Old 12-02-2018, 05:31 PM   #1
LastLine
Talking Series 1 AU Falcon Coolant Flush
Hey fellas, just wondering what would be the best way to flush all of the coolant out of my good ol' falcoon. I've been looking around and there is no clear descriptions on how to do it. Thanks
LastLine is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2018, 06:33 PM   #2
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Embodiment of the AFF spirit in his efforts with ACP.
Default Re: Series 1 AU Falcon Coolant Flush
Hi & welcome to AFF LastLine, yep there isnt much on how to flush your AU's engine. Heres a good link that will help you hopefully, good luck -
https://www.popularmechanics.com/car...o/a78/1272246/
Edit - dont forget to turn your heater to hot & fan to flat out to bleed your system after flushing before starting your engine, leave on till your engine gets to operating temp.
cheers, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792
Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007)
Maka is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2018, 09:26 PM   #3
LastLine
I have had a look at that and other threads and people have been saying i need to disconnect the thermostat ect. to be able to flush the coolant out of the block. If i have the heater going flat out it should open up the thermostat and it should flush out that way, correct?
Old 12-02-2018, 09:49 PM   #4
stock1991
Limited supply
stock1991's Avatar
replace the thermostat
stock1991 is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2018, 08:31 AM   #5
Maka
Maka's Avatar
No, to do it properly, i would take out the thermostat & backflush the block, replace the thermostat if its old & crusty lol!
After youve flushed & reassembled the thermostat block, switch the heater & fan flatout, bleed till engine is at operating temp, good luck!
cheers, Maka
Old 13-02-2018, 10:23 AM   #6
LastLine
Smile Re: Series 1 AU Falcon Coolant Flush
cheers, Maka
Thanks heaps my dude, might as well replace it while i'm in there.
Old 13-02-2018, 10:04 PM   #7
smally289
growing up is optional
smally289's Avatar
Another way that I found was to remove the small bypass hose from the side of the thermostat housing & add water to the header tank with a garden hose with the motor running. Sticking a spare length of hose on the bypass hose fitting long enough to hang past the front bumper stops the water hitting the drive belt & making a mess.
As long as you keep the header tank full you can run it like this for several minutes.
smally289 is offline   Reply With Quote Multi-Quote with this Post
