BLUE OVAL INC.
Know of someone looking to buy a Territory AWD and was wondering if theres any point of difference from SX to SZ2 in terms of how they deliver power to each wheel, reliability, things to look out for.
They want to be able to launch/retrieve their boat on slippery/sandy ramps and have had trouble with single spinner RWD's. I said diesel is cheaper to run but more expensive to maintain but they're not too worried either way. I was thinking SY2 AWD 4.0L 6A? |
![]() Join Date: Jan 2005
There was a change towards the end that made the AWD an on-demand type system from the previous continuous system. Think it was in the final SZ series that the change came in. For the boat ramp, they might feel a bit of slip before the centre diff engages and the front wheels provide propulsion. I believe the change was made to reduce fuel burn (increase fuel efficiency).
Happy to be corrected here.
My Ford Family... 2014 GT-F, Manual, Kinetic with Black Stripes 2021 Mustang Mach 1, Manual, Velocity Blue |
#4 | |||
![]() Join Date: May 2018
But "almost" means a sharp hard turn will turn front wheels off temporarily and I seem to remember at low speeds and low throttle it may also be disengaged - engaged at low speeds and light throttle applied - I remember this from when I was looking at mods for snow driving - the mod to lock the transaxle to engage the front wheels at all times ie in the snow need low power low speed traction. But in any case I never had an issue on boat ramps with my AWD Terry. ie no spinning of rear wheels. The SZII AWD system is a hack however by the Ford accountants - it could have been much better by including the input shaft output shaft speed sensors but that is history.
Ford Territory 2016 SZII TX diesel 17" rims Escape 2022 ST-Line AWD (wife's car) Mercedes SLK280 (toy car) |
3 users like this post: |
#5 | |||
BLUE OVAL INC.
So can I assume up to and including SZ1, drive is directed to all 4 wheels 100% of the time and if so do you know if its an equal balance of power or more rear? Cheers. |
BLUE OVAL INC.
I had a SZ1 RWD petrol and it'd spin the right rear pulling my jet ski out on the same sandy ramp with anything more than slight throttle on new tyres, which was why I suggested he look at AWD as he wants a Territory.
Think it was 38/62 split. It was never symmetrical like the Subaru
#8 | ||||
Regular...with metamusal
![]() Join Date: Oct 2009
Hi. my SX is AWD with approx 35% drive to the front wheels. the front diff is not a LSD and all wheels driven full time. just checked an owners manual [SY?] .... the torque split [going by the book] is 38% front and 62% rear. Quote:
![]() Join Date: Jun 2007
Here is a list of what I’ve replaced in my SYII Barra in the last 3 years (now at 180km). Another forum member who is my mate also had an SYII and replaced similar things. If you can’t work on these cars yourself, stay away.
Useless offroad but I’ve found mine good in the sand and stable on dirt roads. Rebuilt rear diff New fuel pump New power steering pump New steering rack New fuel pump Front diff pinion seal New tailshaft New starter motor New gear selector cable New oil pressure switch Rebuilt front brake calipers New headlining Deleted heat exchanger New Bendix rotors and pads at 100km 3 new door actuators New drivers window switch New tailgate hinges New drivers abs sensor New rear lower control arm bushes New rear upper control arm bushes New front sway bar links New rear diff bushes and rebush whole rear cradle New front diff bushes New upper ball joints New lower ball joints New suspension and springs at 100km
Proud owner of the ugliest Ford ever made Last edited by fordomatic; 09-05-2025 at 11:15 PM. |
#10 | |||
2 users like this post: |
SX AWD petrol full time 38/62
SY AWD petrol full time 38/62 SYII AWD petrol full time 38/62 SZ AWD diesel Haldex, will declutch when stopped to improve fuel economy. SZII AWD diesel Haldex, will declutch when stopped to improve fuel economy. No petrol SZ or SZII AWD. More's the pity. SYII is king of the Territories as it gets proper AWD and had the good ball joints at the front.
I6 + AWD |
#12 | |||
BLUE OVAL INC.
SY2, TS, AWD, BARRA, 6HP26. |
#13 | ||
Not really relevant here I know but I get annoyed by the Subaru marketing . .
Pretty sure that the manual gearbox only was/is 50/50 The slush boxes were (at least in the 2000 model I had) 30 front and 70 rear . . . marketing = never let the truth get in the way of a good story
#14 | |||
My comment was more that it was at least offered on Subaru models vs it never being an option in the Territory.
#15 | ||
I've had 4 and while I read fordomatics pain, never had one issue as listed apart from rear diff replaced under warranty.
Our current one is a 2016 built AWD Titanium diesel with 75K km...we've never gone off-road and the most I've towed with it is right on max tow rating 1600kg (tongue not h/duty hitch) and does it with ease. |
#16 | ||
Attached from my Forscan records. The bottom trace is the TOD clutch operation on my SZII AWD. You can see the engagement of the front wheels when taking off in first gear. Exactly what is required on a slippery boat ramp.
#17 | ||
the 'only' thing differant with my SX .. it has the 4.10:1 diff ratios . . for a standard motor it helps it get up to speed
#18 | |||
![]() Join Date: May 2008
SX through SY II had a permanent AWD system. That changed for SZ with the introduction of the diesel engine and Ford-build 6R80 6-speed auto. As mentioned, it was a part-time AWD system that disconnected at rest, Ford saying it was for refinement and fuel economy. There was no AWD petrol SZ, from what I gather, they rationalized AWD to the diesel to save developing a specific version for the Barra + ZF 6-speed combo, and/or not wanting to put the 6R80 behind the 4.0 engine.
The Fleet - 2016 PX MK II Ranger Cool White 2008 FG XR6 Sensation Blue 2014 FG X XR8 Emperor Red 2024 Mustang GT Race Red The Departed - 2002 T3 TS50 Blueprint 2017 Mustang GT Race Red |
#20 | |||
The increase from 2300 to 2700 presumably is due to the assist from the front axle during takeoff - reducing load on the diff?
#21 | |||
#22 | |||
![]() ![]() The unique NS layout of the boxer engine that is slung so far forward with the gearbox being a transaxle is where the symmetrical part comes in. A transverse engine/driveline can't do that.
Thread Tools | |
Display Modes | |
