Old 03-04-2006, 01:34 PM   #1
OZFORDAU
OZFORDAU's Avatar
Post Problems with the AU1!
Hey,
A couple of problems with my 99 AU1 Forte!
1) Each time i brake the auto shifter would shake in drive!
2) If i take off in 1st gear it has a wineing noise!
3) Each time i brake hard the steering wheel and auto shifter shake! The steering wheels goes off tap! For example if im going 80km/h and brake hard that when it happens! Or even if i brake hard from any speed over 60 i think it happens not to sure but thats what i think....Please help :
Simon
OZFORDAU is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2006, 01:45 PM   #2
Casper
Contributing Member
Casper's Avatar
rotors are warped.. machine or replace the rotors and pads.
whining is usually more a diff issue however it may be time to get the auto serviced. How many KM's on the car now?
Older, wiser, poorer.
Old 03-04-2006, 02:04 PM   #3
OZFORDAU
OZFORDAU's Avatar
Post Km's
It's done about 203,500 and i braught it at roughly 198,800
So i've only had it a coulple of months! How much does it cost to get them machines or replace the rotors and the pads?
Old 03-04-2006, 02:08 PM   #4
GK
Walking with God
GK's Avatar
What he said!
Sounds like time for DBA slotted rotors! Hightek brakes in Moorabbin have a special on them for $100 each until Easter! There is a thread on this "Slotted Rotors" that has the info you may need.
With the whine, how loud is it? How long has it been there? Is it there all the time or just when the auto is cold? I'd get an auto service and then see how it goes. Most forum guys talk about getting the fluid replaced every year or 20,000 kays, some guys say even more frequently. I'm now in the habit of getting it done once a year also. It's good preventative maintanence I reckon.
I'm betting the fluid in yours wasn't changed for a few years though right?
GK
Old 03-04-2006, 02:39 PM   #5
OZFORDAU
OZFORDAU's Avatar
Post Whining noise
Originally Posted by GK
What he said!
GK
The whinging noises is only in 1st! Not sure if it's cause the auto is cold or not! I think it does it all the time when in 1st! The noise has just come recently withen the last week! I've only had the car for like 2 months so i don't know when the fluid was last changed! I used to use the auto shifter has a manual as in 1, 2 , 3 and Drive....But didn't use it that much really....And have since stopped? Could that have caused it?
Simon
Old 03-04-2006, 03:26 PM   #6
The Monty
Just slidin'
The Monty's Avatar
If the whining noise is more like a high pitched whistle, it is your fuel pump (I think). Just trying to help.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 03-04-2006, 03:54 PM   #7
OZFORDAU
OZFORDAU's Avatar
Post Ok
If it's the fuel pump why doe's it only do it when i put it in 1st?
Simon
Old 03-04-2006, 04:53 PM   #8
The Dok
The Dok's Avatar
Sounds like the same problem I used to have, turned out to be my ex missus in the front passenger seat :
Would definately recommend the slotted rotors (@$100 ea, see Cam @ Hightek Brakes hightekbrakes@iprimus.com.au) fitted sum myself last week, much much better & a piece of p!ss to fit.
Removed by laminge
The Dok is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2006, 04:54 PM   #9
autickfordfairmont
Tickford Equiped
autickfordfairmont's Avatar
I think i know the noise your talking about. The Auto box's have a high pitched sound they make, like a valve or something not so much whistling as buzzing sorta thing. Only when Locked in First gear and when accelerating, sorta like a loud whistly buzz noise. My AU does it and so did my old EA, but as said only when locked in first.
When its dead cold it wont do it, but after about 1 min it will do it. Nothing bad, as far as i know.
Genuine Tickford Equiped 1998 AU Fairmont
Mods: ....... Dash mat & Air Freshener, does that count as a mod??????
Sports Exahust, Tickford Intake Snorkle, K&N Filter, NGK Plugs, Top Gun Leads
TS50 Front Bar with Fog lights, TS50 Rear Bar. Injected LPG System,
autickfordfairmont is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2006, 07:25 PM   #10
Dark Horse
_Oo===oO_
Dark Horse's Avatar
Whine in 1st in the BTR auto is a common thing. Mine does it as well, and it's regularly serviced. The only way to get rid of it is to replace the box.
Dark Horse is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2006, 07:27 PM   #11
cArSiK
your sounding awfully like my gregories worskshop manual with your diagnosis :
cArSiK is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2006, 07:45 PM   #12
The Monty
Just slidin'
The Monty's Avatar
Simon
Im not sure, but thats what I was alwys told it was. autickfordfairmonts synopsis is a little closer to the mark I think, compared with what I have bee getting told though.
Old 03-04-2006, 07:52 PM   #13
GK
Walking with God
GK's Avatar
Get the transmission fluid changed, get the rotors and some Bendix Advance pads, and go from there.
All the best with it.
GK
Old 03-04-2006, 08:00 PM   #14
Casper
Contributing Member
Casper's Avatar
Almost a cut and paste job for AU/BA/BF isnt it?
They come warped from Ford
Old 03-04-2006, 08:11 PM   #15
OZFORDAU
OZFORDAU's Avatar
Talking Thank's...
Ok thanks everyone!
Should i get the brakes machined? How much would that cost?
Or should i go and get some DBA Slotted rotors? Which will cost $400 for the lot! Money is a issue again until i can get a job...
And do i need to buy pads if i buy the rotors?
Cheers Everyone
Simon :
Old 03-04-2006, 08:12 PM   #16
Casper
Contributing Member
Casper's Avatar
dont worry about the rear brakes, just do rotors and pads for the fronts.
Old 03-04-2006, 08:15 PM   #17
GK
Walking with God
GK's Avatar
What he said! Will save you heaps!
GK
Old 03-04-2006, 08:40 PM   #18
OZFORDAU
OZFORDAU's Avatar
Default ?
May i ask why not do the whole lot?
Old 03-04-2006, 09:35 PM   #19
GK
Walking with God
GK's Avatar
Others will be able to give you a much more technical explanation than this, but it's the fronts that do the majority of the work. Have you ever noticed that on cars and motorbikes, the front rotors are always larger? This is the reason why.
The fronts stuff up far more because they cop the most heat etc.
From what I understand and have read here, the rears are ok as standard rotors, just do the fronts.
Hope that helps. Let us know how you go.
GK
