Old 23-04-2015, 02:48 PM   #1
pansy99
Default Leaking Water
My 1999 festiva has had a leak since I purchased it over 3 years ago. I'm sick of driving with a pool of water under my feet. Would anyone have any idea where the water could be getting in? I've poured water down the vent near the wipers and it comes out near the wheel so it's not that, and the windscreen has been replaced since purchase, with the person who put it in checking for leaks so it's not that either. I'm out of ideas, as is my mechanic friend. Any ideas? I dread driving it in the rain, and with the torrential rain we've had in Sydney the past few days, my car stinks! Thanks in advance.
pansy99 is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2015, 02:53 PM   #2
Peter B - CV8
Default Re: Leaking Water
You might need to get the car up on a hoist & check out the (under) floor pan area/seams etc for any obvious gaps. Might be spray from the road pushing through a gap etc.
Peter B - CV8 is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2015, 02:57 PM   #3
pansy99
Thanks for that. It isn't coming from underneath as it leaks just parked in the driveway. I will get my friend to have a look though.
Old 24-04-2015, 02:24 AM   #4
Franco Cozzo
Franco Cozzo's Avatar
Heater core?
Old 24-04-2015, 12:43 PM   #5
Is the car's air conditioning condensation drain blocked? Does it smell like coolant or water? Leaking heater core will smell (and taste) of coolant.
Also check this out: http://www.fordownersclub.com/forums...nger-footwell/
where the hinge area is on the drivers side, look to the left and there is a small seam that is not filled up correctly, the water runs into that, fills the pillar with water flooding your car with water
Check out the whole 3 pages of that thread as it points to other leak sources in Ford's mobile shower car series :-)
Old 24-04-2015, 06:08 PM   #6
mikeob
If it is coolant leaking then you are probably up for a new heater core and that could be a big job, as in dashboard out.
mikeob is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2015, 06:15 PM   #7
pansy99
It is leaking water, not coolant, and only when it rains. I had a good look today and found a plug thing along the floor that had a hole in it so replaced that. I also noticed that there is a cap missing on the strip at the bottom of the windscreen, but poured water down that and it didn't go inside the car, so I doubt it's that.
Thanks for the help everyone. It isn't that important if I don't find the problem, as I've driven the car for over 3 years like it, and hope to upgrade soon.
