02-01-2021, 12:01 AM | #1 | ||
There are many advantages to Natural Gas. It is cheap, efficient, abundant, and the cleanest of all fossil fuels.
Not sure how it works in other cities, but in Perth reticulated gas is part of every residential subdivision. In all my years, I can recall only one instance in which our domestic supply was interrupted. My son is keen to connect a generator, for power in the event our supply is ever interrupted long-term. The problem is that we'd then have to source diesel to run it. At best, that's a lot of phaffing about, and in the event of a disaster, diesel supply could be more problematic than power. Kubota (and others I imagine) make NG powered generators, so I was wondering if that were a solution? |
02-01-2021, 07:59 AM | #2 | ||
Cabover nut
So what would be the difference between storing natural gas and storing diesel in a tank for your scenario.
You can simply run diesel genset and heating on bio diesel. Very safe to store used filtered vegie oil yourself and blend it with diesel.
02-01-2021, 11:20 AM | #3 | |||
ive known of a few in perth where contractors have severed the gas line under ground
as inn what i do for a daily job has seen me delivering storm water pit darains n the such (concrete products) for our company to site to be installed and on a few occasions had to take it back some where to be off loaded due to them rupturing a line and halting work heck even when they did the road works out side my place they had done the same here too Quote:
where as at least youd be able to syphon drain liquid fuel from any vehicle or other said engine gas youd be looking at bottles and i think youd find theres a limit to the amount allowed stored on a residential property being under pressure and all and any bottle above a fork size if hard to man handle at the best of times we use to have oil heated houses and storage tanks i think your allowed at least 1000lts of diesel stored (an ibc) and mini tankers can come and fill for you and its the least volatile fuel and not stored under pressure but if your really worried about a said earth shaking disaster and availability of fuels then maybe a genset that could run on home made bio fuels or better said renewable's and storage with solar wind and even hydro from the water flowing in your downpipes to cover all bases
yes still (as money n time permit) doing the rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually just remember don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! I have taken up meditation... at least it's better than sitting around doing nothing !! Last edited by wodahs; 02-01-2021 at 11:32 AM. |
02-01-2021, 05:09 PM | #4 | ||
Where to next??
Yes, diesel would be my choice over gas in this situation.
Of all the main fuels, it is the easiest to obtain / replicate.
02-01-2021, 05:31 PM | #5 | |||
Experienced Member
02-01-2021, 06:51 PM | #6 | |||
yes , and im in the verbs of perth id still be surprised if you couldnt keep 1000lts on your property not like the farmers i know that have 10000 to 50000 lts stored i know local houses that still have the oil heaters with storage tanks and im allowed to bring the prime mover home and that has 1000 cap in its tanks so id be surprised if he couldnt keep 1000 buy like he'd need to for a gen set id prob keep a 44 gal drum
yes still (as money n time permit) doing the rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually just remember don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! I have taken up meditation... at least it's better than sitting around doing nothing !! |
03-01-2021, 02:41 PM | #7 | ||
A gennie running on NG would be the simplest way to protect against run of the mill blackouts. No mucking about with fuel tanks, etc.
But yes, the question is how robust the gas infrastructure is, in the event of a bigger issue.? Hypothetically, if we were hit so hard by a pandemic that we struggled to keep our electricity supply operational, is the gas system easier to keep running?? |
03-01-2021, 03:08 PM | #8 | |||
