Was wondewring does a drive belt cover from an ef\el fit an au 6? HAve heard of sum ppl putting em on but is it a simple put it on job?
Miami Pilot
![]() Join Date: Jan 2005
Yep, should fit. One end goes on thermostat housing bolt, the other should slip over the power steering (?) reservoir.
#3 | |||
Highway Taxi
Close only counts in Horse Shoes & Hand Grenades. :evil_laug |
Ferret
Pardon my ignorance, but why would you do this?
looks and safety. i think they are good looking and if i came across one i would get it..but its also a pain to inspect the drivebelt then..
01 AUII XLS Regency Red Ute 4.0L Egas Auto Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam, 1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD. Thanks to: EvilChief and SJW Performance |
The Ancient Warrior
I can think of a couple of reasons;
1. Safety. With the belt and pullies covered, it takes away the risk of pieces of clothing etc getting caught if you're leaning over the motor checking a fault where the motor is required to be running. 2. The cover stops any garbage/oil that the belt picks up, from being sprayed over the other engine components, battery & airbox, and on the underside of the bonnet. 3. It just puts the finishing touch to a bare engine front. |
so obviously there was never one made for an AU then? this sounds like a great idea. are they still available from ford or is it a wreaker crawl?
not here much anymore
Will fit any AU I6 excluding VCT ones (the cam idler gets in the way on those ones, but they have their own version made to accomodate it).
They are not an AU part, never came standard on them (except the VCT's are i said above). An EF or EL one will fit straight on with no dramas.
RAM 1500
Miami Pilot
I have one on the 6 - from the VCT motor on my old XR6.
#10 | |||
GOt one from the wreckers, looks soo much better now.
It was part looks and really safety that made me want it. The fact that all the pulleys etc are exposed sorta worries me around kids and stuff when im working on the car. Im pretty sure a finger in a moving drive pulley would not be a good thing!! Hey JC, uve painted the exact parts of your engine bay nearly like I have LOL, except i used Blueprint on the airbox etc and gold chrome on the intake pipes to the throttle body!! |
#12 | |||
FTF Club Moderator
JC what are those wires on the drivers side of the engine bay?
Albert Einstein: Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom. (It is more difficult to alter a preconception than split an atom) Falcon Tickford FPV (FTF) Car Club of NSW Fords in the Park 2010 I use and recommend Stingray Car Security. http://www.stingraycar.com.au/ |
#13 | ||
they look like amp cables and other sorts as JC has DVD player and stuff like that..
but JC, you should get some flexi black electrical conjuit for that to make it look a bit neater, well thats what i would do anyway
#14 | |||
Miami Pilot
#15 | |||
#16 | ||
Winter all year round
Do you have to change the bolt on the thermostat housing? I think they have a stud on top of the bolt then a nut holds down the cover?
Some people drive sports cars on the weekend....I drive my AU! It's not what you drive...it's how you enjoy it. Recommend trading with Mechan1k, Offyaguts, EDMONTY, PhantomXR8, HOTC2R, Partie & JC |
#17 | |||
___________
#18 | ||
Just slidin'
Just make sure you turn the thermostat housing bolt the right way
MD Mondeo - For the family
NP Pajero - For the adventure |
#19 | ||
well, i just picked one up today from ford, i think it was an EL part number, for about $35. Looks much nicer imo. The only problem is i had to use metal washers as i noticed on my brothers EL the thermostat housing belt blot has a double head on it. It should hold, but i will try and get one of thoes bolts when i go for a service.
