Old 27-04-2018, 01:23 PM   #1
stefcio007
Exclamation Rear number plate...screws
My rear number plate screw was becoming very loose so I decided to take it out and investigate.
Turns out screws are not what should be used for the rear. The rear holes have bolt threads. I simply found the right bolt in the shed and it threaded perfectly and secured my number plate like it should have been done in the first place.
Is this the dealer being lazy?
I think for the front plate only you use screws so that it can tap into the plastic. Thought I might post to see if anyone else came across this.
2020.25 Focus SA ST-Line Wagon + DAP
2011 Focus LW Trend (Diesel) [sold]
2006 Territory SY Ghia (AWD)
stefcio007 is offline   Reply With Quote Multi-Quote with this Post
Old 27-04-2018, 03:18 PM   #2
Victor1
Default Re: Rear number plate...screws
The screws in mine were to long and were so close to touching the paint that I filed off the tip of the screw otherwise if the plate was flexed up it would've marked the paint.
But I too have had loose plate issues twice now.
I'll have a closer inspection next time.Thanx.
Victor1 is offline   Reply With Quote Multi-Quote with this Post
