03-09-2024, 06:02 PM | #2101 | ||
Outbackman59
Sorry if this is in wrong area,
I am asking gt legend if Air cooling module ((resistor)number Ar29-8c609-ab Is still available and how much are they worth Is for a diesel territtory Regards phil |
03-09-2024, 09:37 PM | #2102 | |||
The part number you supplied is actually an engineering number, this corresponds to service part AR2Z8C609AB. They are obsolete, but may be still some around. Let me check and get back to you. |
04-09-2024, 08:56 AM | #2103 | |||
Managed to track one down, did not realise they were so expensive @$770 plus postage/freight if required. Let me know if you would like me to organise for you. GT |
04-09-2024, 10:26 AM | #2104 | ||
Outbackman59
Hi gt,
Very much appreciate the effort but once the son gets over his heart attack he will say dont worry about it ,so tu very much Rregards phil |
04-09-2024, 12:19 PM | #2105 | ||
Interestingly these https://www.ebay.com.au/itm/23560604...Bk9SR46xlK23ZA look extremely similar to these https://www.ebay.com.au/itm/37558034...Bk9SR46xlK23ZA and https://www.ebay.com/itm/37529034831...Bk9SR7KF3q23ZA Might be worth trying.
regards Blue Last edited by aussiblue; 04-09-2024 at 12:29 PM. |
04-09-2024, 03:33 PM | #2106 | ||
Outbackman59
Yeah i seen them to blue son been told so will see what he does
And just a big shout out and thank to all the help that is given on this forum tu all |
04-09-2024, 05:46 PM | #2107 | ||
hi
GT, Mazda BT50 UN single/regular cab 3.0lt diesel 4x4 5spd man del date jun 011 build date 1/11 Vin MM00UNY0E400891415 Diesel injector price and availability please Bosch no. 0445110249 ? Bosch unit comes with copper washer ,,genuine ? Warranty length ? Seems to vary alot |
04-09-2024, 07:08 PM | #2108 | |||
Will have to do a bit of research on this as I really have Ford info. If they are the same as Mazda, Ford injectors are around $1000 each and washers are seperate at around $4.20 each. I dont have bosch equivalent numbers or bosch numbers at all. Warranty for manufacturing defect is 12 month/20K kms. Let me check with a Mazda contact and get back to you. GT |
04-09-2024, 07:36 PM | #2109 | ||
GT, can you still get the child anchor hook point for an FGX?
If so how much.
04-09-2024, 09:16 PM | #2110 | ||
08-09-2024, 04:48 PM | #2111 | ||
It's not an FG MKI.......
Hey mate.
Chasing a pair of windscreen washer jets for an FG. Express posted to 0830 if available. Thanks.
06/08 Manual FG XR6T. Not an FG1 or MKI, an FG... Want to know how to do an A Service for an FG XR6T? Look in this http://fordforums.com.au/showthread.php?t=11339404 Thinking of oil sampling your engine? Have a look at this trend http://fordforums.com.au/showthread....ght=oil+sample |
08-09-2024, 04:49 PM | #2112 | ||
08-09-2024, 04:50 PM | #2113 | |||
19-09-2024, 11:54 PM | #2114 | ||
Looking for a headlight for my 2012 MkII XR6. Part number is BR2Z13006BA. Can you help with that one? Looked online but everyone seems to be sold out.
20-09-2024, 11:26 AM | #2115 | ||
23-09-2024, 11:52 PM | #2116 | ||
Hi GT
Looking at taking the challenge to do the REAR suspension bushes in my Mar/2009 SY1 Territory RWD. (BIG job I know) Can you help me with part numbers and pricing on these please: and if they are sold as each or pairs. - Upper Control Arm - Inner Bush - Upper Control Arm - Outer Bush/cross axis ball joint - Lower Control Arm (also called toe arm?) - Inner Bush - Lower Control Arm (also called toe arm?) - Outer Bush/cross axis ball joint - The other lower control arm that carries spring - Inner bush - The other lower control arm that carries spring - Outer bush/cross axis ball joint - Control blade bushes - The 3 diff bushes (do they come as a set, or each? ... and from what i can tell the outer two bushes are the same on all models, but the middle one seems to have a few different ones? I can send you my vin if that helps. Appreciate your help.
2007 BFII XT Wagon, 2009 SY Territory TX (Just Bought) & 1997 NL Fairlaine Ghia (Currently Parked with Blown Motor) Last edited by Mosquito; 24-09-2024 at 12:11 AM. |
24-09-2024, 12:10 AM | #2117 | |||
Hi mate, So, I think the easiest way to avoid confusion if for you to write the part numbers from below images of the suspension you want and we can go from there. Let you know if we need a VIN later pending on what we come up with. SY Rear Suspension .png SY Rear Frame.png Cheers, GT |
24-09-2024, 12:38 AM | #2118 | ||
Mate! So quick! I went back to edit the post and by the time I'd finished you'd already replied!
Here's the numbers off your diagrams... Upper Control Arm Bushes 5B639A 5A659A Lower Control Arm (Toe Arm) Bushes 5A659B 5B659B Other Lower Control Arm Bushes 5B638 There appears to be a bush missing on the diagram - goes on the bolt/nut between 5R649A & 5N649A - I'll see if i can attach a pic from the workshop manual. Control Blade Bush 5A638 Diff Bushes 4B424 4B425 (this is the one I think can be different across models) Thanks!
2007 BFII XT Wagon, 2009 SY Territory TX (Just Bought) & 1997 NL Fairlaine Ghia (Currently Parked with Blown Motor) Last edited by Mosquito; 24-09-2024 at 12:48 AM. |
24-09-2024, 07:21 AM | #2119 | |||
SY Rear Knuckle.png |
24-09-2024, 07:26 AM | #2120 | ||
24-09-2024, 08:53 AM | #2121 | |||
24-09-2024, 10:40 AM | #2122 | ||
Thankyou so much...
At $1800 bucks, I'll need to rethink if I really need/want to do the job...lol I'll get under and thouroughly inspect everying again. I really appreciate your time! You are a blessing to the community!
2007 BFII XT Wagon, 2009 SY Territory TX (Just Bought) & 1997 NL Fairlaine Ghia (Currently Parked with Blown Motor) |
26-09-2024, 04:06 PM | #2123 | ||
Hi GT,
I am looking for a set of front shocks for an '09 FG GT, I imagine that the GT had different shocks to the other models, XR etc, Can you help me with these or are they NLA. Regards |
26-09-2024, 07:25 PM | #2124 | |||
There were a few variations in front shocks on the FPV's, do you have the genuine shocks in the car? if so can you advise what colour label or part number is at the bottom of the shock. If not I can try and narrow down from a VIN. We can go from there. GT |
26-09-2024, 08:30 PM | #2125 | ||
Yes mate, had it since new - original shocks still on it.
VIN 6FPAAAJGSW9R54454. Thanks |
27-09-2024, 05:37 PM | #2126 | |||
Obsolete now from what I can see. GT |
27-09-2024, 06:59 PM | #2127 | ||
Thanks Mate, I appreciate you going to that trouble. I was thinking today that if they are NLA I will have a discussion with Koni about valving a set as close to the original spec as possible....I do like the way the car handles.
regards. |
27-09-2024, 07:05 PM | #2128 | |||
https://www.ebay.com.au/itm/23323318...Bk9SR5z5tavGZA https://www.ebay.com.au/itm/12663650...YQBPH31XBDAFVF
regards Blue |
27-09-2024, 07:37 PM | #2129 | |||
27-09-2024, 09:07 PM | #2130 | |||
regards Blue |
