Old 30-10-2009, 01:41 AM   #1
James12344321
Getting Sideways
Default AU II Tach signal help
can any one tell me where to attach my tach signal sensor wire
i got a DRIFT digital tach its got the + - and signal wire and the AWESOME little cut into the wire joiners but anyway what wire should i attach the signal wire to
there has to be something but there is a tach in the dash and it has to get it some how
i got the new one because when i give it some the dash tach jumps up in like 1500 rpm lots and its REALLY annoying :(
Ford Falcon AUII - 3" Exhaust, 18" Wheels, Full TS50 Kit, Custom Air Intake, LSD, Sony Audio 2x 12 Subs, Twin Thermo Fans, K&N Air Filter, Polished Aluminum Rocker Cover, Pacemaker Headers, High Performance Tune, Blue Interior Lights + Neons. 0-100km 6.42s 0-180km 22.1s.
Not to bad for my second car.
Next Mod: TURBO :
Any Holden drive could tell you exactly what the back of my car looks like yet no idea what the front looks like.
James12344321 is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2009, 02:23 AM   #2
JC
Miami Pilot
JC's Avatar
The ECU pinouts are on this site somewhere - just do a search. From memory, it's a pink wire you're looking form or maybe purple?
A cheaper solution to installing a second tacho is fixing your current one - my bet is the cluster has been out at some stage, and the needle has been pushed back on too hard; just get a fork under the needle and lift up slightly, and it should work nice and smooth. If you're not sure how to remove cluster and get the clear plastic cover of, do a search in the AU section on "cluster" (there's plenty of threads covering how to remove etc).
Is yours a 6 or an 8? If the former, I'd be interested to know how you got the 0-100 time in your signature.
Ford Performance Club ACT
Old 30-10-2009, 07:38 AM   #3
frd906
me to jc me to, will be very interested, theres no way with the mods in your signature you would get that, unless its a v8
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2009, 08:46 AM   #4
xr8ute
Back on the road
xr8ute's Avatar
Yeah, its a pink wire and referred to as Clean Tacho Output. Its pin 45 on the V8, not sure about the i6.
Looks like that 0-100 time was measured with a G-Tech
AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute
5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor.
Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash.
xr8ute is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2009, 09:01 AM   #5
JC
Miami Pilot
JC's Avatar
Probably the same pinout on the 6 too then, but check the ECU pinout diagram.
Or abacus, stopwatch, fingers etc! :
Old 06-06-2014, 03:27 PM   #6
Rfordsfun
Default Re: AU II Tach signal help
Au 2 i6 what counts rpm? Ie how does the car verify. Thanks besides the tachometer, where does tachy get it's reading?
Rfordsfun is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2014, 10:31 PM   #7
Evgeni
Auto Nerd
Evgeni's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: In recognition of the many hours spent scanning information for the benefit of AFF members.
Most likely the crank sensor via the computer. The computer would convert the analogue signal to a digital pulse.
Evgeni is offline   Reply With Quote Multi-Quote with this Post
