02-06-2024, 06:17 PM | #841 | ||
Is there a more insufferable weed than English Ivy? I think not, especially after injuring my back trying to pull a large infestation from a fence/gate/garden shed/hedge.
Actually, looking into this, most of that people know of English Ivy (Hedera helix) is actually Irish Ivy (Hedera hibernica). https://weeds.org.au/profiles/english-ivy/ https://www.walterreeves.com/landsca...dentification/ “Irish Ivy is normally larger than English Ivy, in both its leaves and petioles. The Irish ivy leaf is wider than long, with a broad terminal lobe and the leaves are shiny with greenish, not white veins. Also English ivy has a musty odor, while Irish ivy’s is sweet-ish." The seeds are highly attractive to birds, helping it spread far and wide. But the ability to take root from any piece of the plant is its hallmark for survival. And because of that extensive root development, it's extremely hard to control, be that chemically or mechanically. I've seen Ivy drink glyphosate as if it were fertilizer. I have heard of using dousing it with kerosene, but that would contaminate the surrounding soil.
08-06-2024, 09:33 PM | #842 | ||
The start of the winter bare root season this year has been slower than usual. The first delivery from Flemings's arrived at 7am yesterday, of which 600 assorted ornamental and fruiting trees were sorted, labeled, orders pulled and then lined up and buried in sand. A process that took just on 8 hours to complete.
Circa 9am....................... Eight hours later..................... A number of varieties were not sent in that initial Fleming's delivery, so there will be a couple of follow up deliveries to follow. The majority of our fruit tree assortment will arrive next week from a secondary supplier. Roses and our yearly allocation of citrus trees typically arrive late June or early July.
3 users like this post: |
03-07-2024, 06:09 PM | #843 | ||
A couple of months ago, one our supplier reps left a display stand with the intention of showcasing in-season plants. The rep has then been supplying advanced potted specimens to give customers an idea of what they can expect each plant can do. This is all well and good, but my creative brain spotted the potential expand on the idea...................
This plant stand was made by a men's shed, presumably from reclaimed timber. Well, we have plenty of that on hand, with a stack of un-used pallets taking up space in the yard. Pulling them apart was going to be the challenge, so I bought a lever bar from eBay.................. https://www.ebay.com.au/itm/355034833921 Before starting the project, I had measured up and drew out a layout plan mimicking the original, I then knew what amount of timber I was going to need. It took me a bit to figure out the best way to use the lever bar without ruining the timber, but the tool made short work of stripping the pallets down. Following this, I removed all the nails and docked everything to length. Then the fun part of putting it together............... Including the re-used timber, I also used up an assortment of odd-bod screws, so excluding the pry bar and my labour, I made something from nothing. I plan to make more of these as time allows, which will be used around the nursery as needed. I was hoping to have a few of these made prior to the bare root roses arriving, they would display well in these.
4 users like this post: |
05-07-2024, 07:25 PM | #844 | ||
Vision achieved!
The goal wasn't to house all of them, rather to create some visual interest rather than a collection of black pots dumped on the ground. It also makes them more "shoppable". I have had to shell out on some screws after raiding the odd-bod bucket, but even still, the outlay is minimal.................and I'm enjoying work again.
05-07-2024, 09:07 PM | #845 | ||
at the feet at one end drill a hole, place a axle through, couple ave sized wheels and along the lengtyh about base of bed height couple of longer rails and you have yoursels a cart style wheelbarrow.
05-07-2024, 09:09 PM | #846 | ||
Ooooo, that gives me an idea for a moveable display at the front entrance.
05-07-2024, 11:31 PM | #848 | ||
Hmmmmm, maybe...........................
06-07-2024, 07:50 PM | #849 | ||
Why do I imagine you quickly wheeling the displays to block the entrance when you see a particularly painful customer pulling up?
06-07-2024, 07:54 PM | #850 | |||
What a good idea!
07-07-2024, 09:44 PM | #851 | ||
Surely the highlight of the winter landscape, Camellia Japonica season is in full swing....................
