2 XR6 conversion into ute windows not working
Hello. I am new to the forum Long time Ford fan (mostly small Fords) this is my 1st Falcon. I am just about to finish fitted a complete Series 2 XR6 VCT Running gear, suspension, brakes, interior, dash, heater core, doors, panels, the works into a Hordern 6x2 ute.
I have got everything to work. ABS, airbags ect. But for the life of me cannot get the windows to work. I am using the sedan wiring and switches.
I have power to door harness and the central locking/ door actuators work.
I am thinking it has something to do with the security system.
Please help I have wiring spaghetti everywhere. This is the last thing I need sorted before a RWC
Thanks in advance
Scott
3SpeedScottie
3SpeedScottie is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2020, 05:06 PM   #2
3SpeedScottie
Default Re: AU S2 XR6 conversion into ute windows not working
Do I need the back door plugs to be jumped to make it all work?
Old 18-07-2020, 06:35 PM   #3
PG2
#neuteredlyfe
PG2's Avatar
Which switches are you using for the drivers door? The 4 bank or 2 bank of switches?
Old 18-07-2020, 06:57 PM   #4
3SpeedScottie
The 4 bank with the lock button
Old 18-07-2020, 07:57 PM   #5
11ford11
Swap front and rear window fuse links - does power window relay pull in with ignition on - inside fuse box
Check for power at grey/yellow wires at master switch on drivers side
Old 19-07-2020, 11:14 AM   #6
3SpeedScottie
Thanks everyone for the help turns out the fuse box was faulty. Was getting power to the box but none to the power window wires. Swapped it out and it all works sweet
Thanks again 😃
