01-01-2012, 08:30 AM | #331 | |||
Ford's research shows that 80% of running is done at less than 50% throttle opening so most of the timean Ecoboost 2.0 can be run at light throttle on Miller cycle and behave like a Hi Comp 1.4 or 1.6 but it can equally re size itself to become the equivalent of a 3.5 V6 when needed. Unlike older turbo engines with less sophisticated technology, Ecoboost engines don't need t0 as run rich at part boost for detonation protection, the new software programming does that by using the VCT, Injection timing/phasing and increased EGR so at part throttle, it's like a diesel.. |
01-01-2012, 08:32 AM | #332 | |||
Rob
jpd - so when cruising, even if the turbo is spooling, the engine can become like a much smaller capacity. cool stuff. i wonder how long it will be before camshafts are a thing of the past in everyday cars. i believe in F1 valves are operated via hydraulics and electronics and i thought ferrari or porsche had looked at that sort of thing. internal combustion engine has a few tricks left up its sleeve yet. |
01-01-2012, 08:39 AM | #333 | |||
for long range highway driving with A/C and head lights but the plug in rechargeable Electric vehicle is coming. |
01-01-2012, 08:47 AM | #334 | ||
Rob
can't believe KERS systems haven't been more widely developed. porsche went down that road too, but i guess its a fine line between developing the petrol motor further or throwing development dollars behind the electric novelty.
01-01-2012, 11:26 AM | #335 | |||
01-01-2012, 11:47 AM | #336 | |||
Electrical hybrids are most effective at low speed stop start driving, something KERS isn't good at. |
01-01-2012, 03:03 PM | #337 | |||
Peter Car
As for the Honda Accord, even with a smaller 3.5 V6, lighter weight and cylinder shutdown it still uses more fuel than an I6 Falcon. 10.1 Vs 9.9 in the Falcon. Its a pretty poor engine really if after all those factors it still uses more juice than a bigger Falcon "dinosaur". |
01-01-2012, 03:25 PM | #338 | |||
Thailand Specials
01-01-2012, 06:11 PM | #339 | ||
Ute Forum Moderator
We will just have to wait & see. The Ecoboost Edge has had good reviews from what I have seen, but in the heavier Explorer not so good.. More locally a similar scenario is the Mazda CX-7 with the 2.3 DI turbo. They have reasonable official fuel economy ratings but can be pretty horrible in the real world, 14l/100 is pretty common or should I say easy to achieve.
I don't see why the Falcon won't be able to cruise without boost, and I am optimistic that the acceleration figures indicate that under 'normal' throttle applications it will be only under light boost in normal driving. Ironically I think that eco-tuning can be counter-productive because if the car is not responsive enough, people just apply more throttle which negates any economy benefit and more. |
01-01-2012, 08:25 PM | #340 | ||||
reducing capacity to around 70% and with it compression but adding boost to this reduced capacity actually increases torque on light throttle meaning a 2.0 Ecoboost actually behaves like a 1.4 or 1.6 litre engine that's lightly boosted making it seem like a good 2.5 DI engine while giving outstanding economy. Confused? Quote:
IMO, using the 12:1 compression package with petrol and accessing more Atkinson cycle would give the 4.0 I-6 much more variable capacity, enabling it to ape a 2.8 litre I-6 on cruise... |
01-01-2012, 08:47 PM | #341 | ||
Everyone that's experienced turbos on the past is afraid of part throttle boost and the associated enrichment
needed to avoid detonation, well I'm here to tell you that Ecoboost actually achieves a state of lean boost due to sophisticated control of detonation through use of VCT, multiple firing of direct injection and healthy amount of EGR. Precise control of all functions is the key to Ecoboost's success, it's way more than just a Bosch DI Turbo system, that's why Ford has taken out so many patents on the software especially, protocols and control strategies |
01-01-2012, 09:37 PM | #342 | ||
will a t67 high mount fit
will the internals hold 30psi will sct have a tuner will pwr make a water to air kit |
01-01-2012, 10:04 PM | #343 | ||
Good link to Ford paper on advanced Ecoboost studies here
Engineer a comprehensive suite of gasoline engine systems technologies to achieve the project objectives, including 25% Total Fuel Economy Improvement •Aggressive engine downsizing in a mid-sized sedan from a large V6 to a small I4 (18% Fuel Economy Improvement) Mid & long term EcoBoost technologies •Advanced dilute combustion w/ cooled exhaust gas recycling & advanced ignition •Advanced lean combustion w/ direct fuel injection & advanced ignition •Advanced boosting systems w/ active & compounding components •Advanced cooling & after treatment systems5% Fuel Economy Improvement Additional technologies •Advanced friction reduction technologies •Advanced engine control strategies •Advanced NVH countermeasures3% Fuel EconomyImprovement Last edited by jpd80; 01-01-2012 at 10:24 PM. |
02-01-2012, 01:18 PM | #344 | |||
Peter Car
01-02-2012, 12:08 PM | #345 | ||
some info for you..
