Old 14-07-2010, 02:46 PM   #1
frd906
Default Ecu Query
Hey guys
My mech picked up a s1 xr6, september 98 model
Vct + 5spd, Heritage green
For wrecking
Just wondering if i was to grab the manual conversion out of it and put it in my car, if i will be able to use the ecu for the manual side of things and it will not affect any other operation of the car, also would i have to swap dashes
Not worrying about the electric windows or the fancy stuff.
Mine being a march 99 build, smartlock
cheers
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2010, 02:53 PM   #2
Mont5.0
Mont5.0's Avatar
should work, could always get your ECU flashed for manual.
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is online now   Reply With Quote Multi-Quote with this Post
Old 14-07-2010, 02:56 PM   #3
frd906
hmm should get the car running in the next couple of days so i can see how the gear box is etc cheers, will try and get photos
and yeh was thinking about mine getting flashed,
Old 14-07-2010, 03:17 PM   #4
superroo
You can't stop the signal
superroo's Avatar
Is your car a series 1 or 1.5?
Old 14-07-2010, 04:10 PM   #5
The Monty
Just slidin'
The Monty's Avatar
Wouldnt worry about using the ECU. Just get yours reflashed for Manual use. Its not like it comes with an extra 10kw or anything.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 14-07-2010, 04:30 PM   #6
Stattic
Stattic's Avatar
The vct ecu will definitely not wok with a non vct engine. Just get ford to flash your correct ecu
Current
Blueprint 03 xr8
5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives
256rwkw
BA manual Typhoon
Fully optioned, 340rwkw@16psi (thanks Bluepower)!
The old ride....
AU Fairmont, cammed beast, R.I.P you made my p plate years bearable!
150.8rwkw courtesy BPR
Stattic is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2010, 04:45 PM   #7
sleeper393
sleeper393's Avatar
Question
Originally Posted by frd906
Hey guys
For wrecking
cheers
hey off the subject , did you know a doreen langham from jimboomba ?
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak!
AU SERIES 3 LIQUID SILVER
BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS
123.4 GROUND TEARING RWKW'S , LOL
sleeper393 is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2010, 07:03 PM   #8
frd906
No i dont no who that is,
Cheers guys reason i wanted to use the ecu was so i can use the manual, saving me going to ford and getting it reflashed,
But looks like the better option unless i just shove the manual and vct engine in, then ill do the whole swapys of dash etc
Cheers guys
Old 14-07-2010, 07:33 PM   #9
The Monty
Just slidin'
The Monty's Avatar
Why do you need to swap dashes? Only reason it would be worthwhile doing a dash swap is to go to Fairmont/Ghia Dash.
Old 14-07-2010, 07:51 PM   #10
frd906
well if i opted to run power windows my forte dash dont have the connections for the power windows
Old 14-07-2010, 08:54 PM   #11
brad`
The Monty
brad`'s Avatar
it should the only diffrence between the xrs and the forte as far as i know is that the spedo cluster is diffrent... all the wiring for the windows and all the rest should be there, well i know in the fairmont i have all the wiring for the door lights and amp and crap even tho it doesnt come with it...
couldnt see ford spending extra money to make the wiring with and with out
brad` is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2010, 09:02 PM   #12
frd906
Nope it aint there, i changed my couple of my doors ages ago at huggies bears house and we looked and couldnt find nothing, i think it was a option on the fortes
