#31 | |||
Go drive another VE that one could be a bad example. Handling to most is misunderstood as it is about ride and steering feel to most. Handling is about, it will respond to commands of a excellent driver with no stupid surprises. or maybe it is safer for an hopeless fool just steering it. I was in a new SSV manual ute the shocks were rubbish and old mate did not know about the traction control so he did not have it switched off so power was not that impressive taking off. |
#32 | ||
personally i think the falcon and the commy handle very well for a vast general duties,as do most modern cars, obviously everyone`s perception of handling is different, and manufacturers could if they wanted set them up like a super cars.......................which would be totally ridiculous and impractical for the every day driver who bounds over speed humps, pot holes, across driveways,loads the boot up with 20 bags of compost, etc, etc, alternatively throws the kids and gear + the boat or van on the back and heads bush.
being honest with yourself why would you wan`t any better than what our sporty sedans comes equipped with, of course if you have another daily and it`s a weekend track car well that`s different. and the magazines telling us "car x can get a bit unstable at 200 kph while negotiating a tight bumpy sweeper", "the stability control keeps it on track but it does`nt feel as good as car z going at 200 kph through a bumpy tight sweeper" ......er yeah right, like even 10% of us will be doing that in this day and age, as for the question does handling matter? yes it does .....up to a point, the point varies with drivers demands, an XT or omega are 10 times better handling and safer cars now than cars from the old days, imo even the poverty paks have abilities above the abilities of most drivers to drive them at ten tenths anyway, don`t get me started on FWD vs RWD. |
#33 | ||
I'd be more concerned with how well the bastard stops than its handling, as long as it doesn't go round corners like a couch I guess
http://i56.tinypic.com/23hlk6p.jpg |
#34 | |||
Ford Convert
In a FWD car, obviously not applied in the situation I described above as that would very much be impossible .... but in the case of ever losing control in the wet what to do I wouldn't even know TBH .... Hope for the best? |
#35 | |||
I am Groot
![]() Join Date: Dec 2007
.. ![]() ![]() ![]() ![]() "Those were the days when the cars were cars, they weren't built out of an Ikea pack like they are now and clothed in plastic; they were real cars." John Bowe |
#36 | |||
Once (in my RWD Territory) I was following a (FWD) Barina around a bend in the wet and the rear end of the Barina lost traction and he started to go into a slide. I had to maneouvre suddenly to avoid him and I still didn't lose traction. In my experience a traditional RWD (before ESC and all that) will give you some sign that it's about to lose grip, a FWD holds on longer but at the extreme will suddenly lose grip at the rear without warning and violently. Years ago there was a fatal crash on a curve of the Cahill expressway in Sydney where some young bloke took his small FWD into the curve too quickly (probably overconfidence in the FWD), the rear came unstuck, the car spun around and crashed backwards and the petrol tank ruptured and exploded. Anyway, on topic, the average buyer won't drive to that extreme, the manufacturer uses FWD to save costs, the design, weight distribution etc will probably be not the best (unless its European) and the handling will be a dog, but the buyer won't care because they'll assume that's how a modern car handles. They won't even try the alternatives to get to know any better. |
#37 | ||
Ford Convert
Yer I suppose it's a situation most drivers would not have to deal with too often but it's the inherent properties of my Falcon right now in regards to the combination of reasonable power, high line pressure, lsd diff, tyres that are due for replacement(next week) and then add some water on the road and a little too much throttle(it's easy to do) and the back end is very prone too movement.
Even still in such a situation the excellent handling characteristics of the falcon given it's chubby nature always mean I am able to easily correct a mistake of my own making as any correction must happen literally in a split second and requires good steering feel n feedback imo and obviously the knowledge of when to apply traction and when not to the REAR wheels. |
#38 | ||
It is nice to feel a bit of sideways squirm and a slide or two in rear wheel drive cars when driving hard, which you need to have traction control/ stab controls all shut down for, but when as newer good handling cars like xr6's hsv's are getting less and less give from fun to lost it on a slippery patch, I can have more fun in renaults Clio or Megane. They are awesome fun! You would NEVER beat it over the mountains with a gt or HSV. You can actaully drive crazy hard and theres still give on the limits. Also to those that say cars like this understeer? get your road lines correct! just back off from that understeer and it will not, even oversteer a bit.
But to answer the question, does anyone care? I would say less than 1% of drivers really care about handling. |
#39 | ||
I would say I drive (at times) my FWD much harder than the average punter, and it's never lost traction. Then again, it doesn't have anywhere near as much grunt as an RS etc...
