30-04-2006, 05:40 PM | #211 | ||
The Vengeful One
Will anything like these becoming out for EA-ED??
30-04-2006, 05:41 PM | #212 | ||
BA XR6
Honestly with the reflector painted, i reckon it'd look better.
Phantom BA XR6 Falcon |
30-04-2006, 07:02 PM | #213 | ||
XRR83D
So those of you that have these lights already, is it worth the risk putting them on?
2003 BA XR8 Falcon - Lightning Strike Mods: 18" GT's (Aftermarket), BF GT front end(FibreSports), Tint, Premo Sound, Leather, CAI, DBA slotted, 2007 Suzuki Swift - Pearl Red Povo Pack |
30-04-2006, 07:23 PM | #214 | |||
Bring on the lion...
El falcon, 4.0, XR6 camshaft, pacemaker extractors, 2.5 inch exhaust with tri flow sports muffler, AU TE50 intake, with K&N panel filter, Advanti racing Stalker 17" rims, Sitting on Ultra Low King Springs, 'Gabriel' Ultras Lowered struts, NOW MANUAL, 3.45 LSD 9.694 @ 75.38 MPH at Mildura Drag Strip 1/8 Mile XC Falcon project car underway...... |
30-04-2006, 07:50 PM | #215 | |||
_Oo===oO_
They'd look better as well, u need SOME color on there. Looks like I might be getting a set after all! |
30-04-2006, 07:52 PM | #216 | ||
windsor user
there is a red tint paint - like there is the black tint.....
give it a try.... but before fitting them, just make sure it does actually reflect red...... it should do though |
30-04-2006, 08:00 PM | #217 | ||
_Oo===oO_
Got any daytime pics DRHEMI?
Anyone got pics with the brake lights/indicators going? |
30-04-2006, 08:05 PM | #218 | ||
Aspiring mr efxr
wot about the wagons? i doubt they r made but if they were anythin like that id get a set. right after i do my bit for speed camera revenue!
30-04-2006, 08:07 PM | #219 | ||
windsor user
they havent got full clear tail lights out for the wagons, but just grab some EL Wagon tail lights.....they have a clear indicator rather than the amber one
30-04-2006, 10:52 PM | #220 | ||||||
OzEcruisers PRESIDENT
[HTML]http://www.fordforums.com.au/showthread.php?t=46672[/HTML] Quote:
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan PROEF 13.46 @ 105.78mph Tuned by DYNOMOTIVE 200BUX - AFF Drag Nats 2019 EF Wagon
30-04-2006, 11:46 PM | #221 | ||
BLUE OVAL INC.
I think they look ok but i reakon they would look better if they were yellow like ef headlights :
01-05-2006, 06:04 PM | #222 | ||
XRR83D
THe risk of being defected....smarty...lol
01-05-2006, 08:09 PM | #223 | ||
You run thats risk if you have taken your factory fitted mud flaps off :
01-05-2006, 08:19 PM | #224 | ||
Last warning
find me where mud flaps are required on sedan's with low ground clearance
i think you'll find they're more a requirement for higher cars like 4wd's etc.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
01-05-2006, 09:38 PM | #225 | |||
02-05-2006, 01:26 PM | #226 | ||
Last warning
while i do beleive this could be very possible requirement, i'd like to see some kind of document stating this is required, i wonder if there are exceptions or even requirements to 'replacements'
02-05-2006, 01:32 PM | #227 | ||
Girrrrr!!!
Something about spray suppression...
BTW. My lights haven't arrived yet, hopefully there is a little bit of paper in the letter box today to pick them up
Falcon EF XR6 in Heritage Green Heritage green, isn't that a fence paint? |
02-05-2006, 01:36 PM | #228 | ||
Girrrrr!!!
Traffic Operations (Road Use Management) Act.
