Old 28-02-2009, 06:19 PM   #1
KHlaser92
KHlaser92's Avatar
Exclamation KH laser problems
After turning off the engine mostly after driving for a wile, it sometimes trys to diseal on trying to run with the key off untill it dies. Any ideas what the problem is?
KHlaser92 is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2009, 04:43 PM   #2
Peter B - CV8
My daughter's one (auto) used to do it as well. I adjusted the idle speed etc - but it still continued to do it. Ended up just suggesting that she simply turned the ignition off whilst the car was still in Drive - the much lower idle speed whilst in drive, stopped the run on.
Peter B - CV8 is offline   Reply With Quote Multi-Quote with this Post
Old 05-03-2009, 06:38 PM   #3
KHlaser92
KHlaser92's Avatar
thanks, mine is a 5 speed manual, any ideas?
Old 06-03-2009, 12:11 AM   #4
78XC
Clinically Insane
78XC's Avatar
My guess naturally since it is deiseling on would be that your ignition timing is out by a just a fraction to effect running. (Naturally I'm asuming that you have an Electronic distributor and that you won't be having any trouble with point gaps). The reason that it keeps running is because since the spark is getting delivered at the wrong time (being carby I assume?) you are it still drawing atomised fuel into the combustion chamer and its still getting a little spark to ignite that fuel.
Personally I would get a timing light and put a decent chalk mark on the timing markers, un-do the bolt that hold the dizzy in place and adjust your timing (retard or advance) till both those chalk marks line up.
If you need to know how to adjust timing in more detail just say and I will point yo in the right direction as best that I can. I'm not claiming to be a machinic thats just what I have been taught.
Thanks,
Andrew
1978 XC Falcon Restoration"VIEW HERE" :
1978 XC Falcon- Waiting...
1971 XY Ute- In peices and full of bog
1974-6 XB Ute- Need to pick up
1990 EA Sedan- Grandpa spec minty
1998 XH Falcon Ute- Daily hack
1976 ZH Fairlane- Neary FINISHED!
The War Machine is coming
78XC is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2009, 09:10 PM   #5
74XB
Sometimes I'm Here...
74XB's Avatar
Yeah, by who was that, I wonder...?
When everything is coming your way... Your in the wrong lane!
For Sale:
  • Various Ford bits from XA to EA. PM all enquires or contact 0428913715
1974 XB Fairmont Restoration"VIEW HERE!!!!"
  • 1974 XB Fairmont - 250 Pre X-Flow T5 5 Spd (Project)
  • 1984 XE Falcon Wagon - 200 X-Flow T5 5 Spd (Project)
  • 1990 EA Falcon GL - 3.9l BTR Auto
    (Daily)
74XB is offline   Reply With Quote Multi-Quote with this Post
