Old 19-11-2006, 12:13 AM   #31
Sundeep
Sundeep's Avatar
Yeah pretty nicely done huh? Couldn't have hit a gutter better myself if I tried I reckon.
Yay for finding urethane bushes in the control arm, boo for the control arm going in the bin.
Sundeep
Sundeep is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2006, 01:46 AM   #32
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
****. That would have hit at atleast 70 kays.
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2006, 02:50 AM   #33
Heffnic
this is true
Heffnic's Avatar
Right on the money really good impact, not good for the back a little bit of whiplash up the gutter at about that speed to do that damage.
EF Fairmont, stage 2 crow cam, 18" apache rims,xr air intake,full Lukey exhaust system, supalow springs, green dash mod,last dyno 145rwkw,stereo :gren:
Heffnic is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2006, 05:24 PM   #34
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
the question every one wants to know the answer to, how is the gutter?
VE SS Ute manual 09
AU XR8 UTE 200KW manual 02
Challanger Ski boat V8 01
125 Thumpster 2010
Swag
All set for the weekend
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2006, 10:57 PM   #35
needfordspeed
I don't think so, no one has asked that question yet. Do you have a gutter fetish or something?
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH
needfordspeed is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2006, 10:58 PM   #36
dansedgli
dansedgli's Avatar
ma\\\
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2006, 11:05 PM   #37
Olympus
Rocket Fuel Anyone?
Olympus's Avatar
been there done that. He probably needs some new stabilizing bars too. When I did it I bend my rear axle as well.
Olympus is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2006, 12:06 AM   #38
Damo
the gutter was fine. The people who slept in it were not so lucky.
Old 20-11-2006, 12:09 AM   #39
Sundeep
Sundeep's Avatar
Lol you guys still going?
The car is fixed, didn't take so long to do it. I hate working on suspension but I'm such a pro I could replace the whole front end in 15 minutes with 2 people helping.
Anyways.. everything lined up well and the car drives nicely. Just needs a wheel alignment and it's set.
Replacing the distributor, on the other hand, was a whole other story :'(
Sundeep
Old 20-11-2006, 12:12 AM   #40
Damo
can you sign my rocker cover sunny ?
Old 20-11-2006, 12:24 AM   #41
Sundeep
Sundeep's Avatar
Man I'm gunna bring the fattest **** off texta to the next cruise and make sure I sign you rocker cover.. if you don't let me I'll drop ya..
Sundeep
Old 20-11-2006, 12:45 AM   #42
Rollin
Rollin's Avatar
I can't believe you are whinging about replacing the distributor! so easy!
take off airbox lid and IAC motor, take off plug leads at plug ends and remove cap, pull it all out. remove the rotor and the other plastic bit the cap sits on, undo the bolt that holds the dizzy in and pull it out carefully....
d@mn mexicans...
Rollin is offline   Reply With Quote Multi-Quote with this Post