![]() The truth is most people aren't going to get anywhere near the limits of their car, RWD or FWD, unless they're being extra stupid, or the conditions are particularly extreme - gravel/water/ice on a road etc.
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red. ![]() Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White. |
#40 | |||
Monday to Friday; drive to work and back. If have kids, will drop off and pick up. Visit mates. Saturday; (if not working, taking kids to something, visiting people, following up chores) go for a spirited drive, safely so as to not lose licence and empty wallet, or get car confiscated for dangerous driving. Sunday; (as above for Saturday) recovering from Saturday, getting ready for Monday. Really, how much of persons driving can be used to enjoy the handling of a car? 5, 10, 15%? Most people want good handling, but mostly they want a comfortable quiet ride so that they can enjoy their time in the car in traffic on the way to work. And lets face it, most new cars handle quite well for what we require. I've driven all the cars you mention, and none of them would make me say "that handles *****". What I notice is how it parks and steers around the city and suburbs, vision through windows, crash and bumps on roads, tyre noise, etc. I had a 2012 Focus Titanium and Sport for a few days, both fantastic handling cars, great cars in fact; would I buy one? No. I wanted to but they're set up wrong for us (me and wife). The Titanium had everything we want in a car, but the ride was too firm, turning circle poor and lots of tyre noise (tyre issue, check it out in the Focus section of forum). The Sport had a perfect ride, turning circle was good, tyre noise fine. However, we couldn't get it with the options we wanted - basically whats in the Titanium. Both models handle extremely well, the Titanium more so only because of the wheel package - bigger, fatter, lower profile. Basically, Ford lost a sale because they have built a "drivers" car but got confused with which model it should be - Sport or Titanium. So to answer your question; everyone wants a good handling car, but for their every day car the priority is comfort.
The true danger only occurs when you take a potentially dangerous piece of machinery and place it in the hands of the most unpredictable species on the planet. Human behaviour, as history has catalogued, cannot account for what any persons actions may be, especially concerning their love of the motor vehicle. http://www.fireservicecollege.ac.uk ![]() Last edited by johnydep; 16-02-2012 at 12:30 PM. |
#41 | ||
Ford Convert
Driving home from work just now and I'm behind this knobhead in a camry. We were approaching the end of the road I was travelling on which finishes with a blind crest into a t-intersection, Craigieburn/Epping Road to those northern suburban members.
Anyway pre-empting that most likely, like everyday .... traffic would come too a dead stop on the other side of the crest and considering it was bucketing down liquid horsepower I was well on the brakes before even climbing the said crest. Old mate proceeds to continue over the crest without any thought to what might be on the other side and when he gets over realizes he needs to stop rather quickly. Jams on the anchors and TBH I don't even know how he managed to stop but this camry literally pivots on it's front wheels and ends up perpendicular to the car he was following. I watch all this unfold with a good twenty metres to spare in front of me only to look in my rear view to see the dumb ***** in her pintara just about do the same thing but instead she nearly spears of the side of the road into the drainage ditch. I can only shake my head at these people, as by definition I am the dangerous modified car driving hoon and these people are your "safe" average drivers? |
#42 | ||
Where I live there is a 70km/h, dual lane, and divided section of road with a large sweeping bend in it. I am continually frustrated by people taking the corner at 50km/h or less. I have seen fully loaded semis' take the corner faster than 90% of the roads users. This leads me to the conclusion that people hate G forces. They accelerate slowly, and corner slowly, just so they feel like they are sitting in an armchair.
#43 | ||
"How important is the handling to the average car buyer?" - not important at all LOL if it were, there would be lots of people driving around with modified suspensions
arguing on the internet is like running in the special olympics, even if you win, you're still a retard! |
#44 | |||
![]() They bag someone harshly for driving at 0.05 but they them self could not even come close to some people driving at 0.10 at all. There is a lot of people that are just so pathetic sober that it can make a joke of the 0.05 thing. A good driver that is a seasoned drinker can be a better driver at 0.05 than maybe 50% of the people on the road and that's a fact. but some people will waffle on with, ooww! how dare you. you should be ashamed with your self and that one could turnaround and say back, you can't even drive regardless as you are hopeless and a menace 24/7. and that's a fact. ![]() Not supporting drink driving but it is a true story. |
#45 | ||
335 - STILL THE BOSS ...
'Handling' is an excuse used when your car is underpowered! Being used of late by those with a HSV, drive their GF's hatch and anything slower than a GT 335!
