29-05-2015, 11:54 AM | #61 | ||
I don't think anybody is really going to argue against the Camry being well screwed together, or being able to function as they are intended to do.
But, by and large, people who are passionate about cars don't like Camry's. They want something with an x-factor, and the Camry lacks that in spades. |
29-05-2015, 11:59 AM | #63 | ||
Mate had one when I had a MkV GTI (DSG). Marginally quicker, and the GTI was a 6.8sec car. The Aurion was no 5sec car... I had a Megane RS250 which was only just a 5sec car, and there was daylight between that and my GTI.
29-05-2015, 12:28 PM | #64 | |||
Over time, roof trim fell down- required total roof trim rebuild, trim in door panels are failing, rear suspension needed rebuild under 110,000, front suspension needed rebuild, engine mounts broke and needed replacement, the engine rocker etc gaskets leak and engines notorious for leaking oil .... At present sounds like it has a super with fan slippage caused by oil, will deal with when replacing timing belts.. Oh yes- fun having to replace timing belts every 100,000 and handing over $$$$ Changing rear 3 spark plugs under manifold requires removal of manifold and more $$$ Toyota not a patch on Honda quality and reliability I got with my Honda Euro...
Ford Rides: Ford Fiesta ST Mk 8 -daily- closest thing to a go kart on road for under 50K FG X XR8 smoke manual - Miami hand built masterpiece by David Winter, BMC Filter, JLT Oil separators, Street Fighter Intercooler Stage 2, crushed ball, running 15% E85 and 85% 98- weekender |
29-05-2015, 12:34 PM | #65 | |||
Show me an AU that isn't riddled with problems either.
2023 F150 Platinum v8.. MY18 Mustang GT Magnetic... 2023 BMW 530D |
2 users like this post: |
29-05-2015, 12:49 PM | #66 | |||
The rear suspension needed a rebuild prematurely, as did the front shocker replacements. These aspects did not occur in the 16th year, but occurred prematurely, as did the engine mounts which went at about 200,000. Simply put I am not impressed with Toyota quality in terms of the ancillary stuff, although I cannot fault the engine/gear box, which has been bullet proof aside from the oil leaks and costly ongoing maintenance required in terms of timing belts/spark plugs.
29-05-2015, 12:58 PM | #67 | |||
Try comparing a 16 year old kia or hyundai against a current model, they have come ahead in leaps and bounds in all areas from 16 years ago. |
29-05-2015, 01:11 PM | #68 | ||
yea and the Hoodling is perfect on the AUs. My old AU Forte II had that problem. i wasnt arsed fixing so it was held up with thumb tacts. My AU series 2 XL utes hood linings starting to go at the moment. My Mates AU Fairmont Ghia's been dangling down for years at the rear and I am very sure many people on here with AUs have encounted that problem as well at some stage....
29-05-2015, 01:23 PM | #69 | |||
29-05-2015, 01:37 PM | #70 | ||
Those Aurions are light and have a big engine. Power to weight ratio is 135kW per tonne. XR6 is 115 and XR6T is 156. Even Megane RS is 141 . So it is a Camry on steroids .
29-05-2015, 01:50 PM | #71 | ||
Not of the Sooty variety!
Toyota could make a Aurion that runs into the 4's and the only way I'd still only buy one, would be if I was buying one for my grandfather. ;)
As much as it pains me to say this, they aren't as slow as you'd think (nor as fast as the owners think). Fit and finish is pretty good, but that's about as good as it gets. Handling is pretty ordinary for mine, but I'm sure that as most of them would spend their lives 15-20kph under any speed limit, you wouldn't notice the handling anyway. That being said the older I get, the more attractive they are looking (which gives you an idea who is their target market).
