Old 20-08-2006, 10:01 PM   #1
NeishaXR8_347
SS Grunt
NeishaXR8_347's Avatar
Default Jaycar Speedo corrector: Works a treat.
Hey all i installed the jaycar speedo corrector in the xr8 today and it works amazing you can adjust it up to 99% up or down, very easy mod to do, i had to adjust mine 16% slower to accomodate for the 3.9's. Cant recommend it enough tho.
Shaun.
NeishaXR8_347 is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2006, 10:09 PM   #2
SIKSIX
Its gone V
SIKSIX's Avatar
Can't reccomend it!!!
any reason?
SIKSIX is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2006, 10:15 PM   #3
SIKSIX
Its gone V
SIKSIX's Avatar
What did you set the dip switches to, and also did you put in the 1k resistor in r1 or r2?
Old 20-08-2006, 10:23 PM   #4
NeishaXR8_347
SS Grunt
lol i said i cant recomend it enough lol, meaning its great. sorry i worded it wrong.
VERY VERY GOOD MOD. lol
Old 20-08-2006, 10:35 PM   #5
8pAc
RDP #181
8pAc's Avatar
Cool i was wondering what we had to do in the aus if we changed diff ratio's to get the speedo back in order.
Originally Posted by MRJUCY
Camrys like most Toyotas have always been ugly, poorly equiped & brain crushingly dull but that's what a lot of people look for in a car unfortunately. I like my fridge, it keeps my beer cold other people like them so much they want to drive them it seems.
8pAc is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2006, 11:34 PM   #6
Hords
Treasure your balls?
Hords's Avatar
G'day Shaun,
Didn't know about this kit. Is there a part # for it. Haven't got JayCar's catalogue, but may call 'em tomorrow.
Meteorite T3 TS50 ESS
Hords is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2006, 11:39 PM   #7
santoitaliano
BF F6, APV SR3900
santoitaliano's Avatar
if anyone needs one PM me, i have one ready assembled...
Santo
White APV SR3900 [WIZZRD] (Click Here) [/COLOR]
Daily:
2006 Red BF F6 Typhoon
Bluepower enhanced.
santoitaliano is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2006, 11:42 PM   #8
NeishaXR8_347
SS Grunt
cat num/part num is KC-5380 $44.95. They also have a website.
Shaun.
Old 21-08-2006, 09:18 AM   #9
FRDGAL
GT-P #0336
FRDGAL's Avatar
I've just bought that (waiting for it to arrive) so I'm glad to hear it works.
2003 FULLY OPTIONED MERCURY SILVER BA GT-P BUILD #336
REVERSE CAMERA - SAT NAV - PIONEER SUB & AMP - SUNROOF - DVD PLAYER - CUSTOM DUAL EXHAUST
~Tuned By Bluepower Racing~
FRDGAL is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2006, 10:58 PM   #10
ClassicAU
hey, i am looking to pick up the one that santo has for offer, but he asked me to post to see what the ford settings for the dip switches and whether to put the resistor in r1 or r2 and he'll complete it for me. does anyone know what they are, or even what that means? :P
cheers
ClassicAU is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2006, 11:05 PM   #11
santoitaliano
BF F6, APV SR3900
i never actually installed it in my car so didnt really pursue the right settings for it...
there is a resistor that needs to be installed in one of two jumper locations and some dip switches that need to be set correctly in order to interpret and correct the signal to the speedo...
Santo
Daily:
Bluepower enhanced.
Old 22-08-2006, 11:40 AM   #12
xr8ute
Back on the road
xr8ute's Avatar
Shaun, have you got just the one corrector fitted between the VSS and the dash?
Have you found it has affected gearbox shift points at all? Or where the speed limiter cuts in?
Old 22-08-2006, 12:01 PM   #13
ClassicAU
i am actually looking to get an edit done on my car, and was just wondering if the speedo is controlled by the ecu and if the edit can correct it?
Old 22-08-2006, 12:07 PM   #14
jonbays
TL40 Wagon?
The edit can adjuct ecu actions that take place at a speed like speed limiter and auto transmisssion gear changes.
The edit can't change an input signal though.
Old 22-08-2006, 12:45 PM   #15
xr8ute
Back on the road
xr8ute's Avatar
From the wiring diagrams i've seen, the VSS signal goes from the (back of) trans, then to the dash, and then to the EEC.
The EEC has scalars for diff ratio, and tyre size...these are needed to interpret the signal from the VSS properly so it can calculate car speed properly (and car speed is used to define auto shift points).
