got a ford au 1 that will not start , we replaced the inhibitor switch no go , new battery still nothin , the starter is fine tried a new ignition barrel that didnt make her go either , starting to run out of idears on this one anyone got any idears on this one
#2 | |||
Or is it being immobilised for some reason by the ECU? |
Is the engine turning over? What if you bridge out the starter? Or give the starter a good wack with your hammer handle?
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
Au Falcon = Mr Reliable
if its not turning over check your body control module (bcm), do a search on bcm related problems you might find something & go over all the relays under the bonnet.
cheers,Maka
what are the circumstances leading to it`s failure in the first place?
Sounds stupid but if its a Auto take out of park and down to say Drive and back upto Park..
Sorry im sure you have already checked this |
good idea the Sly1, try starting her in neutral as well.
#8 | |||
#9 | |||
#10 | |||
Bugger!
Checked alternator output? Should be 13.5-14v, too high and it can cause all sorts of problems.
Whoops, there goes another factory setup! Chop and change - butchering cars since 1990 ![]() |
#12 | |||
#13 | ||
normally the problem with a series one is not stopping
![]() sorry had to say it. I'd be checking to see if the immobiliser is kicking in if it cranks by bridging the starter but still won't start sounds like it is immobilised
[SIGPIC][/SIGPIC]
#14 | |||
#15 | ||
Formally kotevski22
I have the same problem what was the fix
#16 | ||
i think this is definatly something to do with the imobiliser as we can get heer to go if we turn her over within a few seconds of conecting the battery up its like the computer then kicks in and says im borken or somthin taking the car into auto electrisian on tuesday will post diganostics he gets
#17 | ||
up date , well the au went left her battery off for 5 days put it back on and blow me she went bugger me 8 times now with out a problem , i did wonder if the computer still thought the netural safty switch was still broken even after we fixed it , i guess the computer needed more time to reset
#18 | ||
Formally kotevski22
Fixed Ford Re Program The Key To The Pcm All Good Thanks For The Reply's.
