#61 | |||
#62 | ||
I'll be giving it a crack also. GT42 going on ef. But dont want to go faster than 11.0, on any track that will require fitting of a full roll cage. No one has really gone nuts enough with the driveline, but the speed has already been run showing that cars have the power to do it. Im sure if some of the 10 sec e-series were fitted with a glide and a 4000rpm+ stall, as well as a 9inch or Dana, they'd be in the 9's.
As for that VL turbo running 14.1 being 15th in the fastest turbo VL's, thats gay. The 15th fastest e-series would be far quicker, and has about 8 years less development done to it. How many VL's run 10's with a stock N/A bottom end? VL's were cool in their day, but its the day of the Ford Turbo now. Anyone running a 1.44A/R Turbine on a ford? |
#63 | ||
That EL XR6 is definitely an interesting machine with the positive displacement blower on the exhaust side. Shame they butchered the bumper to fit the cooler..
#64 | ||
My money is on Tufed6 to be the first Eseries into the 9s unless ea_ba_turbo hits the NOS.
#65 | ||
FPV GT-P 335!
I think ea_ba has hit the NOS in his latest PB?....can anyone verify?
Current rides - 2013 FPV GT-E MK2 & 2010 FPV F6-E Tuned by Michael J's & Son. |
#66 | ||
XF Ghia. All snorted out
I'd be happy to run a high 12, low 13 with the XF once it's finished (standard internals with EA management and bigger F/pump), and if i can do that i'll look at jigging a very cheap E-series to experiment with. 9's is probably out of the question but a ten isn't, i've been bitten by the bug to try LPG using all of the cheap ways out and parts that won't cost the earth. Wouldn't it be nice to skin a HKS moded skyline using a $150 EA that runs on taxi gas using the origional engine backed up by an all ford driveline, ie, C4 and nine inch. Just a thought at the moment but i do have the hardware to make it all happen, just need an EA, where will i find one of those.
#67 | ||
So...........did any of these cars do it?????
Is anyone building an E series to run 9's? |
#68 | ||
I build your wish list...
No but snortingboost is on the money with L.P.G. ..
I wish I had found this thread mths ago ... well done good mining |
#69 | ||
Custom e-series owner
i know of a build that is going on at the moment in a ea brock thats having a new turbo engine built and aiming for 800hp, the previous kit that was on it blew the engine and it was dynoed at 520hp at the rear treads!!!
a mate and i are waiting to get the phone call to say it is finished so that we can go and have a look... its got a manual thats been built to withstand 1000hp, 9inch and about 3 inch exhaust... once it is run in, the owner is looking at putting slicks on it and running down the track... can't wait will take pictures next time |
#70 | ||
TUFED6 is still draging the chain and has to get the car to JPC for a tune on C16 before heading out to the track.
EASPRINT only has 5 pistons after easternats. Adrian Vella is just about to run the EL again after another few tweeks that should see him better his 10.1sec Mikes dyno EA is stuck at 10.0 There is a green EL XR6 supercharged in WA that is in the 10's as well. But there is a roumor that a white EA from Bresciani Racing has cracked a 9.8sec pass, but it is only roumor as I have seen no time slip or pictures, or any other evidence. |
#71 | ||
Thanx for the update :thumbsup:
#72 | |||
![]() Join Date: Jan 2005
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
#73 | ||
Gunna girlie-man
Taken from the bresciani racing website. Although not updated in a while i would love to know where this car is at now.
"February 20th, 2006 It’s been a busy few months at the Bresciani workshop with many cars undergoing modifications. Pat’s EA Falcon has just upgraded to a Garret T51 roller bearing turbo sitting on a set of custom extractors. Boost is controlled via a 44mm external Tial wastegate. The car is also fitted with an Autronic computer, forged bottom end, Tremec 5-speed gearbox and brass button clutch through a 9-inch diff. The combination has made 435kW at the wheels on 25psi boost on an initial tune with more to come."
WADE CAMS-- UNLEASH THE POWER!! <INSERT WITTY SIGNATURE HERE> Daily- 05' BA futura... work done. Cruiser- 85' VK berlina... more work done ![]() ![]() |
#74 | |||
#75 | ||
supercharged el xr6 in wa has done a 10.1,
there is a few builds going on ova here that are going for huge numbers, so i dont think the 9's will be far away.
# 1997 EL Falcon GLI - Custom built AU 4L bottom end, Billet Turbos B76-GTS, Nizpro plenum, 6boost manifold, Autronic SM4, Custom billet surecam camshaft, 3x 044 pumps and custom undercar surge tank, Custom 4" exhaust, ID2000 Injectors, 60mm Turbosmart gate, Turbosmart race port bov, , Tremec TKO 600, Cebco 330mm Brakes, 3.7:1 9" diff with billet axles and trutrack center 608rwkw, 9.6sec 1/4mile # 2008 FPV FG GTE - Xa Coilovers, 20x8.5/ 20x10 fairladys |
#76 | ||
pats car is undergoing another rebuild, aiming for 800hp.
not far from completion that i have heard...will be there when its done... |
#77 | ||
Any updates on this?
#78 | ||
Just a bogan VF SS driver
hiboost on boosted falcon has run a 9.6 now
i think he lurks around here
Just your typical Holden Driver ![]() ![]() |
#79 | ||
i know of an EA being built that is hoping to get into the 10's N/A
if he gets there then low 9's would be on the cards with a nos tickle
#80 | ||
an N/A 6 EA running 10's?
are you building it Jason? |
#81 | |||
#82 | ||
jason you do realise to see those times it would have to have a looottttt of power.... hiboost ran 10.24 with 8.5" slicks an he has like 800hp @ wheels... since ran 9.6 with 10" slicks...
this 10 second ea doesnt happen to be orange does it? |
#83 | |||
I also said that he is hoping to get into the 10's i didn't say it will get there Time will tell it should be racing by the new year ( if i can get there to build the cage ) and it is not mine Jason
#84 | |||
OzEcruisers PRESIDENT
![]() Join Date: Mar 2005
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan PROEF 13.46 @ 105.78mph Tuned by DYNOMOTIVE 200BUX - AFF Drag Nats 2019 EF Wagon
#85 | ||
YEAH IT IS A FORD
10 on a na motor.
Well how bout a 12 or 11 first. Na 6 fastest is jmm - 13.29 in a stripped out car 0ed666 - 13.71 - In a complete car Grenchie - 13.79 The jmm did a 12.1 on Nos i would believe with turnbo he did a 9.96 and the white ea did a 9.91 i believe . Now Hi boost has done a 9.6
POWERED BY CVE www.cveperformance.com EF PS1WGN - 2013 AFF PROJECT CAR OF YEAR http://fordforums.com.au/showthread.php?t=11390858 STILL THE QUICKEST AFTER 4 years NA6 e series EA BROCK 225rwkw - 12.85 |
#86 | |||
#87 | ||
Gunna girlie-man
lol good luck jason...... oh lord
#88 | ||
Do not turn this into a school yard scrap. Take any negative posts to PM.
Please keep this thread to the topic. |
