27-05-2023, 05:23 PM | #1 | ||
Got a weird question. When I need to do a quick job under the car, I usually jack it up one side and put it on stands. Will doing this repeatedly put the car out of wheel alignment?
~~~~~~~~~~~~~~ Rides (past and present) Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m) AFF motto - If contrary views trigger, please use ignore button. |
27-05-2023, 05:37 PM | #2 | ||
Cabover nut
Couldn't imagine it would, not unless it fell off the stands ! Even then it would have to have loose ball joints and suspension components.
27-05-2023, 05:40 PM | #3 | ||
Bolt Nerd
Not unless you open the doors
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4 Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD 2 wheels.. 2015 103ci HD Wideglide.. SOLD SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida! (Ex Blood Orange #023 FPV Pursuit owner : ) |
27-05-2023, 05:42 PM | #4 | ||
Cabover nut
I didn't think he was working on a 2CV.
5 users like this post: |
27-05-2023, 05:51 PM | #5 | ||
you taking the mickey?
Reason I ask is that I've been doing quite a bit of repeated work recently where I've just had to jack up the one side. On occasions, I'd notice that when putting the car back down, the wheels won't be in the exact same position as before putting it up. Its not way out, but not exactly the same place. Had a wheel alignment done the other day as the car felt twitchy. The toe out was pretty bad.
27-05-2023, 10:12 PM | #6 | ||
When the car is on the ground after being driven its what I call "settled ride height". Where the bushes have stretched into their normal position and the wheels have cambered out.
When you lift the car the bushes contract, for lack of a better word, and when you drop it back on the ground it stays in that contracted state until you roll the car back and forth a few times till it goes back to normal. It will also normally leave the car sitting higher until you roll it as well. You might notice when you jack the car you can hear the wheels scrubbing as little as they pull back into the car as it lifts. The other most noticable is when you lift the front end and drop it back down the wheels will appear to have positive camber and the front end 20 to 30mm higher than normal. If some of your bushes are getting into the fubar stage then yeah, it could ruin your alignment when the suspension is at full droop. Specially the rear inners when they get old. |
27-05-2023, 11:33 PM | #7 | ||
How do you guys go around corners?
Does Ford give you a magic jack that lifts the car evenly? Or a POS that can barely lift one corner at a time. It will stress things more than a four poster hoist or a straight front or rear lift but wont break anything thats in good order. |
28-05-2023, 06:50 AM | #8 | |||
I never lift by a corner only, the way the car flexes makes me feel uncomfortable. Sent from my SM-G965F using Tapatalk
28-05-2023, 10:07 AM | #9 | ||||
Regular...with metamusal
what Jastel means is going around corners puts stress on the cars body & mainly on front corner. i would be more worried if i lifted one corner & opened a door .. then could not close it. |
3 users like this post: |
28-05-2023, 10:16 AM | #10 | ||
Cabover nut
When I first bought my van it went completely out of wheel alignment after a (kangaroo) emergency stop.
After a quick look one tie rod end had pulled outward due to it the being loose on the shaft. Considered it lucky to have been on a quiet side road. Couldn't possibly do that jacking it up.
28-05-2023, 10:22 AM | #11 | ||
4 users like this post: |
28-05-2023, 10:26 AM | #12 | ||
Cabover nut
the most important bit.
28-05-2023, 12:30 PM | #13 | ||||
I'd imagine jacking one side up to jack stands height, repeatedly, would be very different to turning a corner. And the jack that Ford provides is for emergency use, wouldn't think it'd be great for the chassis to do a corner for general "service". Quote:
28-05-2023, 08:30 PM | #14 | ||
I have jacked from all corners, with many types of jacks, in the proper areas mostly but not always, on many cars over the decades and never had a suspension move, or door not close. Often someone is cleaning car and opening doors as other guy is fixing the problem.
I have had cars hit other cars, walls, poles, animals etc and unless it actually impacts suspension or wheels I had no wheel alignment problems afterwards. Its probably not impossible but very improbable for anything to move...IF everything is tight and in good repair. |
