Old 20-02-2007, 07:21 PM   #31
Stav
Smile
Stav's Avatar
There is noise everywhere and the oil light came on today.This means no oil pressure.The car is getting towed to the mechanics on Thursday morning. I was super clean...The car was going like a bullet!!! I drove it till the afternoon thinking how good wsid will be then bung ..it happened. Some thing has given way .I checked the compression and its fine.This morning it idled fine and fairly quiet.After a while the light flickered on/off. Near home it just stayed on..Got home,dropped the sump to try and see inside and could not see anything.
What would cause no oil pressure? A wrecked oil pump? A blockage?
Old 20-02-2007, 08:22 PM   #32
jonbays
TL40 Wagon?
This is BAD news mate
I do not like the sound of it at all.
Old 20-02-2007, 08:32 PM   #33
mik
mik's Avatar
do you think something could have come loose draining your oil presure away? hope its an easy fixer:
Old 20-02-2007, 09:10 PM   #34
AusXH
Powered by 8
AusXH's Avatar
Just a quick note on removing the BBM should you decide to attack it again. I've found it easiest to remove the upper part of the manifold first (using an allen key to crack, then a cordless drill and hex head extension to remove the bolts) and then the fuel rail along with the injectors. This leaves it all clear and the bolts very accessible.
Best of luck with it all Stav.
AusXH is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2007, 10:08 PM   #35
FS5
don't know mate ,somethings let go .theres not much that can go wrong with what you did .
did you block the oil galleries in the head while you were trying to get the bolts undone? maybe something drop down there ?
it wouldn't be the first time someones dropped somethin down there .the first cam i put in mine the (jmm).i dropped the micrometer tip down an oil gallery trying to dial in the stupid cam .it lived in there for 2 days before i changed the oil and fished it out :
no oil pressure is serious ,could it just be a dud sensor , maybe you bumped a wire somewhere .
just remember its only $500 a for a replacement engine.its what keeps me going .
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17.
FS5 is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2007, 10:15 PM   #36
Stav
Smile
Stav's Avatar
Mate it may have something to do with the 600orpm's it hit just before but it was dam good fun....if its or an engine well let it be number 3 with my race head and the surecam!!
Old 21-02-2007, 07:42 AM   #37
james22
With da Warlords
james22's Avatar
Tough luck dude, Let us know how it goes.
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
Old 21-02-2007, 09:05 PM   #38
AUXRVIII
Seized or broken oil pump drive. Have seen a few break.
AUXRVIII is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2007, 07:11 AM   #39
Stav
Smile
Stav's Avatar
I think you are right.I never drive the car hard until at least 15 minutes has passed to get the oil well circulated for protection. That day was just like a godsend to me with the way it was going fast and I gave it too much too soon.
Old 22-02-2007, 02:52 PM   #40
Mechan1k
Mechan1k's Avatar
Hope you find out what's wrong with it ... and hopefully it's not too muc of an expensive fix either.
If it's really bad ... 2nd hand low-km AU engines go for around $700.
Old 25-02-2007, 05:10 PM   #41
Stav
Smile
Stav's Avatar
Was the pump.Fixed... :sm_headba :hihi: :1syellow1
Old 25-02-2007, 09:58 PM   #42
FS5
OOOOOOOOOOOH YEAHHHH!!!!!
so whens the head goin on now man ?
Old 26-02-2007, 11:53 AM   #43
xr8ute
Back on the road
xr8ute's Avatar
Aah, that must be a relief.
Glad to hear it is back on the road Stav
Old 26-02-2007, 02:01 PM   #44
Stav
Smile
Stav's Avatar
As another friend of mine on the forum has mentioned..maybe the car is telling me something...leave it alone!! So head will go on when it leaks or I get the headbolts off first one day.