You need the "edit" to change the value of these scalars in the EEC, otherwise you just put up with the difference in "car speed" related calculations.
Old 22-08-2006, 05:30 PM   #16
FRDGAL
GT-P #0336
FRDGAL's Avatar
No it can't. That's why I bought the Jaycar kit to correct it in my car, because the Edit couldn't.
Old 22-08-2006, 05:55 PM   #17
xr8ute
Back on the road
xr8ute's Avatar
Yep, that will be because the dash gets the signal direct from the VSS and not from the EEC.
Old 22-08-2006, 06:03 PM   #18
HoT-AU
06 SS Thunder Ute
Whats it do?
Ford..Holden.. Not fussed lol
HoT-AU is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2006, 06:05 PM   #19
SIKSIX
Its gone V
SIKSIX's Avatar
Neishaxr8 what did you set the dip switches to?
and what did you do with that resistor?
Old 22-08-2006, 08:49 PM   #20
NeishaXR8_347
SS Grunt
The 1k resister needs to be put in R1 and the dip switches are as follows: LK1 on y, LK3 on x.
xr8ute: I got under the car and found the White wire on the VSS and cut it and then ran to wires into the cabin for the kit, just remember which end goes to the VSS and which to the dash/ecu.
Since ive installed it, it now holds the gear longer in D, it would only hold it to 5500rpm with foot flat and in D and now it will hold the gears til 6200rpm in D. so its changed the shift point a bit.
Shaun.
Old 22-08-2006, 11:47 PM   #21
NeishaXR8_347
SS Grunt
Also i forgot to mention there is another jumper link its LK2 and can be on F for faster or S for slower and can be corrected 99% faster or 99% slower.
Shaun.
Old 22-08-2006, 11:54 PM   #22
HLC
Audi S3
can ya make it, so your speedo reads double? like 200 when you are really doing 100? cause that would be awesome!
Old 23-08-2006, 12:08 AM   #23
NeishaXR8_347
SS Grunt
Yeah you could do that, so you could make it read faster and do a timing with your mates in the car lol 0-100 in 4 secs lol.
Old 23-08-2006, 12:16 AM   #24
HoT-AU
06 SS Thunder Ute
helllo!! whats it do guys! If there anygood i might look at one!
Old 23-08-2006, 12:25 AM   #25
HLC
Audi S3
that is the best mod ever!
Old 23-08-2006, 08:38 AM   #26
xr8ute
Back on the road
xr8ute's Avatar
Yeah, that makes sense. Thats because the EEC thinks you still have 3.45 gears in the diff, and is calculating the car speed based on that (and engine rpm).
The difference between 3.45 and 3.91 is about 13% right? 5500rpm x 113% = 6215rpm...
You could put another speed corrector between the dash and the EEC to change the signal back down to normal, and the EEC would be calculating road speed again properly
...or get the edit and change the value for the diff ratio to 3.9
...or just be happy with 6200rpm upshifts, and if your making power up there, then why not ;)
Old 23-08-2006, 09:20 AM   #27
ClassicAU
so the edit can fix it? i am interested to know this as i just got my car back last night. i now have a 3.73 LSD from my stock 3.08 (i think?) and now my speedo is out by at least 15km/h
Old 23-08-2006, 09:26 AM   #28
jonbays
TL40 Wagon?
With a speedo corrector all you are able to do is correct the speedo signal which corrects the speedo reading. it can't edit the ecu change up points so they will be moved when you adjust the speedo. If you slow the speedo down by 10% then the car will rev harder 10% before changing gear.
With two speedo correctors in series one between the transducer and speedo and one between the speedo and ecu you can correct the speedo signal and uncorrect it back to the ecu. So you have the first one minus 10% to slow the speedo and the second one plus 10% to speed it back up to "normal' for thre ecu.
Old 23-08-2006, 10:33 AM   #29
Futura01
horsepower
Okay this is getting confusing!!!!!
Lets say okay i change my diff ratio from std to a lsd 3.9 ???
How would they normally adjust the speedo at a workshop ???
OR the other option is if i do this jaycar mod am i right in saying i will need an edit to adjust the shift points again ???
Help this thread is confusing at this point in time
Futura01 is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2006, 01:29 PM   #30
ClassicAU
i think i might get mine fixed with a different gear in the transmition. i have changed this before in my old EA, i think it was just a little plastic gear that goes on the side of the trans somewhere.
