31-08-2016, 10:09 PM | #1 | ||
searched everywhere and cant find anything.. Does anyone have the wiring colours for a 1999 WF festiva.. want to put in my cd player but there are a bunch f wires and no plugs and it looks like a birds nest
thnks |
01-09-2016, 07:42 AM | #2 | ||
I've got a WSM for one of the Festiva's from around that era so I'll see what I can find when I get home.
Cheers Russ
01-09-2016, 08:42 AM | #3 | ||
Hi. Found this for a 93 festiva http://www.modifiedlife.com/1993-for...ing-schematic/ . It might be the same, start by checking the power wires with a test light (check every wire for power first) and then use a torch battery to check the pairs of speaker wires are the correct pair for each speaker and use the colors to get + and - right. Cheers MD
03-09-2016, 02:24 PM | #4 | ||
pulled the front door covers off and checked the wiring to the speakers.. both left and right have green/yellow and green/red wires so need to trace wiring and see if it branches off into another colour
03-09-2016, 04:51 PM | #5 | ||
Hi. Try this B+ red/blue Acc+ green/blue Earth Red/black (thick)
Dial light Red/black (thin) FL+ Green/white FL- Green/red FR+ Green/orange FR- Blue/orange RL+ Yellow/blue RL- Blue/green RR+ Blue/black RR- Red As above check with a test light to make sure that you dont connect a speaker wire to an earth or power feed. This is from my old list so it should be right. Cheers MD
03-09-2016, 11:35 PM | #6 | |||
