02-01-2011, 07:06 PM | #2551 | ||
i still don't see it, are they parked in the middle of the road?
02-01-2011, 07:19 PM | #2552 | |||
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red. Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White. |
02-01-2011, 07:27 PM | #2553 | |||
the line markings give it away...
You've seen it, you've heard it and your still asking questions?? Don't write off the Goose until you see the box going into the hole.... |
03-01-2011, 05:28 PM | #2554 | ||
03-01-2011, 05:52 PM | #2555 | |||
Up for sale is my pride and joy! I purchased the corona 14 years ago of my Nan, who purchased the car new from Toyota in 1986. This car has been in my family since new and has cost me over $100,000 to get it to where it is today. There literally isn't a part of the car that hasn't been modified. There isn't a mark, dent or scratch on it! That's also the main reason for the sale. I have invested so much of my life making this car perfect, I can't bear to drive it. The custom turbo charged engine, hasn't even got 5000klms on it yet! PHOBIA was featured in Issue No.152 of Hot4's including a cover shot. Made the top 5 in Zoo 2010 Car of the Year & has done very well in the shows entered! PHOBIA is currently insured through Shannons for $25,000, has full registration, and has never had any problems with the police in the 14 years I have owned it! Full Specs... Car 1986 Toyota Corona RT-142. Engine Hardware 22R-E 2.4L Custom Turbo. Engine Accessories Ceramic coated Garret GT30/76 turbo, Tial 38mm external wastegate, HKS SSQ blow-off valve, GReddy oil catch can, custom front-mount intercooler, Blitz DSBC electronic boost controller, Motec turbo timer, custom ceramic coated turbo manifold, custom duel fuel rails, four Group A secondary injectors and four 22R-E injectors, Altronics injector driver, Bosch 044 Fuel pump, 75mm custom throttle body, Earls braided lines, Delco programmable engine management, Delco ignition, ported and polished head, machined receiver groove, 2mm copper head gasket, O-ringed block, custom dished forged pistons, re-grounds 272deg cam, adjustable cam gear, oversized valve springs, re-drilled water jackets, custom water pump housing and pump, custom alloy radiator, 16" thermo fan, custom 3" ceramic coated dump pipe, 3" Hi-tech Exhaust. Driveline hardware Supra W58 five-speed manual, Exedy Five-puck button clutch, Fidanza Aluminium Flywheel, MA61 LSD in an F-series IRS diff. Bodywork White base coat with House of Kolor Green Ice Fleck, full side vinyl graphics, custom front and rear bars, molded matching side skirts, custom bonnet, shaved aerial, window washers and wipers, de-badged, side moldings removed, colour coded everything, laser cut polished stainless steel wheel trimmings. Brakes and Suspension Four-wheel disc brakes, bendix high-temp pads, high-pressure race fluid, custom four-way independent airbag adjustable suspension with Koni dampeners and custom strut tops. Rolling Stock 18x8 inch NK07 Trilogy S2 wheels, 215/35 Falken GRB **451 tyres with white walls. Interior Gadgetry MY99 WRX front seats, full beige leather re-trim, custom door pods and pleated leather inserts, custom A pillar tweeter pods with in-built Carbon Series Auto Meter boost and volts gauges, Auto Meter Carbon Series Tacho and Temp gauges, glovebox-mounted switches and gauges for the airbags plus external switch box, boot-mounted floating air tanks, dash-mounted boost controller and turbo timer, carbon-fiber pedals, Momo gearknob, colour-coded leather wheel, colour-coded centre console and punched aluminium floor mats. Stereo Components Kenward KDC PS911R motorized head deck, Boston Acoustics 6.5in front splits, and 6.5in three-way rear, alpine V12 four-channel amp, two Soundstream SPL 12in subs in a custom sealed enclosure, Soundstream Reference 500 two-channel amp, Optima D34 Yellow Top battery, all Jaycar heavy duty cabling and gold plated terminals. Please feel free to ask any questions you may have about PHOBIA. There will be no test pilots or joy flights, but I do encourage any inspection. I have full photographic evidence of all parts that can't be seen. Including the entire build! Please note. I'm not chasing cash, nor am I in a rush, so no crazy offers please. Having said that, I am open to swap or trade, with cash adjustments either way! Any E46, E90, IS200, S15, R34 or WRX would get my interest, but im open to all offers. |
03-01-2011, 06:33 PM | #2556 | |||
RAGE Engineering
If it doesn't fit, use a BIGGER hammer |
03-01-2011, 06:41 PM | #2557 | |||
3..2..1..
