Old 19-12-2007, 10:23 PM   #61
tuffnc
aka SHY4D aka Patty
tuffnc's Avatar
Originally Posted by Mr_4.0
3.45's in your ef fairmont? u must of put them in did you? i thought fairmonts only had 3.23's? even the LSD ones.......
im pretty sure they were standard. but anyway, 3500 stall gets popped in tomorrow...yummy!
tuffnc is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2007, 01:17 AM   #62
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
where and how much for your 3500rpm stall patty? i was wanting to do the same this to mine. only have had one quote so far.
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw)
2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned)
Mr_4.0 is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2007, 04:22 PM   #63
Big540
Big Block All The Way
Originally Posted by BROCKYB8
mief that is a turbo one that you are talking about and he is not in the 9's
also there is the mock car doing 10 flat
Yes it is turbo now, back then it was N/A with a Motec M800, T5, and 3.9 gears and went 13.2
Then it was on NOS 12.2 with the T5 with 250 ish rwkw
Then went 11.8 with the same tune and a C10 and transbrake
Now it has the turbo with 380rwkw and has gone 10.0
and yes I have seen this car on the dyno, so I have no reason doubt the power it is making and I think the time speek for them selves.
Big540 is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2007, 07:28 PM   #64
tuffnc
aka SHY4D aka Patty
tuffnc's Avatar
dominator with lock up....im going through ronnie at geelong engine replacement services and it'll be in by lunch time friday!
Old 28-01-2008, 09:28 AM   #65
Stav
Smile
Stav's Avatar
Originally Posted by Grechie
last night i went to calder, in the heat, it was doin 14.5's with 100mph over the line with 2.4 second 60 footers, its got it in her, but i need bigger tyres, i have only ****ant 205s
last time i went with 155rwkw i was doing 14.43 with 96 mph and 2.1 60 footer
Just saw this..Well done mate 100mph indicates around 180 rwkws on that run and capbility for a flat 14 second run.Btw the au injectors from memory max out at 180 rwkws so keep an eye on the a/f ratios to avoid a leanout.You need some mickey tompson et streets and you will get the 14 seond pass.
Old 28-01-2008, 02:31 PM   #66
3.9from hell
hoons cause global warmin
au injectors are the same as eseries ones
19lb
"if you believe you can, or believe you cant, your probably right" (henry ford)
3.9from hell is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2008, 03:09 PM   #67
ED_Boy
EL Futura T5
my Futura has recently tipped 217HP (165kw) at the rear wheels
EL Futura: 4.0 L6, Factory 5spd Manual
Project Twisty
ED_Boy is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2008, 05:27 PM   #68
Stav
Smile
Stav's Avatar
19lb
I think the au ones flow more.Do check first though.
Old 28-01-2008, 06:41 PM   #69
BROCKYB8
YEAH IT IS A FORD
BROCKYB8's Avatar
ed boy 217hp = 161.82kw
165 kw = 221.27
http://www.unitconverter.com.au/
POWERED BY
CVE
www.cveperformance.com
EF PS1WGN - 2013 AFF PROJECT CAR OF YEAR
http://fordforums.com.au/showthread.php?t=11390858
STILL THE QUICKEST AFTER 4 years NA6 e series
EA BROCK 225rwkw - 12.85
BROCKYB8 is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2008, 11:54 PM   #70
fritzz
fritzz's Avatar
correct,
au= 20lb or 205cc (41hp)
ea-el= 18lb or 185cc (37hp)
# 1997 EL Falcon GLI - Custom built AU 4L bottom end, Billet Turbos B76-GTS, Nizpro plenum, 6boost manifold, Autronic SM4, Custom billet surecam camshaft, 3x 044 pumps and custom undercar surge tank, Custom 4" exhaust, ID2000 Injectors, 60mm Turbosmart gate, Turbosmart race port bov, , Tremec TKO 600, Cebco 330mm Brakes, 3.7:1 9" diff with billet axles and trutrack center 608rwkw, 9.6sec 1/4mile
# 2008 FPV FG GTE - Xa Coilovers, 20x8.5/ 20x10 fairladys
fritzz is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2008, 12:11 AM   #71
[Tonko]
What's green is gold
[Tonko]'s Avatar
Different spray pattern too i heard somewhere here....
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU -
1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps-
[Tonko] is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2008, 09:16 PM   #72
Stav
Smile
Stav's Avatar
Wink
The ba injectors different spray pattern .Au and e series should be the same.