22 Mudguards and spray suppression (1) A vehicle must have firmly fitted-- (a) a mudguard for each wheel or for adjacent wheels; and (b) for each axle group and single axle on a vehicle that is part of a B-double, spray suppression devices complying with Parts 1 and 2 of British Standard AU200-1984 Spray Reducing Devices for Heavy Goods Vehicle. (2) However, subsection (1)(a) does not apply to a vehicle if-- (a) the construction or use of the vehicle makes the fitting of mudguards unnecessary or impracticable; or (b) the body or part of the body of the vehicle acts as a mudguard. Examples for subsection (2)(a)-- 1 pole-type trailers used to carry timber 2 most road-making plant 3 some agricultural equipment (3) A mudguard fitted to a vehicle with a GVM over 4.5t must, when the wheels of the vehicle are in position to move straight ahead-- (a) reduce the danger of a person contacting the moving wheels; and (b) for the rear wheels-- (i) cover the overall tyre width of the wheel or wheels to which it is fitted; and (ii) be fitted so the height above ground level of the lowest edge of the rear of the mudguard is not over one-third of the horizontal distance between the edge and the centre of the rearmost axle. (4) However, a mudguard may be up to-- (a) 230mm above ground level; or (b) if a vehicle is built to be used off road--300mm above ground level. (5) The outside of a rear mudguard, other than a mudflap, of a vehicle that can be seen from the rear of the vehicle must be coloured white or silver if the vehicle-- (a) is at least 2.2m wide; and (b) has a body the vertical measurement of which is under 300mm at the rear, measured from the lowest point of the body above ground level to the highest point; and (c) is not fitted with rear marking plates in accordance with section 106.22 (6) For subsection (5)(a), the width of a vehicle is measured disregarding any anti-skid device mounted on wheels, central tyre inflation systems, lights, mirrors, reflectors, signalling devices and tyre pressure gauges.
02-05-2006, 01:36 PM | #229 | ||
Last warning
Yeah, i know why they're used, but as i said, i was under the impression it was more for higher cars, i'd simply like to see the requirements
02-05-2006, 01:36 PM | #230 | ||
Girrrrr!!!
02-05-2006, 01:38 PM | #231 | ||
Last warning
cheers
02-05-2006, 01:40 PM | #232 | ||
Girrrrr!!!
Welcome
02-05-2006, 01:43 PM | #233 | ||
Last warning
For victoria:
hxxp://www.parliament.vic.gov.au/rsc...20Part%20A.htm Mudflaps are not normally required on passenger car type vehicles. However, mudflaps must be in place on vehicles where they form part of the wheelguard system such as on some motor bikes, heavy vehicles and vehicles with a tray type body. For passenger cars the tyre section width at the top of the tyre must be covered when the wheels are in the straight ahead position. For motorcycles, side cars and trikes, guards must cover the tyre section width.
02-05-2006, 01:44 PM | #234 | ||
Girrrrr!!!
Must be different from state to state.
02-05-2006, 01:50 PM | #235 | ||
Last warning
Yeah, heaps of the road laws are.
we discussed earlier the requirements of the lights from state to state, its ridiculous to have different laws a mere 1000km's from one major city to the next.
02-05-2006, 02:02 PM | #236 | ||
Girrrrr!!!
Well until I get pulled over and defected I won't be sticking reflectors or tinting or anything...
I can't see them as being dangerous either.
02-05-2006, 05:41 PM | #237 | ||
[EBGLT]
The moment you post a pic darren you will have 10,000 e-series drivers there you should have bulk buyed!!!!!!!!!
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
02-05-2006, 05:41 PM | #238 | ||
back to the shop........
apart from all the drama these lights. i recieved mine today and they look insane. will post up pics when i get some :1syellow1
Bow to the turbo |
02-05-2006, 05:42 PM | #239 | ||
Last warning
he's already posted pics man :P
02-05-2006, 05:42 PM | #240 | ||
Girrrrr!!!
Got my tail lights today, very happy with the quality of them, very well packed, unfortunatly no time to install today, will put them on tomorrow.
