12-01-2012, 12:25 AM | #31 | ||
went straight into back of the cluster. you can find pin numbers and details in this thread also if you have your workshop manual that will help
12-01-2012, 11:10 AM | #32 | ||
"Layin Frame"
Thanks mate saw it was pin 3 on the 20pin plug but couldnt find a diagram of pin locations for that plug?
12-01-2012, 03:19 PM | #33 | ||
66 Mustang
So for coolant light, earth the black wire on header bottle and red wire on the header bottle to back of cluster?
12-01-2012, 03:50 PM | #34 | ||
"Layin Frame"
yeah that sounds right mate but couldnt tell you which wire on the cluster. but i havnt done it yet so might not be right
30-06-2015, 11:44 PM | #35 | |||
Hi I get this and understand it but not real clear on pinout numbering. I connected this Fairmont cluster today to my 1/2000 AU1 Falcon and noticed it mostly works > revs, speed, left blinker, volt, so on. what didn't work. turn parkers on and cluster lights turn off instead of dimming, right blinker and abs don't show. I believe this 4 wires will fix my problem. pity DTE is not in this new cluster as I like to view that option. Anyway 3 more gauges are better then DTE so I will live with out it. Before I start cutting wires and making changes I would like a little more info please. What is the pinout numbering to start with. Another thing, oil light stays on and needle doesn't move. do I need to buy a pressure oil switch? Thanks |
01-07-2015, 10:47 PM | #36 | ||
Could someone please help me out.
I have done a lot of research and think this it correct but I would like someone who has done this to let me know if I am on the right track please. |
13-07-2015, 01:57 AM | #37 | ||
Okay so I found the PIN layout order swapped the 4 wires around
everything worked like I had hoped but came across a new problem not mentioned on the board anywhere. What was happening was when I start the car everything looked fine until I needed to put the lights on. With Parkers the Odometer light would go out. The pin layout is as follows in the following image. I had to do a lot of meter testing to find my answer on the next problem. The Od lights going out with parkers on is a earthing problem from pin 15 on the 2nd connector. I found by jumping the wire from 13 to 1 fixed the lighting problem with Od not lighting up with Parkers. As I don't know if the white wire on pin 15 serves any other purpose I thought it would be a better idea to put a Diode between 15 and 1 to allow power pass one way with Parker lights on. This works perfectly. The following images shows the finished project |
20-07-2015, 04:11 AM | #38 | ||
06-03-2016, 02:40 PM | #39 | ||
Hi You seem to know a bit about the au cluster looking at some of the post, I was wondering if you could help... Im tring to put AU stereo controls into an EL.. Ive chased the wiring from clock work spring and RED/WHITE wire from there goes into the cluster and then come out as a RED/BLACK and a ORANGE and BLACK going to the stereo...
What happens in the cluster to go from 1 wire to 2 wires. I have looked every online and cant fine anything Hope you can help Thanks inadvance Graham Barnes |
06-03-2016, 04:23 PM | #40 | ||
Hi Mate, this is the best I can offer. Wiring says nothing about stereo being connected to the cluster http://www.fordmods.com/ford-technic...ter-upgrade-d4
My only guess is the cluster wires are for dimming the stereo lights. This is images of my old cluster, it's nothing great but maybe it will help. http://oi63.tinypic.com/s5bf5y.jpg http://oi64.tinypic.com/vbyud.jpg http://oi67.tinypic.com/spw0hs.jpg http://oi65.tinypic.com/dxidfq.jpg |
22-03-2016, 01:38 AM | #41 | |||
Is it possible for me to retrofit an AUI sender to my AUII Fairlane and get a "proper" gauge or not? |
11-07-2020, 01:05 PM | #42 | ||
Lange212
Cheers to the bloke that posted pictures and all the info for the wires for the cluster upgrade, you saved me heaps of time!!
So ive put a series 3 fairmont cluster in my series 2 ute. Everything works except for when i turn the car off and the lights are on, it doesnt make the warning noise like the standard low series cluster did. Anyone else had this problem? |
26-03-2021, 04:25 PM | #43 | ||
Thanks. This was very helpful. I have got my S3 XR dash now working in my S3 Forte.
Just did the odo light fix. Only problem I had, was when I did the wiring to get the odo back light working, ended up activating the Smartshield. Couldn't start it. Not sure why. Pretty sure I followed the instructions. Maybe coincidental. I have snipped out the odo light wiring and had a locksmith reset BEM. On the bright side, I now have a spare key. |
12-11-2022, 07:50 PM | #44 | |||
16-11-2022, 05:03 PM | #45 | ||
Next upgraded Mk1 Leopard
That's what we hope when we share our ups and downs, great to hear the info still helps
01-03-2024, 05:14 PM | #46 | ||
i know this is a very old thread, i was just wandering, I've done all the things needed to upgrade my Ford S3 Futura to a high-series Ghia cluster, but for some strange reason, i can NOT get the illumination to work [cluster lights]. Any ideas???
Thread Tools | |
Display Modes | |