03-01-2011, 07:22 PM | #2558 | |||
[Moto] Darkness Black - Hornet 900 [Daily] Molten Orange - '14 WZ Fiesta ST - Team Dynamics Pro Race 3 Wheels - Bluefin Stage 1 - Resonator Delete - Stubby Antenna [Weekender] Winter White - '06 BF XR6 Turbo - 6spd ZF A/M - Leather - D/Zone Climate - BF XR 18's Headlights don't work in your B Series? Here's how to fix it! |
03-01-2011, 07:31 PM | #2559 | ||
Browsing here and there..
It's still a 1986 Toyota. People have more money than brains!
03-01-2011, 07:38 PM | #2560 | |||
Doesn't stop people (myself included) spending money on family barges.
03-01-2011, 07:49 PM | #2561 | ||
HUGH JARSE
03-01-2011, 07:53 PM | #2562 | |||
03-01-2011, 08:22 PM | #2563 | |||
03-01-2011, 08:39 PM | #2564 | ||
03-01-2011, 08:59 PM | #2565 | ||
Making superman jealous
I would not say the volvo above is a fail just someone prob a backpacker or a kid injecting some personality into his ride the best way they can
If life deals you lemons dont complain just get on with it and make lemonade 2006 SY Territory Ghia AWD in ego with roof mount DVD, tints, 7 seats, iPod input 2005 Crewman Cross 8 with 350 cubic inches, AWD, black on black rims on black leather, tints and polished racks NEW TOY Bayliner 185, inboard 3L 4 cylinder pushing us along at 50MPH whenever i get a chance I love Aussie cars and are gonna really miss them soon....... |
03-01-2011, 09:28 PM | #2566 | ||
That Corona is quite obviously well engineered or appears so, its all neat work.
It looks comprehensively awful. |
03-01-2011, 09:53 PM | #2567 | |||
Oo\===/oO
04-01-2011, 12:48 AM | #2568 | |||
Had Rep of GT-HO. Legit.
And they are one of the few rice cars i freakin love!!
I'm back! Finally. |
04-01-2011, 03:46 AM | #2569 | |||
Constant annoyance
GT Club - no longer for ford enthusiasts, now for fat old men who need air con and power steering for the maccas drive through. |
04-01-2011, 05:20 AM | #2570 | |||
04-01-2011, 10:26 AM | #2571 | |||
They are cheap to find parts for too and they look awesome
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery! Insta@mooneye_ghia White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly |
04-01-2011, 11:50 AM | #2572 | |||
Constant annoyance
04-01-2011, 12:12 PM | #2573 | ||
Its not just the looks, its the fact its an AE86, its got rep, and just looks like a drift pig.
me rike em rots an rots
04-01-2011, 12:13 PM | #2574 | |||
04-01-2011, 12:19 PM | #2575 | ||
The Thread Killa
They've deservedly become a cult car; I wouldn't mind having one.
"It is the mark of an educated mind to be able to entertain a thought without accepting it." - Aristotle |
04-01-2011, 12:22 PM | #2576 | |||
04-01-2011, 12:25 PM | #2577 | |||
3..2..1..
04-01-2011, 10:46 PM | #2578 | ||
one sore bore...now 13.4
This guys been trying to get rid of this for ages....cant imagine why it's not selling?
http://cgi.ebay.com.au/ford-xm-ute-/...item2a0d0d5867 |
04-01-2011, 10:51 PM | #2579 | ||
Oo\===/oO
7g for a V8 engineered Xm, not bad...I'd have to return the body to stock though...
04-01-2011, 11:54 PM | #2580 | |||
