21-08-2012, 12:35 AM | #1 | ||
Sometime it flashed slowly, and getting slower and slower, then stopped flashing at all, and the green arrow on my dash stay on there.
Is it an easy problem to fix? Anyone know how to fix it? Thanks in advance! |
21-08-2012, 12:46 AM | #2 | ||
Check if you have any indicator lights not on. If indicator lights on more than likely flasher cube needs replacement. (located in fusebox)
21-08-2012, 06:56 AM | #3 | ||
Just slidin'
Indicator relay, as said above. Its a pretty cheap fix as well.
You can also just get in there and give it a clean, or a wiggle, sometimes it can make it work again for a while.
MD Mondeo - For the family
NP Pajero - For the adventure |
21-08-2012, 10:35 AM | #4 | ||
Flairs - Truckers Delight
step 1. locate flasher relay (see below diagram)
step 2. remove step 3. whack it on the concrete/gutter/road about 5 times step 4. replace step 5. try, find it works, say 'why the hell did doing that fix it?' step 6. from now on realise that that the tick-ah-tick-ah comes from the little cube relay in the fusebox and not behind the little green arrow on the cluster step 7. do a burnout
21-08-2012, 08:24 PM | #5 | |||
'mechanically-challenged'
sirchAU's Galaxy Blue Falcon S
21-08-2012, 08:54 PM | #6 | ||
Walking with God
I'd change the relay.
Mr Hardware has got the good oil! Quick and easy to do. GK
21-08-2012, 11:17 PM | #7 | |||
I will try your steps, hopefully it will work Thanks mate. |
21-08-2012, 11:39 PM | #8 | ||
Yup r5 should be a black box with 3 pins
22-08-2012, 12:21 AM | #9 | ||
Rob
remember, only do step 7 when indicator is safely working again.
99 liquid silver AU Classic -Sold
Supercharged Nissan 350z 280rwkw Blueprint series 3 AU V8 manual |