08-07-2024, 06:36 PM | #852 | ||
Just bought myself a set of Knipex pincers to help remove nails from the pallets I've been breaking down. The set at work have gone missing, and while I made do with a claw hammer, I was snapping some of the nail heads using it. Hopefully this will help out.
https://www.totaltools.com.au/46643-...pincer-5001210
08-07-2024, 09:52 PM | #853 | ||
hope you dont snip the buggas off....... like I regularly do
08-07-2024, 09:59 PM | #854 | ||
last big project i did with pallets, very rustic well planned, can seat 60 people inside
image posting
20-07-2024, 08:02 PM | #855 | |||
I'm still knocking these things out, I have made seven of them now, with timber cut for an eighth. This week I have focused on making them with shorter legs, 500mm instead of 750mm. While the 750mm versions are at the perfect height for customers to shop from, I like to display plants at differing heights to create visual appeal. Because the companies impact driver and drill were being used elsewhere, I brought in my own this week. That Milwaukee M18 Surge is the BOMB! It's just so smooth and quiet, in my mind this would be less fatiguing for someone who uses one of these all day long. The hydraulic gearset means you can creep up on the fastener rather than just smashing it into oblivion, handy for soft timbers or when using it on plastic. Money well spent! I also found an old stencil of the company name in the shed, previously used to brand tools and equipment from when we had a landscaping division. The lettering is about 90mm high and 300mm long, which fits within the central board. After centering the stencil across facing sides, I applied a thin dusting of satin black spray paint. In keeping with the rustic look, the stenciled company name in black really finishes them off. I would also love to have a stencil made of the company logo to complete the look, perhaps in a contrasting color.
24-07-2024, 10:20 AM | #856 | ||
I’ve discovered there is an apparent shortage of popular Elaeocarpus variants in saleable sizing in NSW. Is this also true for your area - or does the winter chill mean it’s not sold much there?
24-07-2024, 10:42 AM | #857 | |||
Regular...with metamusal
i saw the bottom pic 1st & went 'round yard'?. that would have taken awhile with all those posts. |
24-07-2024, 06:32 PM | #858 | ||
We don't carry many Elaeocarpus, so I couldn't say. Having said that, a lot of plants become unavailable during the colder months as the growers run out of saleable stock. The grower more than likely has stock laid down, but they are waiting for spring growth before sending them out as viable, saleable stock. This is often hard to describe to customers from the Amazon generation, you know, we should just be able to order them in at a drop of hat.
24-07-2024, 08:31 PM | #859 | |||
Everything was second hand/recycled inluding all nuts, bolts wood screws etc
24-07-2024, 11:39 PM | #860 | ||
I’m close to calling the cusp of spring here, the air has a different feel and sun a bite. The nurseries which have previously bombarded with emails about stuff including Elaeocarpus spp around now, are seeming much more restricted in their online offerings. I’ll check them in a few weeks and see if it’s changed.
Magnolias are fantastic just now, absolute peak up my way for the deciduous varieties. |
25-07-2024, 02:42 PM | #861 | ||
T3/Sprint8
Christ CB you reckon we’re on the turn ?
I think your being influenced that we’ve finally had a couple of weeks of no rain but temps have still been low but sure is a pleasant change feeling some sun for a change. Sent from my iPhone using Tapatalk
25-07-2024, 06:35 PM | #862 | |||
25-07-2024, 06:53 PM | #863 | |||
T3/Sprint8
Some kind of running over hot coals challenge pit ? Alot of fun with 60 competitors family more so inlaws ? yer I wouldn't mind a few walking over hot coals haha Have you a score board close by we haven't seen ?
25-07-2024, 08:33 PM | #864 | ||
used to be an open fire pit but the outside of summer the wind could be a real deterant so I created this as my farewell present April last year.
Its apparently been very popular and successful. No fire walking or dragons though.
Today, 07:58 PM | #865 | ||
Despite there being plenty to keep me busy in winter, a lack of customer flow does become a concern in terms of cash flow. When it's cold and overcast, I can hardly blame people for not wanting to buy stuff for their garden. This year though, I also think cost of living is at play at one end of the spectrum, and at the other, people are jetting off to somewhere warmer now that Covid restrictions are a thing of the past.
After today, I can safely say that spring is now on its way. The days are getting longer, the sunnier and warmer temps are bringing the customers out of the woodwork. Speaking of woodwork.............................. For now, I've finished the display boxes made from old pallets. Actually, someone wanted to buy one the other day, so I may end up having to build some more. At the moment, I've swung into making some custom sign holders. Again, re-claimed timber and some screws. To hold them upright, I've used some pvc electrical conduit I found out back, which then slots into a hole bored into the timber dividers used in our display tanks. As spring approaches, time is fast running out for these tasks. Spring is about selling, restocking, selling, restocking.......................
