[EBGLT]
Ok guys here it is.
Took the car down to Hallam performance today with Paul fom CVE. First run was not so good it ran 122rwkw which I was pretty disapointed and a little worried I must admit. Paul soon jumped out of the car and said you have a vaccuum leak which alternately means boost leak. So I got up under the and worked my wonders turned out that there where a few minor leaks here and there. Out of the tree at the back of the inlet manifold. Sliding across under the engine I had a look at the wastegate which look good until I touched the the srcew which holds the vaccuum hosing which controls my boost level. It was loose as so after hunting around hallam performance for 10 mins we found some washers that would fit however are on temporary as I need better ones that need to be a little smaller and tighter around the thread. Here is the last Dyno for the day. ![]() As you can see 163.6rwkw was acheived at only 3psi which is insane im over the moon about it. Cant wait till I get a few little things here and there sorted out and I can wynd in a bit more boost. hehe. ![]() SnyperEB
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
Nitrous Junkie
Congrats, thats an awsome effort for only 3psi. Can't wait to see what it does with a bit more boost.
'97 Toyota Supra - 6spd, Tilton Triple Plate, Built 2J, T88H-38GK, HKS 272 Cams, Haltech E11V2 |
Two > One
a low boost setup would make a very nice car to drive. Wind it up to 5-6lb and would be a fantastic daily power plant. As it sits it would be 1000x more tractable than a 164rwkw N/A car. Nice work!
windsor user
thats mad shaun...... good work....
would be very fun now, and as mentioned it'll only get better with more boost ![]() |
ThUmPeR
Congrats on the dyno test Snyper!! good to see it!
loving the turbo too! cheers troy
1994 ED Falcon ICE: 7" DVD BIG MTX sterio OTHER: 2.5" exuast, Pacemaker extractors K&N Flat pannel 20" Gianna wheels Dropped on Pedders BA Bonnet bulge clear indicators all round Full EL Ghia interior |
you and your cheap tricks to gain massive hp lmao
mpfi conversion 35rwkw gain tighten some screws 40rwkw gain when are you working on my car? :P |
holy crap thats awesome well done shaun!!! 160rwkw on 3psi., DAMN thats good!!
2015 FGX XR8 - 557rwkw on E85 KPM Street Fighter PCMTec Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19 Shockworks Coilovers PITLANE AUTOMOTIVE & PERFORMANCE
:D:D
congrats that is a good result off 3 psi now we all cant wait to see your car at cruises now
Cheers Grant |
likes falcon's
it's all waynes fault! just leave shaun alone you butcher :P
www.carhubsales.com.au |
:D:D
after alot of people turboing there cars i just was speaking to mark he is thinking about turboing his EB and use the LTD as a daily
Cheers Grant |
EBII XR6
Awesome work shaun, thats more power at the wheels than mine has at the flywheel from factory! I bet it pulls hard now.
Mark dont do that, supercharge the LTD and dont waste money on the EB!
DEVLXR
#12 | ||
Gunna girlie-man
great work shaun, ill be the one catching you now :(
(for now ![]() ![]()
WADE CAMS-- UNLEASH THE POWER!! <INSERT WITTY SIGNATURE HERE> Daily- 05' BA futura... work done. Cruiser- 85' VK berlina... more work done ![]() ![]() |
#13 | |||
Congrats Shaun! Can't wait to see the beast in action!
#14 | |||||
[EBGLT]
Otherwise I think I have a lot to look forward to 163.6rwkw was gained with a very restrictive exhaust, boost leak, standard fuel standard motor, standard ECU and lots of little things here and there that are all going to get the car running better and increase power I owe a huge thanks to Paul from CVE (V8Capri) as he has alot to do with the car seeing these kind of dyno figures. Quote:
#15 | ||
was that with the gearbox you stole of me or your other one? lol
good work, more work, more kws, NOW |
#16 | |||
[EBGLT]
Na sorry mate that was with my gearbox your one is in my shed. Clutchneeds adjusting its bent something near the gearbox. Might just use the spare T5 I have in the shed.
#17 | |||
#18 | ||
3PSI that is bloody awsome Shaun great numbers mate
looking farward to see what it produces with a few more psi well done bloke jason
#19 | ||
If it aint Blown it Sucks
What is really impressive is that is the same stock engine, stock ecu and stock injectors.
Once you sort all the niggly bits, we can put some extra fuel in it, should be very good.
Australia's fastest 3V n/a Ghia 13.52 @ 102 mph @235 rwkw !! Now turbo 11.77 @114 mph 320 rwkw, 810 nm torque, 280rwkw @3000 rpm !! :thebirds: ![]() http://www.fordforums.com.au/showthread.php?t=11296772 Thanks to Snort Performance, Headsex and CVE Street car DeTomaso Pantera ![]() Drag car 1995 Mustang, Haleys Comet ( It's back !) Power by CVE ![]() Melbourne's first SNIPER Tuner ![]() Now tuning E series |
#20 | ||
Last warning
Good stuff Shaun, deffinately gives me inspiration to get mine ont he dyno.
how ever i imagine mine won't make too much more power then that lol.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
#21 | ||
The one and only
Shows how simple and achievable real power is.
Soon it will be 200 which is heaps and a very nice car to drive. Start savine mate!
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
#22 | ||
Good stuff mate.
163 is impressive on 3 psi. What was your exhaust when it was tuned? You said it was restrictive but I thought you got it done today? I made 114rwkw on 3 psi with the standard exhaust and a wolf back in the day so you are doing very well.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
#23 | ||
Gunna girlie-man
any problems while on the dyno? : running hot, noises etc?
#24 | ||
that's impressive, any plans to take it to Calder Park or the likes ?
#25 | |||
XR6 Turbo FTW
Braden its just a thought for now I don't know if I will do it yet but I have plans to supercharge the LTD anyway in the next year or so. Its funny how everyone love the LTD lol. Its great but I like to EB more in the way of racing etc and the LTD as a Weekender cruiser and show car
02 BA XR6 T U R B O - 232rwkw @ 6psi Blueprint, 19" FG2 XR6 Luxo Rims, Momo Steering Wheel, XR8 Bonnet Buldge, Full Leather, 3.7 Typhoon Diff Gears, Force Lip Spoiler, De-badged, Ghia Boot Garnish, Pedders Adjustable Coil- Overs And Camber Kit 96 EL XR6 - (Daily) Gunmetal Grey, 19" Typhoon Copies, Tickford Body Kit, Pedders Sports Ryders With Shortened Shocks And Camber Kit, Full S/S Difilipo Exhaust With Matching Extractors |
#26 | ||
LOW AND SLOW
Thats great snypereb, Congrats. The power you gained just from going to MPFI was impressive, but now with turbo its insane.
#27 | |||
#28 | ||
Two > One
Out of intrest what fuel pressure are you running?
#29 | ||
Parts bin special
That's some impressive performance Shaun! Well done!
Weekender 1964 US Falcon Futura convertible - Rangoon Red 260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels https://fordforums.com.au/showthread.php?t=11470868 Daily 2014 SZII Territory diesel - basic runabout Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more 2000 AUII Fairmont - XR wheels, Ghia interior 2010 FG XR50T ute - XR8 bonnet, Streetfighter intake |
#30 | ||
Wayne told me today on the way to FDC, couldnt believe it. Thats awesome power man, at such low boost! Will go hard when its boosted. Are you planning on changing the motor any time soon? Sorry if Ive missed that part, just skimmed through this thread..
Must go pretty well but! Good to see it all up and running. |
