When I log into FF, Chrome has next to the web address " a red triangle with Not Secure" when I click on it , it tells me " site is not secure"
Why ? I use Kaspersky Total Security.
CSGhia |
#2 | ||||
FF seems secure at the top level but for some reason, they are not passing the https to the lower levels such as this reply. Quote:
Following on from DOC's reply
I don't see any security warnings using Chrome but I can sort of replicate OP's warning by changing from https:// to http:// in the web address bar. csv8 - if you log in to FF using a Bookmark or Desktop shortcut, check that the URL (of Bookmark/Shortcut) is prefixed with https://. Warning should go away if you use https://www.fordforums.com.au The only thing I can't replicate is the red triangle icon, ie, I only see a circled "i" icon if I browse FF using http://www.fordforums.com.au. |
select to reply to a post and look up the top (while in reply mode) you will now see the i (info) button instead of a lock and then you can click to see it says not fully secure.
#5 | ||||
According to Chrome Dev Tools > Security, the reply-to page is trying to access an image over http:// Quote:
I still can't replicate a red triangle warning though like the OP, and that's what got me interested in the thread. I'm using macOS High Sierra (old version I know) + Latest Chrome if that makes any difference to the tech admins. |
Shockwave
Says not secure on mine too, but I'm still using Windows 7 so thought that may be the prob.
Doesn't concern me anyway... Cheers, |
OK. I can fix the image loading - when we migrated to SSL obviously there are still some templates that are using http rather than https and they are obviously bypassing the rewrite rule that converts everything else to https. I'll track down any templates still calling http and fix them.
I've fixed a few of the internal templates that were (somewhat ironically) calling the Comodo Trust logo via http rather than http. I'm still tracking down where the image icons are being called from ...
.. and I fixed that button which was the only one that was being called with a full URL rather than a shortcut.
There can still be issues where users post pictures using http rather than https but that's a bit beyond out control.
