Closed Thread
Old 01-02-2007, 12:15 PM   #31
Baboon_AU
Baboon_AU's Avatar
hey mate go to glenfords in canningvale on bannister road there.. i got an awesome jack there. 3.5 tonne.. its a big mother f*cker and its really low at the front so u can get under really low cars. worthwhile investmemt.
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline
Old 01-02-2007, 12:18 PM   #32
If the wife will let me (given I now have four trolley jacks of various types and vintages it will be difficult to justify). Actually if I can't get a car lift I want one of those lightweight aluminium race jacks next as I am getting too old to drag th large iron ones about.
aussiblue is offline
Old 01-02-2007, 12:30 PM   #33
kryzak260
Brembo Lover
Probably a silly question, but where are you guys jacking your cars up from?
I have used the scissor jack to change a wheel and i put it in the little slot in the body (sill i guess you would call it) where it tells you to, and the metal bent back towards the middle of the car because of the weight. Since then i have avoided jacking the car up...
Mine: 2007 BFII XR6 Turbo in Conquer with Sunroof, BFII Typhoon rims, CarPC, FPV Leather Wheel
Hers: 2006 BF Super Pursuit in Vixen
kryzak260 is offline
Old 01-02-2007, 01:15 PM   #34
There is a jacking pad inside from the sill at front and use the diff at the rear.
Old 01-02-2007, 01:40 PM   #35
kryzak260
Brembo Lover
Are there jacking pads at the rear inside the sill aswell? I just cant see myself jacking the whole rear of the car up on a dirt shoulder to change one tyre ;)
Old 01-02-2007, 05:09 PM   #36
Hords
Treasure your balls?
Hords's Avatar
Any input on where to "safely" put the axle stands once the jacking pad is occupied by the trolley jack?
Meteorite T3 TS50 ESS
Hords is offline
Old 01-02-2007, 05:18 PM   #37
Casper
Contributing Member
Casper's Avatar
under the chassis rails that run from in front of the rear wheels to behind the front wheels.
Older, wiser, poorer.
Casper is offline
Old 01-02-2007, 05:27 PM   #38
Scott
I often worry about young blokes who buy these cheap jacks. I own one and use it often but only to get the car high enough to use my big fella - I reckon that's all they are good for.
Scott is offline
Old 01-02-2007, 05:32 PM   #39
Hords
Hords's Avatar
Thanks Casper,
I take it they're the outer rails running adjacent to the sill and not the inner ones adjacent to the exhaust (RHS)?
Hords is offline
Old 14-02-2007, 10:08 PM   #40
Here's the answer a jack that is also a jack stand http://www.alltradetools.com/index.h...d/3693/lang/EN
6000lb Capacity. Patented design combines jack stand and bottle jack in one unit. Safety bar locks unit at desired height. Wide steel base for stability under load. Height Range: 13-1/2” to 21-1/2”. Perfect for SUV’s, off-road vehicles, construction jobs, framing and floor joisting
Old 05-03-2008, 11:57 AM   #41
gozza
gozza's Avatar
You call that a trolley jack?
gozza is offline
Old 05-03-2008, 02:22 PM   #42
HLC
Audi S3
looks like this thread is back from the dead, so ill kill it,
but this is a safety lesson to all of us. axle stands are a must when working under a car. better to be safe than sorry.
HLC is offline
Closed Thread