Falcon EcoBoost specs 179kW @ 5,500 353Nm @ 2,000 8.1L/100km for XT (192g/km CO2) 8.5L/100km for G6 and G6E (201g/km CO2) No price premium. Also a minor change to EcoLPi which has further improved economy and emissions. Available Q2. |
01-02-2012, 12:10 PM | #346 | ||
Wow thats impressive...
Whats the 0 - 100.. It should nearly outdo the 3.6 Omega.
2022 RAM Laramie 5.7 2023.50 Ranger Wildtrak 3.0 V6 Premium Pack 2024 Everest Sport 3.0 V6 Touring Pack 2024.50 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA Jan 25. |
01-02-2012, 12:10 PM | #347 | ||
So about the same economy as Camry, but a hell of alot more power and torque.
01-02-2012, 12:13 PM | #348 | ||
That torque figure is insane for a 2 litre.
The real clincher though is the no price premium! |
01-02-2012, 12:17 PM | #349 | |||
Pity the fool
Those L/100 figures combined cycle? I'm struggling to understand why there is such a difference between the XT and G series.
Fords I own or have owned: 1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD Proud to buy Australian and support Ford Australia through thick and thin |
01-02-2012, 12:32 PM | #350 | ||
Rob
surely this makes the 6cyl redundant to all but a small minority of buyers!!
only 3kw less than BA. not quite as much peak torque but being available at just off idle, you wouldn't notice. i can't see a reason why you would tick the 6cyl petrol box. |
01-02-2012, 12:34 PM | #351 | ||
Cheaper fuel, cheaper rego.... its all a win...
I think ill trade my GT in on a G6.... comfy suspension / tyre combo, cheap to run..... sounds like the car to own!
01-02-2012, 12:35 PM | #352 | |||
01-02-2012, 12:38 PM | #353 | ||
So when does left hand drive production begin??? That would eat the base model 5 series and e class for breakfast........ maybe thas all part of the plan. Impressive specs indeed.
01-02-2012, 12:39 PM | #354 | |||
01-02-2012, 12:44 PM | #355 | ||
8.1 litres v 8.5 litres per 100 km's on the face of it doesn't appear logical ??
01-02-2012, 12:50 PM | #356 | |||
I still think there's a good case for the I6 but agree the Ecoboost stat's look impressive. |
01-02-2012, 01:12 PM | #357 | |||
Might be a sign of things though, the 6 handles more weight easier... I would hate to think what the economy of the 4 pot towing would be!!
01-02-2012, 02:05 PM | #358 | |||
The G6 is 30KG heavier than the XT, and the G6E is another 20kg heavier than the G6, however even an extra 50kg would not suddenly make an already very heavy car 5% less fuel efficient. With the I6 the economy difference is only 0.1 ltr/100km between the XT and G6E, I would expect the weight differential to be the same (as its due to luxury equipment levels) and the wheel/tyre difference is well known.
That seems to suggest the XT has undergone some additional changes to further reduce the economy, possibly lighter smaller wheels, and low resistance tyres, further demonstrating Ford’s focus on the Fleet market for the EcoBoost. Not having an XR6 Ecoboost further suggest private buyers are not the targeted audience. Quote:
01-02-2012, 02:08 PM | #359 | |||
01-02-2012, 02:11 PM | #360 | ||
Dunno guys its hard to figure. The new eco tyres are pretty trick but they're not cheap so if they're putting them on an XT is beggars belief they wouldn't go on the more expensive G6 and G6E.
Maybe the G6 and G6E rims and that super new touchscreen are all made of lead |
