29-09-2006, 06:53 PM | #31 | ||
im an apprentice for a CAT dealership and CAT machinery has mostly all magnetic plugs.. and they are in everything ranging from diffs to hubs, to axels to sumps. its not so much to collect the particles but to tell when to overhaul a component. on brand new cars, i would recommend that as soon as you get it, dump the oil and install a magnetic sump plug and then every 1000kms for 10 000km you should dump the oil and see how much metal is on the plug.. there will be heaps as all the moving internal parts are wearing in and shed metal filings.
01 AUII XLS Regency Red Ute 4.0L Egas Auto Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam, 1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD. Thanks to: EvilChief and SJW Performance |
29-09-2006, 10:47 PM | #32 | ||
Early holden Gen III's had magnetic sump plugs from factory thats so u could tell when they shat.. :MrT_anim:
then they went back to standard type i guess to many people got worried when they found it |
30-09-2006, 01:04 AM | #33 | ||
Thanks guys,and I thought that no one would reply,was I wrong! desicion made,im getting one next week,thanks again,this forum rocks,one happy lion
Ice creams for everyone!!! |
30-09-2006, 02:51 AM | #34 | |||
B-Series Moderator
BF MKII XR6 Turbo 2007 (Flare) ZF Auto 380rwkw - 11.68 @ 120.94mph 60ft=1.97 Custom Tune, Exhaust. injectors.1.2K Plazmaman 1.2K Plenum kit Now with bigger turbo and 426rwkw. |
30-09-2006, 10:07 AM | #35 | |||
Walking with God
GK
30-09-2006, 10:12 AM | #36 | |||
Walking with God
Sometimes my slowness on the uptake astounds me! LOL! *GK retreats to corner, pondering the potential embarrassement of that last statement to be quoted back to him many times! LOL!* GK
30-09-2006, 11:09 AM | #37 | |||
Treasure your balls?
Meteorite T3 TS50 ESS |
09-10-2006, 07:54 PM | #38 | ||
Walking with God
Originally Posted by phildee These $20 ones seem to look much more like the proper sump plug http://cgi.ebay.com.au/FORD-FALCON-...1QQcmdZViewItem Might have to grab one for the next oil change. Wish I'd seen that one first, before getting the other one! LOL! GK Sorry to quote myself here, but that was almost like a prophecy or something! I got the plug from the first supplier in the thread, was sent the wrong plug, not sure why but am not getting a refund and keeping the plug. The plug sent was smaller in diameter (the bolt itself) and wouldn't actually cover the area of the sump hole. The thread was wrong also, too large, not by much so it didn't work out. I then (as of this morning) ordered 2 (I thought, what the heck!) from the second supplier, as he uses original Ford plugs to start with. Made sure I emailed him to let me know I'm getting AU plugs as I don't want anymore oil on my drive. Not much, but the smooth changeover of plugs I had envisaged did not occur! LOL! I'll let you know how they go! GK
09-10-2006, 11:16 PM | #39 | ||
a good source for a powerfull little magnet is old computer hard drives, a bit of mucking around but would make a good pan/sump magnet.
27-10-2006, 02:52 PM | #40 | ||
I would be careful about sticking magnets onto the oil pan unless you plan to drop the pan and clean it regularly. If you don't drop the pan off to clean it, the particles just build up and as the power of the magnet decreases (all ferrite magnets lose strength) those particles are then released back into the oil.
A magnetic sump plug is a great idea because you are removing the particles when you remove the plug and clean it. When I was racing, we always stuck magnets to the oil filter as well. This kept anything metallic that was floating around in the oil trapped inside the filter and when we replaced the filter the particles were thrown out with the filter. Back then, we used ordinary ferrite magnets but we were changing filters every month so the risk of the magnet losing enough strength and releasing the particles wasn't really a risk. Just recently I read about using the magnets from a hard drive and so this morning I pulled one apart and removed the magnets. It only took about 5 minutes and was quite easy. For their size they are EXTREMELY strong and should be safe to mount on my road cars oil filter for the 6 months or so between oil changes. |
27-10-2006, 03:08 PM | #41 | |||
I know the paste like gunk, I've rebuilt a N12 Pulsar gearbox before, which had about 400 grams of that pastey stuff, 50 grams of metal shavings and about a kg of stripped gear teeth! |
27-10-2006, 08:06 PM | #42 | ||
Walking with God
Both plugs are in.
Haven't done an oil change yet, but intend to do one in a few thou, which will have the oil roughly 3,000 kays old. I'll take a pic of the magnetic plug when I change it. Cheers, GK
