Old 23-11-2011, 02:33 PM   #1
brownieXR8
brownieXR8's Avatar
Default Maybe I've gone mad...
Over the weekend I changed plugs (BPR6EFS-13), Leads (Eagle Eliminator), coils (MSD) and cam sync. Now for some reason, and maybe it's in my head, but my exhaust seems to have gotten a drone at highway speeds...
Is this even possible? I wouldn't have thought so. The car has standard extractors and cats, but I think has an aftermarket cat back (I've not seen an factory exhaust, so can't be 100% sure).
On a side note, plug 5 is a real pain in the butt to get at. I assume this get worse with after market extractors?
HIS: AU III XR8 220, 5 speed manual, short shifter, MSD coils, ACRON CAI, Front 330mm brakes with C4 calipers and braided lines
HERS: BA Fairmont, vapour injected LPG
I reject your reality and substitute my own!
brownieXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2011, 02:39 PM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Default Re: Maybe I've gone mad...
cam sync - as in the cam that opens and closes the exhaust valves?
It's entirely possible.
Old 23-11-2011, 02:49 PM   #3
brownieXR8
brownieXR8's Avatar
Cam sync was squealing when cold, as is not unusual from what I've read on here. Unless the sync wasn't functioning at all, surely that wouldn't have an effect on the valves opening / closing. And yes, it was removed and installed with cylinder 1 at TDC and all lined up the same going in as it came out.
I should point out this is on the XR8 220 in case that wasn't clear.
Old 23-11-2011, 06:26 PM   #4
Sox
RIP...
Sox's Avatar
I would suspect it's all in your head.
Oval Everywhere...
Old 23-11-2011, 07:51 PM   #5
FGII-XR6
FGII-XR6's Avatar
I think he means he changed the camshaft position sensor that goes in the hole where the distributor would go
[SIGPIC][/SIGPIC]
Rides:
Old 23-11-2011, 08:09 PM   #6
Peuty
Afterburner + skids =
Peuty's Avatar
With Pacies it gets harder, but it's not impossible. Socket with a ring spanner does the trick.
Oo\===/oO
Old 23-11-2011, 08:35 PM   #7
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice.
Yes it is possible, you have just change components that effect how well the engine run's and its overall tune.
The drone being a result of now running better and smoother, aka more consistant firing of all cylinders.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2011, 10:47 PM   #8
b2tf
not here much anymore
b2tf's Avatar
Add in lots of swearing. With difillippos it is a real PITA.
RAM 1500
Old 24-11-2011, 02:56 PM   #9
brownieXR8
brownieXR8's Avatar
Yeah, that's the one. Couldn't remember the exact name of it.
There was already plenty of that. Had to go searching for a socket with a hex on it and then go to the old man's to get a spanner...
While we are on the subject, does anyone have a pic of the factory cat back?
Old 24-11-2011, 03:02 PM   #10
Peuty
Peuty's Avatar
No you got the name right. It was the 6cylinder owner that was confused!
Oo\===/oO
Old 24-11-2011, 03:38 PM   #11
needaXYGT
AU II XR8
needaXYGT's Avatar
I used a normal short socket so it would rub against the header and welded a handel to the side of the socket. worked well.
AU XR8 II ute
XD FAIRMONT GHIA 302
XA FAIRMONT 302 TOPLOADER
needaXYGT is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2011, 04:33 PM   #12
Mr Hardware
sigh.
Old 24-11-2011, 06:01 PM   #13
FGII-XR6
FGII-XR6's Avatar
I knew what the correct name was but was trying to explain the function of it
[SIGPIC][/SIGPIC]
Rides:
