About when did Australian market cars stop coming equipped with a hole for crank starting, and the handle to accomplish it?
One of the last I can remember was the Renault 12, which ran until the mid-seventies. Looking at pictures of EK Holdens, I can’t discern a hole in the front - but maybe it’s below the bumper, and I don’t believe even the first XK Falcons had a crank hole. |
Reckon they still exist in Melbourne's mens public toilets
5 users like this post: |
That wasn’t what I meant!
For some what some reference I think a E-Series starter MAY bolt to a cross flow but a crossflow starter is NOT interchangeable with the pre-crossflow ( I may be wrong and thinking pre-crossflow to before ( I'm not sure what that motor is called/goes by( Canadian motor I think and had both a electric starter and a hand crank
All people have the right to stupedity but some people abuse the privilege |
60 series Landcruiser had hand crank provision, though I believe "most" OZ market ones had the larger radiator which obscured the crank nose, they ran to 1990. 40 series Landcruiser also had hand cranks (1984) aswell as a bunch of older cruisers (55 series).
The Silver Bullet - BJ74 Where the actions at Ontrack 4wd Club https://www.facebook.com/ontrack4wdclub |
surely with the compression of today's engines it would be impossible to hand crank a motor. think of trying to crank start a 12cyl Lambogini
Good points Hulsty, do you also know if Land Rover carried the crank starting option into Series 3?
Generally, too - didn’t the early Beetles have a crank hole? |
Experienced Member
Have just checked the early Series 3 Landy in the shop, crank hole in the bumper.
2H 60 Series definitely had it.
Surprised to see M&D's Renault 12 had it, but the car was designed for North Africa. Beautiful car, so comfortable front seats, you could rally it on dirt tracks happily, and a really weird (and sensible: north/south fwd means no torque steer) FWD setup. Ours was Virage wagon.
I6 + AWD |
#12 | ||
#13 | ||
Experienced Member
#14 | ||
![]() Join Date: Oct 2006
The last car in our family that I can recall having provision for crank handle was a "Beetle Backed" Phase I Standard Vanguard.
It had the little bit in the middle of the bottom half of the venetian blind style grill that folded down to access it. ![]()
regards Blue |
4 users like this post: |
#15 | ||||
Regular...with metamusal
![]() Join Date: Oct 2009
nor did any Valiants, local or imported. |
#17 | ||
![]() If you see this happen, then you cut it mid stream and run ![]() On a more on topic note, imagine trying to hand crank a modern car, 10.5:1 compression ratios, or a turbo diesel in the vicinity of 17.5:1 ![]() Last edited by Franco Cozzo; 16-08-2024 at 08:22 PM. |
#18 | ||
Edit, wrong car and motor/box configuration. But I’m still pretty sure there was no crank start option for the Virage. You could troll Aussieflogs to ask them.