'73 Landau - 10.82 @ 131mph '11 FG GT335 - 12.43 @ 116mph '95 XG ute - 3 minutes, 21.14 @ 64mph 101,436 MEMBERS ......... 101,436 OPINIONS ..... What could possibly go wrong! Clevo Mafia [SIGPIC][/SIGPIC] |
#46 | ||
Would like to hear from someone thats sells cars as i think you will find a lot of people dont even test drive a car these days. So if they are not taking them out for a test drive how important can handling be?
VIXEN MK II GT 0238 with Sunroof and tinted windows with out all the go fast bits I actually need ![]() |
#47 | |||
I once took a Barina for a test drive and asked the salesman if I could find some winding road where I could "rally" it a bit like my old Mini. He just went white and said "no"! |
#48 | ||
as in chopped
To most people, Handling would be less important than how many cup holders a car has, or what colours it comes in.
(But then again a nice handling street car will have it's doors blown off by a dedicated track car on the track. It's all relevant.)
-> Reading this signature was pointless <- |
#49 | |||
The Futuriser
Current Subaru Liberty MY08 2.5 SatNav Previous 2003 BA Ford Futura. CKGD - Freelance Graphic Designer |
#50 | |||
#51 | |||
_Oo===oO_
However I love the fact that it's overqualified for it's job (which for me is being a comfortable, well equipped, cheap to own, daily driver) Great handling wold be pretty low on most people's lists I imagine. |
#52 | ||
I think that people these days dont really care about the handling of their car just how many kms to the tank they get. I know i didnt buy my territory for its handling capabilties (but if i want to go round corners fast ill just take the rally car for a squirt :P).99% of people dont really care about going for"spirited" drives.
#53 | |||
![]() People want something comfortable, good on fuel, well equipped with toys, and safe...in that order. Steering? It goes around the corners doesn't it? What more do you want. Different people, different perceptions as well...i run my '82 Celica with nicely setup suspension that's tight as a drum and it handles like it's on rails...compared to that, the G6E is a marshmallow. However, taken in isolation, the G6E is a tight, nicely steering thing for a luxury car. It's only when you start direct comparisons...like hopping straight out of one car and into another like car magazines do or has been mentioned in this very thread...that you really notice the differences. I've driven new commodores and new Falcons, and reckon they're both pretty damn good for a large heavy Australian car. They're not expensive Euro-sedans, and for the price, they're bloody good deals, both of them. |
#54 | ||
It isn't , or else Toyota would never sell a single car .
Chevy badges , the Polariser of the new millenia . |
#55 | |||
Looking at cleavage is like looking at the sun. You don't stare at it, it's too risky. You get a glimpse of it then you look away. |
#56 | |||
As far as I know, the biggest killers on the road are those under the influence of drugs / alcohol and speed. I do indeed see a heap of drivers out there who are completely useless, devoid of any driving skill or idea of what's happening around them at any given time. But, these people still don't make up the largest portion of killers, more so the ones who'll run up your backside or side-swipe when attempting to overtake. They aren't the risk takers. The risk takers die or kill others. Last edited by martyk54; 17-02-2012 at 11:53 PM. |
#57 | |||
#58 | |||
I am aware. My comment was also tongue in cheek... ![]()
#59 | |||
The biggest cause of crashes is stupidity and most could steer a car ![]() As far as i am concerned most drivers if they kill or injure people in a crash it could be just like akin to premeditated murder, because they should not even be on the bloody roads. they are just so hopless. What i am saying hear is some people are not even a good driver regardless, they may have a licence like a builder can be licenced to and be hopeless idiot. I seen one toss on TV of late the fool had a in car camera where we see other people run into him and the fool did noting to avoid it and who is to say he did not speed up and attribute to it. and he was hit on his right he was a moron. |
#60 | ||
GT-P With An Ego
drug/drunk driving penalties is something I fully agree with (and think should be harsher), as you say drivers are bad enough as is, certainly don't want booze or drugs making things worse.
The problem with setting hard limits, is as already said, someone could be hopelessly plastered and be under 0.05, while some liver damaged hard drinker could be perfectly fine to drive. The law doesn't allow for personal differences. Or we'd have variable speed limits for better drivers or worse drivers.
1998 DL LTD in Sparkling Burgundy, daily, mild 5.0L, high end stereo, slow'n'thirsty - 138.8rwkw. 2006 BF GT-P in Ego, 5.8L all alloy, Kenne Bell 2.8HLC, Nizpro Stage 2 ZF - 440rwkw. 2008 SY F6X in Silhouette, Ford Performance Club of ACT |
