Drag Racing Discuss Drag Racing here be it dirt or tarmac. Sponsored by Sydney Dragway. |
07-11-2011, 08:33 PM | #31 | |||
RIDES 76 ZH Fairlane 500, Mushroom Beige, Brown vinyl roof, 351 c4 13.361 @ 104mph 2.001 60ft 208rwkw ZH BUILD |
08-11-2011, 06:27 PM | #32 | ||
maybe strip some weight off her i.e spare tyre reo bars... helps
25-11-2011, 06:08 PM | #33 | ||
make sure your not sitting in the middle of the water when you do your burn out get some one to guide you to the edge of the water .because it builds up under your guards then drips down onto the start line.also work out a routine and stick to it .good luck
ba xr8 ute 11.69 118 manual. stock motor .nos . 1.55 60ft |
03-03-2012, 10:42 PM | #34 | |||
1000+ passes
XY ute 1600+ kgs, normally aspirated pump gas 351 std stroke, cast iron 2V heads, toploader, drag radials, 11.524 - 119.48mph https://www.facebook.com/DragRacingT...2067110055900/ http://www.cacklingpipes.com/100825_...250810_025.JPG XA coupe naturally, aspirated Cleveland, full exhaust, 98 oct pump gas, drag radials, Manual trans, 10.664 132 mph The faster youve gone the worse your attitude |
06-03-2012, 02:32 PM | #35 | |||
Tribal Elder
06-04-2012, 05:50 PM | #36 | |||
Steve
I'm surprised no one picked this up
(Torque x rpm)/5252 = HP (318 x 5260)/5252 = 318.48 HP |
28-04-2012, 10:03 AM | #37 | ||
When we were playing with relatively slow cars as teenagers we used to drop the fan belt off before the run and push it up to the line. Do the pass then put it back on on the return road. This was only in Geminis and escorts that ran 15 and 16 sec times but usually dropped a few tenths. Air cleaner off? Back seats out? Tyre pressures? Slicks would help but there are plenty of cars running consistant quicker times on normal street tyres. I used to run reasonably consistant low 12's with 195 street tyres in a turbo rotary escort (don't laugh it was a lot of fun)
