01-05-2009, 09:49 PM | #1 | ||
Have done some searches but not really seeing for my issue. I see a normal problem with the AU Sedan but buggered if I can find it
Water leak today - found out when water poured out as I opened the boot - from the panel area where the number plate is and lots of condensation about. Have no spoiler, and no leak or water stains only a lot of condensation on the inside of the top boot lid. Dry as between the seat and rear window (looking up side down) & around the lights - no evidence of water near the lifghts at all, and only on the carpet where I lifted up the boot. Ive had the wife run a torch around the outside along the boot line (I was inside - its dark now) and did see a slight glimmer of light, but upon opening the boot, I cant see where a seal woul actually get in between the boot and the fabricated panel thats welded to it (imagine the top of the boot lid is wet (condensation) but its on the underside of that only) thoughts? |
02-05-2009, 12:25 AM | #2 | ||
All Bran = Regular Member
Boot rubber... $68 from Ford.
I got sick of getting wet everytime it had rained and I opened the boot. I looked up and down, had my son-in-law in the boot and hosed it down, checked this, checked that, checked the other... Sometimes it is the obvious. |
02-05-2009, 01:14 AM | #3 | |||
Walking with God
GK
02-05-2009, 01:15 AM | #4 | |||
AU Falcon Man
yeah mine does the same thing... only ocasionlly after it rains... my boot seal is split above the fuel flap area...
2015 SZ MkII Ford Territory TS Aero Blue, RWD Petrol, Standard Sat Nav. 2013 TF Ford Kuga Ambiente Panther Black, AWD, 6 Speed Auto, 1.6lt ecoBoost Turbo Petrol. Was 2012 FG Mk2 Ford Falcon XR6 Swift Green,6 Speed Auto, Stock... 2001 AUIII Ford Falcon Forte Genuine T2 TS50 bodykit, 18" BF Cobras, Boge and Eibach Suspension and Complete AU2 Fairmont Ghia Interior 1994 EF Ford Fairmont Gun Metal Grey, Lumpy Straight 6 |
02-05-2009, 01:19 AM | #5 | ||
Cocoloko
to be sure just remove the grommets at the bottom of the boot lid to help it drain, or drill a small hole at the base.
My Au boot lid is coverd in rust worse then a XD rear boot well lol. It was bogged when i bought it but has pushed it all through again, pretty cut about :(
94 ED XR8 Sprint: SVO alloy heads, FMS F303 cam, AU EECV ECU, T5, on going build. 2010 Territory: family bus. 79 P7 LTD 351. |
02-05-2009, 10:44 AM | #6 | ||
cheers guys - I will look at the grommets and possibly adjust down the boot lid a bit, if not - "boot rubber" ;)
02-05-2009, 07:31 PM | #7 | ||
The garnish leaks on mine.
9/98 AU1 XR6hp-about to retire from the road and be reborn on the race track. 86 ZL mint grandpa spec with premo sound and 150000km 07 TTG XForce, PLAZMAMAN, IDYNO TUNED, 349KW@all 4! 97 el futura MOCKed up with a 2500 stall, heaps of fun! |
03-05-2009, 10:15 AM | #8 | ||
gone fishing
new boot rubber fixed mine up as well
Cheers Whiskers |
