Hello gents, one day my ac fan decided to stay on even though ignition was turned off, bought another fan speed controller and plugged it in, it now works as normal except the ac fans only turn on when it is switched to high, another other speed eg low to 9 and the fan turns off.
Have been browsing google looking for the answer but cant seem to find it.
RIDES 76 ZH Fairlane 500, Mushroom Beige, Brown vinyl roof, 351 c4 13.361 @ 104mph 2.001 60ft 208rwkw ZH BUILD |
CNC fixer guy
Hi Mate,
Are you sure the fan controller you replaced it with is for a climate control type unit? Was the replacement part new? -Andrew.
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player. Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers. |
Hi Andrew, I got it out of a Fairmont with climate control that was being wrecked.
The transistor on the back did look corroded but it still works properly except only works on high now. Not sure if I need a new transistor on it or if the old fan controller was broken.
CNC fixer guy
I remember years ago my dads nc lane with climate control had the same prob that you had originally.
The fan would stay on. It was a short cct transistor and i managed to replace just the tranny and fixed it. Im not sure if the au might have a tranny for speed control up to no. 9 and a relay in parallel for flat out ( speed no. 10). If you can read the transistor part number we can then identify the collector and emitter and see if it has a dead short or open cct or indeed if it has a relay in circuit?
Went to jaycar and they don't have the transistors so ill have to order another off ebay and go from there
CNC fixer guy
Ok.
Can you see any components on the speed control unit beside the transistor? If there is a relay for high speed , it may be mounted there or else where. Possibly the used one you got has an open cct transistor and there is a relay for speed 10? What part no is the transistor? Any chance of a pic of the speed control unit?
![]() Join Date: Oct 2006
See http://www.fordforums.com.au/showthread.php?t=11319441 both pages.
regards Blue |
