Old 14-01-2020, 11:19 PM   #1
car10002
Default tow a van
hi everyone.
was wondering what sort of larger trailer would be close enough to a van in size and weight would a car trailer be close enough or would you need furniture trailer.
want to start towing a van and as still dont have a van you got to work around it and at moment only way is hire a larger trailer as no one has a van that cars rated to tow.
finally got the transmission cooler put on the ba.
am as most of you know are building trailer and got to hire a car trailer to take the old chassis away and wondered wether a car trailer with a old chassis loaded on is close enough to a van.
even if you hired a car trailer and either had it empty or found something else to load would that be close enough.
want the ed soon as so vans got to wait but when that happens am building one that looks like the old viscount duralvan but have newer tech that newer ones have.
thanks
car10002 is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2020, 01:12 AM   #2
73 4V XB
Frankenford pilot
73 4V XB's Avatar
Default Re: tow a van
Originally Posted by car10002 View Post
hi everyone.
thanks
A tandem trailer can weigh anywhere between 500 and 1000 kg depending on the build/carrying capacity. If you want to substitute a tandem for the average weight of a van you would need to put a car on it, not just a chassis. A van, once it’s fully built can weigh anywhere from 1500 to 3000 kg depending on length, materials used and what mod cons you have.
Cheers Bretto
73 XB GT
Last of the Big Ports
73 4V XB is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2020, 01:24 AM   #3
car10002
a goof car trailers about 750-800kg unloaded and a box trailer is about 200kg normally plus obviously the spare tyres on the hire trailer too, would a tonne for all that sound right.
a medium van would be about 1000-1500kg probably depending on what you got. what would be close enough.
would the current radiator in the ba be ok until it goes then get a bigger one now that the transmission coolers on
Old 25-01-2020, 06:06 PM   #4
Crazy Dazz
WTF?
You don't own a caravan?
And so because you don't have a caravan, you feel the urge to tow something else?
Are you trying to test your car's performance as a tow-car? Is that it?
So you want something to approximate a Caravan?
IMHO, the biggest issues in towing a van are:
1) Braking. Unfortunately you can't really trial this, because most hire trailers will have illegal and usually non-functional over-riders.
2) Weight Distribution. By law you're only supposed to have 10% of te weight on the hitch, but if you have to choose, more is better than less. Vans can be rebalance by moving water tanks, gas bottles, and spare tyres. It can be hard to re-balance a car on a trailer, as you only have tow choices.
3) Side Winds, including those caused by passing trucks. A large covered furniture trailer would give you your best approximation of this, but they're smaller than most vans.
4) Drag. Most people think in terms of power to weight, but at highway speeds its the drag that kills you. Again, a tall covered trailer would be the best approximation.
Time to Make the Hippies Cry Again
Old 25-01-2020, 09:19 PM   #5
car10002
Want to have the chance to tow one and don’t have a van so got to come up with something close for now
Old 25-01-2020, 09:20 PM   #6
car10002
It’s only since having a better car you can think about doing that and many other things
Old 29-02-2020, 08:21 PM   #7
car10002
Hi
Want to have the chance to tow a van and don’t have one so got to come up with something close for now, would a car trailer with stuff in it be close enough to a medium size such as a vintage viscount or millard and have same effect.
Most of you probably know that it’s only since changing to the ba as a daily car that you can start thinking about things
