#31 | |||
I build your wish list...
aarrhhh Nope have a look at the charts again .. dont worry about the graph on the rhs . mine pulls like a 14yo with his first playboy mag and stays there till red line (6,300rpm) and looking at yours it drops off a bit about 1,000rpm under red line.
If it weren’t for physics and the law enforcement, I’d be unstoppable.
#32 | ||
What Wheelspin?
i meant highest PEAK torque. your right in what you say. yours has a wider power band than mine by far.
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw) 2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned) |
#33 | ||
OzEcruisers PRESIDENT
![]() Join Date: Mar 2005
Swannys Car had more it in - as you can see on the Dyno it dipped at 4,400 thats as his tyres were slipping on the Dyno
See Here - this is his 173.5 rwkw run ![]()
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan PROEF 13.46 @ 105.78mph Tuned by DYNOMOTIVE 200BUX - AFF Drag Nats 2019 EF Wagon
#34 | ||
I will be back there in a few weeks I hope .... I will take my cam corder and get a hole run ... maybe get a bit better I hope
#35 | |||
#36 | ||
a Clive cam to my specs $280 to get one but they are a regrind as there was no billets when I got my cam .
#37 | ||
What Wheelspin?
hey swanny, i still havent done that little BBM trick you do. i should do it. i assume u have done it to yours??? and rosco aswell?
so whens the next e-series cruise anyway? time to catch up with mr swan.
#38 | |||
As MR.4.0, me and Trick run the WPN Swanny Head If you want to come play Johnny come to the HPF Dyno Day on 31st October, 2009
#39 | |||
#40 | ||
Might have to come down to the HPF day, see what the fuss is about.
OED must be loving this, his time has stood up pretty well :P
2009 BF MK3 XT EGAS WAGON PREVIOUS RIDES: 2002 AU3 FORTE EGAS WAGON - 1995 EF GLi WAGON - 1991 EB GL WAGON V8 - 1998 EL FAIRMONT TURBO phat GUARD ROLLING | 0429 093 302 | facebook "CHEAPEST GUARD ROLLING IN MELBOURNE" |
#41 | ||
Bigger numbers to come once his Car has been run in - when it hit the Dyno it had less than 300klms on the engine rebuild
Same engine Rebuild as my car - stock rods, stock crank, re-used the cast pistons - block just honed - basically new bearings, rings, oil pump...... Wish i could find that 13 second video of his old car, and ppl thought he used NOS ![]() ![]() ![]() ![]()
#42 | ||
That would be because the car got slower and slower and he wouldnt pop the bonnet :P
What dyno was that run on btw?
#43 | ||
What Wheelspin?
daltons in geelong.
#44 | |||
I know the reason that i havn't had great improvements on my car as in it is over fueling big time and the head ecu are best suited to gas not ulp oh and i should say this my EL is running the cam out of the above mentioned car as well as the ecu the only difference is that i am only running a 3.7 lsd ( not 4.11 ) and it is not on gas ( LPG ) when i get it on gas it will hit the dyno again and it will have a J3 chip in it that has been tuned properly as for the bonnet not being opened on the day it was not on happy gas I was there and it didnt put out anysounds ect that would point to happy gas the reason it got slower was the fact that it was slowly killing the auto can't wait to show some that the set up swanny does is good as you can get but that wont happen for thetime being as i dont have the $$$$$ to spend on the gas ( LPG) side of things
#45 | ||
Same Dyno when we had the Dyno Day and some boosted Members Attended for the Fun
![]() Also Dyno Dynamics was out during the week Calibrating said Dyno to make sure the readings it was putting out was Correct. I have to fix my Cat, enlarge the restricter in my exhaust to 2 half inch instead of 2 quarter inch and add the CAI and I will be pretty much up there with the Highest RWKW for an AUTO Eseries NA 6cyl ![]()
#46 | ||
What Wheelspin?
i need a rebuild! 220,000km and un even compression FTL! :(
#47 | ||
yep but a stock rebuild will get ya about the 160 mark .... there is a few things ya can do to the block to help out and make 2 or 3 more but thats only if the person knows it .
if ya go a ACL race rebuilt kit and a bore out then ya should jump to the 175 - 180 mark.... once again it depends on who builds it .... I see on another site like this there is motors built by the owners or there M8s and they are flat out trying to get 150 with a ACL rebuild and all there other fancy stuff .
