01-12-2019, 10:23 PM | #11 | ||
Yes, you can surely update the settings within the appropriate module to change the time-out value - I am very confident you could adjust that - the very hard bit is knowing what memory location you have to change the value of.
But, I found this for a Mustang - and they often share similar modules: Stereo Extended Play APIM 7D0-01-01 : xx?x xxxx xxxx Change ? To: A-Off, 2-20 minutes, 3-30 minutes, 4-40 minutes, 5-50 minutes, 6-60 minutes I don't have the Forscan software anymore to look at this module in my own vehicle to see what it's set to... if you were really passionate about getting this done; then you might want to phone around a few specialist dealers to see who would be prepared to make this tweak -I guess it would be more likely possible from the performance tuners. Good luck! |
