#31 | ||
It appears to be doing it accros both banks. But besides that I can't log down to an individual injector. At least I am pretty sure I can't. The way it is doing it I feel it is sensor related as it is pretty consistent. I have tried a couple of slightly varied tunes through the quaterhorse to no luck. Same thing regardless.
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust. Wagon Build AU I Forte Sedan - No longer
Toy Car Build |
#32 | ||
Just a wild guess, its not something silly like you've got your LHS bank O2 sensor wiring swapped with your RHS bank O2 sensor?
#33 | |||
Thanks for the thought though ![]()
Toy Car Build |
#34 | ||
So after being in the shed for a week or so without running this is what it was doing....since the problem has started it has been doing this sometimes on startup. But it seems now it is permanent :(
The second start up was with a bit of throttle although it really was not liking it :/ Any ideas? ![]()
Toy Car Build |
#35 | ||
Just saw the video, it does seem like a spark problem, but who knows...
Im not sure what drives the ignition timing in AU3 V8, but I assume the ECU takes the crankshaft position sensor and camshaft position sensor signals. FTe342 did suggest camshaft sensor, but as a test if you havent already done this, unplug the harness to the camshaft sensor and run the car again like in the video. If problem still exists then it may not be the cam sensor... But if it runs ok then maybe its a cam sensor issue? Good luck. |
#36 | |||
Toy Car Build |