"To be afraid is to be alive - to act against that fear is to be a person of courage." Current
The Toy: 2002 AUIII TS50 The Daily and Tow Vehicle: 2016 VW Amarok |
29-05-2015, 02:13 PM | #72 | |||
on toyotas i have noticed late models appear to use the same ones that i have in my 1990 lexus, and let me tell you they just dont give trouble .... unlike some other brands, even my young brothers 84 cressida windows still go up and down fast. there is a reason people buy these so called white goods , in general they dont spend hardly any time at all in workshops getting stuff done that should not need too. the other thing i like about toyota`s is the attention to detail, unless you actually own one you dont always see the finer points. while my antique beat up LS400 which was about middle of the LS400 range it still has electric seat belt height adjusters , air bag suspension, a second lock and key on the inside of the car to keep people away from your valuables in the boot while the valay or mechanic has your car, 12 way electric drivers seat, passenger is electric too ... but not as flash, plus seat memory. third sun visor above the rear vision mirror. auto locking doors after 20 kph standard first aid kit standard basic tool kit . the heater fan on at full throttle you can hardly hear it, and it works like a beauty. tailshaft damper hydraulic cooling fan.... you cant hear it nitrogen charged brakes steering damper i could go on . And this is just a basic version of the luxo model, and some of the quality tech on this old car is still craps on many high end cars on the road today. there is a lot to like about the way they put cars together imo. |
29-05-2015, 02:28 PM | #73 | |||
Although some Wheels times haven't been too fast, the Aurion's 6.1 second time on the test that XR6 Martin mentioned was pretty quick, but 13 degrees and (apparently) a light driver should have helped. But they are fast and perhaps under 6 might be possible I guess, but of course it comes back to the accuracy of the speedo. |
29-05-2015, 02:41 PM | #74 | |||
200kw front wheel drive is more like 165kw to wheels where falcon 195kw at motor is likely 145kw at rear wheels. Add to that the car is lighter. Last edited by HULK_I6T; 29-05-2015 at 02:53 PM. |
3 users like this post: |
29-05-2015, 02:45 PM | #75 | |||
LS was start of Lexus brand and competing against S class , XJ AND 7 series - so it had to be good . |
29-05-2015, 02:50 PM | #77 | |||
so did you own a Honda at the same time regardless of its condition its a 16 year old car and should not be compared to any new car.
______________________________ 2015 Territory Titanium RWD Diesel - SOLD 2016 BMW X5 xdrive 30D Msport Seadoo Challenger 210SE 310HP |
29-05-2015, 03:02 PM | #78 | ||
29-05-2015, 03:10 PM | #79 | |||
Petro-sexual
If you want to bring 'facts' in to it please go and get actual facts. Don't just drop in a "likely" to cover yourself, while trying to mislead. |
29-05-2015, 03:28 PM | #80 | ||
I cant speak for the aurion but we have a 04 v6 camry that has been absolutely flawless, in the 11 years of ownership has never failed, nothing has broken, interior is still excellent.
and this car lives outside in the hot sun in summer, and the wet cold winter and it does get a flogging from time to time, lol it doesn't get washed or detailed. just serviced as required.. while its not the best looking, best handling or even fast, it would have to be the best built and most reliable car ive ever seen.. although we are about to get rid of it to buy a aurion, hopefully the aurion will be as good as the camry.. |
29-05-2015, 04:14 PM | #81 | ||
29-05-2015, 04:36 PM | #82 | ||
Thailand Specials
29-05-2015, 04:56 PM | #83 | ||
Petro-sexual
Yes, they do have less losses, but the numbers spruiked after are what concern me.
AKA: Not worth the paper they're written on, and always embellished to suit. |
29-05-2015, 05:18 PM | #84 | |||
It already went through that....survived, moved on......but now it's back. Amazing |
29-05-2015, 05:21 PM | #85 | |||
Many baulked at my claims of Aurion doing 5s in the 0-100 sprint.. I placed up video to prove it.. These facts are not that difficult to digest. do your research. |
29-05-2015, 05:25 PM | #86 | ||
I’m in my 70’s and I have a lot of friends who own various models of the Camry and they do everything that is asked of them.
Pick up a prescription, Thursdays at the bowling club, Sundays at Church if it isn’t too early, park across the bays at Coles Carpark, Sunday drives any day of the week, they go forwards and backwards, scrape along gate posts and bollards and a place to store a hat just to name a few. My friends believe they are one of the most versatile cars ever and they look great in white.
Smile - I dare you |
11 users like this post: |
29-05-2015, 05:31 PM | #87 | |||
Petro-sexual
Let's get something straight.... The video you posted is useless. You do not even get the needle to 100, and with the accuracy of the speedo, you're likely to have only done a 0-90 sprint. |
29-05-2015, 05:32 PM | #88 | ||
Lol you really have to give credit. After all this time you still know how to suck everyone in. Still quicker than I thought they were.
29-05-2015, 05:32 PM | #89 | |||
Petro-sexual
It came back to a "bag the troll" thread because the troll re-appeared. |
29-05-2015, 06:04 PM | #90 | ||
having driven both an Aurion SX6 and FG XR6 (non turbo) I honestly think the Aurion quicker then the FG it seemed more responsive. where as the Falcon had the better ride and handling
