Ive searched threads for an answer to my problem but no success. Sorry if this is a repetitive one.
Just bought this 2011 Mondeo Turbo Diesel automatic. 170,000 with service history since leaving the factory. I have never driven one before this so not sure if this is normal for a Diesel Mondeo. Takes time to reach speeds and even longer in slight climbs. Example, standing start take off i will hit 60km in roughly 100 meters. Very dangerous turning into traffic when finding a gap. Another example while in a minor climb is the exit ramp out of my town merging onto the hwy has a climb not that steep..... but Takes me almost 1000 meters in distance to reach 100km speed and only doing around 60km at the point of merge. I'ts as if i'm towing a truck behind. Rev gage shows 2500-3500 rpm in-between gear change (depending on the slope of the road). No Engine lights appear. No codes showing when plugged in. Turbo tested and it's fine. PS: Another strange happening is i can feel the gear change kick down when approaching a intersection. I feel the jerk at around 40-35km speed. It's as if it shifts down to 2nd or 1st to early. Not sure if this is also normal for a power shift Anyone with an idea? or is this gutless acceleration normal for a Mondeo Last edited by JustBill; 08-07-2024 at 08:57 AM. |
No, that's not normal, it is a very grunty engine and pulls hard from just over 1500 rpm.
I'm not sure what could cause a loss of power like that and not generate a code. Loss of boost is one possibility, but that should result in at least one code. Sent from my SM-S906E using Tapatalk
3 users like this post: |
Some possibilities come to mind. The fuel filter or air filter might need replacing. A service "history" doesn't actually mean any real services were carried out, just that they were billed for.
Possibly a faulty injector. Maybe perform a leak back test. You could try some injector cleaner too. There could be some restriction in the exhaust. A blocked DPF should throw codes, but there could possibly be some physical damage to the exhaust. Someone who knows a lot more about these cars than me suggested that the intercooler could be partially blocked with oil from the PCV system. It should definitely rev out past 3500rpm, going close to redline. I guess it's possible the inlet manifold is gunged up with EGR soot combined the PCV oil. That wouldn't throw any codes AFAIK. Re the transmission: I would definitely look at changing the oil and external filter. DIY is best, there's videos on YouTube on how to do it. If you don't want to DIY try to find a transmission place with a clue about these cars. (There aren't many) Last edited by AlanM; 13-07-2024 at 05:17 PM. |
Another thought, it could simply be the throttle position sensor.
A possible way to check if it's this would be to use the cruise control to accelerate. If you're going about 40kmh on cruise, and press and hold the + button, the car will normally accelerate pretty fast. If it does, then the throttle pedal sensor could be the problem. |
#5 | |||
Took it to a mechanic who had it for 2 days and looked over it. They were 100% certain the injector seals is the cause and need replacement. So i did that myself. But no change, still drives the same. |
#6 | |||
I replaced them and now i can say it's 100% certain wasn't the problem as it drives exactly the same. |
A further note, I hadn’t taken in before today, that Alan Howatt (YT Mondeo taxi expert cited in other posts) has permanently upped stumps and moved to a Filipino village with his better half. He might well be up for some affordable paid consultation - is a pretty clued up character. Or someone could just be cheeky and invite him to join the forum!
#9 | |||
Yeah I had a car with leaky injector seals (the copper washers) and it drove fine apart from a burnt smell at times. That wasn't what I meant by the leak back test though. That's where the internal seals on an injector are failing and too much of the fuel pressure is being lost down the leak back line. There are other things that are easier to check first though. The leak back test requires a little investment in some parts. |
#10 | |||
I did take the injectors for testing and just got them back yesterday after one mechanic felt certain that the injectors were faulty. Results came back injectors are fine. They were cleaned up new copper washes fitted and placed back in the car, No change to the power. This is becoming Trial and Error and becoming expensive. I'm baffled why 3 different mechanics physically inspected it and none can solve the issue. PS: A symptom i haven't mentioned yet,,,,, when accelerating the rev gauge pulsates around 50-100 rpms. it pulsates up/down every 1 second looking at my watch. When using cruise control driving on level ground (no acceleration needed) rev gauge is steady. You can't hear the revs nor feel it, it's that minor. And still no codes nor engine light popping up. Last edited by JustBill; 18-07-2024 at 08:34 AM. |
We recently had a Benz in the shop with the supercharged “Kompressor” engine. Without the intake sealed properly, revs would hunt up and down.
#12 | |||
I reckon you have a leak somewhere in the induction pipework post turbo, or a hole in the intercooler. The ECU is smart enough to limit fuel in the case of not enough air to prevent it from belching out black smoke, but not cluey enough to throw codes for it. Same engine as my old Focus, same engine management system. Mine also blew injector seals, and also it's injectors return line, all it did was leak diesel over itself, didn't cause any issues with performance. Last edited by Franco Cozzo; 18-07-2024 at 01:15 PM. |
#13 | |||
Also, i discovered something else in the engine bay. On the fire wall, there seems to be a splatter of very light brown clay like dirt. Could be a pipe or hose of some sort at the turbo side of the engine. I don't think driving over a muddy puddle caused this due to the drip cover under the car. The first mechanic said he checked all the hoses and pipes leading in and out of the turbo and didn't identify a issue. He pulled the exhaust back a bit and seen the turbo working. I'm starting to think now..... "Or did he check?" |
#14 | ||
Just got a third opinion. Worse news and that the Powershift transmission is gone which is why its powerless due to slipping. Revs to 3000+ meaning engine is fantastic and nothing wrong with the power coming from this turbo diesel. I'm gutted, this car was purchased privately for my son which i picked 5 weeks ago using my sons money that he saved, who is due to come back from overseas soon. I've let him down. What a useless father i am.
#15 | ||
If it's not shuddering or clunking the transmission may just need new oil. These things need hydraulic pressure to make the clutches engage. If the oil is bad you can get excessive slipping.
There's plenty of videos on YouTube on doing the oil change. It's not as straightforward as most, but it's not hard either. Do the external filter too. Supercheap get them in pretty quick. Their part number is WTF4. Easy to remember! Once you've done the oil change it might be worth doing a clutch relearn on Forscan. |
#16 | |||
#17 | ||
Have a look at this channel on YouTube:
https://youtube.com/@yepthatsit?si=DlJagU94IetLjNi- He has fixed some severely malfunctioning powershift and Volvo DCTs. (Same transmission) by basically cleaning out the valve body and demagnetising the solenoids. Also, changing the oil may not produce an instant fix. The TCM will have adapted to dirty old oil and may take time to relearn having new oil. A clutch learn could help. It's certainly worth trying before assuming the transmission is shot. |