#48 | ||
Guessing RWKW
![]() ![]() Dyno Proven is where its at ![]() I saw a guy with an EL XR6 rebuild and he only pulled 140rwkw mark - that was with ACL Race Pistons
#49 | ||
Im not doubting it, just need to get all the cars on the same dyno, lol!!
My EL read low, but felt quicker, and beat cars that had more power on there piece of paper. Thats the way Id rather it I think.
#50 | ||
How are you guys getting such high readings?
I had my car dyno'd at Dalton by Matt and only made 129rwkw. Im guessing most of you guys are using BBM and with slightly meaner cams but thats a pretty big difference.
Current Ride: EL XR6 - 4.0, M5, FULL EXHAUST, 18” ANZ TYCOON'S, SUPERLOWS ![]() Former Rides: EB1 FAIRMONT – 4.0, A4, FULL EXHAUST, WADE 1004, TIP J3, 18” BA XR8’S, SUPERLOWS, SPRINT KIT, AU1 FAIRMONT GHIA – 5.0, A4, 3" CATBACK, 20" VERSUS WRAITH, ULTRALOWS, TICKFORD & MOMO GOODIES |
#51 | ||
The Contributing Factor to all High Readings is the Swanny's (Trick XD's) WPN Heads
![]() MR_4.0 + Sorted + Trick XD all have these Heads Sorted + Trick XD have freshly built Stock Rebuild Bottom Ends - thats same Cast Pistons, Same Rods, Same Crank, Same Block - Basically New Rings and Bearings and only honed - no increase in cc's or cubes In my Case my Pistons, Rods, Crank and Block are over 300,000klms old Stock Bottom End Rebuild in my case did Sweet FA to rwkw's as I had 156.9 before and now I have 161.1 - thats on same Dyno
#52 | |||
#53 | ||
'04 BA XT
Dont worry mate, I just had my ute tuned at bluepower and got 128rwkw after the tune, started with 114. So I was still pretty happy with the result.
Will need to get the head done eventually though.
1979 F350 Tow Truck 80 series Turbo Diesel Cruiser |
#54 | ||
Well I am trying to find a set of pacemakers but no where here in town has them . . looks like it will be a ebay job .
I will be hoping to have a different set of extractors and a different air intake So I hope I get better power . |
#55 | ||
has anyone tried out the inlet manifold spacers/insulators?
I think you can get one that goes against the head, and one that goes in the middle of the upper and lower sections. Would be a good idea I think. |
#56 | ||
I read somewhere that its only good on a boosted car . .
it was on the internet so it must be true ????
#57 | |||
i can get you a price in the morning and let you know if you want Jason
#58 | ||
What Wheelspin?
swanny, get a set of pacey ph4480's. that what i want to get on mine now.
way better than the 4499's i have now. but will require slight retune. will alter engine vacuum at higher revs.
#59 | |||
The Dalton Dyno was calibrated by Dyno Dynamics the same week we did the recent runs. Previous Run i did was 156.9rwkw and without the Head it was 137.5rwkw So with mine it went 137.5rwkw 156.9rwkw Head and J3 Chip Tune 161.1rwkw Rebuilt Stock Bottom End, Head and J3 Cip Tune Now the 137.5rwkw although from a stock bottom end I had Pacemaker 4480's HPC Coated 3" Magnaflow Cat 2.5" Red Back Cat Back System Custom Clive Cam Auto with Hi Stall When my engine was pulled apart it was very clean and didnt really need to be rebuilt - as can be seen by the dyno readings from before and after the rebuild. Only had the engine rebuilt as it was out of the car anyway getting the cam guides and cam chain replaced ![]() So to summarise so called high readings on my auto car was from an Stock bottom end that had been well maintained. But yeah we will see what Happens at HPF ![]()
#60 | ||
LoL
and I have a Stock bottom end build a set of no name extractors Repco off the shelf exhaust stock intake Custom Clive cam and now slipping clutch Thats my motor lol as rosco said Stockys R us |
