Old 16-08-2020, 04:45 PM   #1
PETE_XR6
Default Ford Fairlane analogue clock
I am currently taking care of a 6 cylinder ford fairlane 2000 model during the lockdown.I don’t have the opportunity to drive it much so on a number of occasions I had to recharge the battery to start it.My question is, does the analogue clock use a lot of power over a period of about 10 days or so? Will it useful to remove the fuse for the analogue clock?
PETE_XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2020, 06:02 PM   #2
wodahs
wodahs's Avatar
Default Re: Ford Fairlane analogue clock
with all that will draw power whilst the vehicle is in shut down mode id say the clock is the least you need to worry about
and if your going to go to the extreme of pulling the fuse you might as well just disconnect the battery from the vehicle to stop any draw down
yes still (as money n time permit) doing the
rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually
just remember don't be afraid to try something new.
Remember, amateurs built the Ark...Professionals built the Titanic!
I have taken up meditation... at least it's better than sitting around doing nothing !!
wodahs is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2020, 07:54 PM   #3
PETE_XR6
Thanks for the info
Old 16-08-2020, 08:10 PM   #4
stock1991
Limited supply
stock1991's Avatar
How old is the battery? A new battery could solve it or get a battery tender, like
https://www.sparesbox.com.au/part/ct...8aAj57EALw_wcB
stock1991 is offline   Reply With Quote Multi-Quote with this Post
